Question about Philips DVDR520H DVD Player/HDD
System seems to have crashed
MY philips DVDR520H seems to function ok, except one day when i turned it on and opened the browser window to playback something i had recorded, the pictures that indicate what has been recorded were all grey and after waiting a while to see whether they loaded they remained grey. when i try to play one of them, it freezes and i end up having to switch the whole thing off to get it started again. strange thing is that after this if i tape something its picture is displayed in the browser and i can play it no problem, but the ones taped before whatever happened remain grey and unwatchable. It seems if i deleted all the affected one my dvd player would continue functioning correctly, however i dont what to lose anything that i have on the harddrive. Is there anyway i can restore them?
    Genius:
  • 1,074 Answers
There is no way you can restore them consider the pictures lost you will have to delete them in order that your set wil function properly.
Posted on Mar 19, 2007
SOURCE:
Philips DVDR520H DVD Player will not recognise disc
Disc must be the right type (+R) . Not faulty, and have nothing on it if it is a use once disc . If it does not work then after a reboot , the drive may be faulty .
Aug 18, 2012 | Philips DVDR520H DVD Player/HDD
My computer problem is 0x3bc3 just crashed
Saw a solution in the web and it helps. Try the following step;
"System process at address 0xE4783995 have just crashed, please follow these steps to deactivate it from your system." is a fake warning and the only visible part of the infection which is defined as a Trojan/Ransomware. It's a piece of malware that blocks pretty much everything on your computer and demands payment in exchange for the identification key. In order to remove the "System process at address 0xE4783995 have just crashed"
STEP
Enter this code: 754-896-324-589-742 to unlock your computer.
HOW TO UNINSTALL IT
To remove all System process at address 0xE4783995 have just crashed files, you must kill all System process at address 0xE4783995 have just crashed processes that are running in your computer's memory. To kill System process at address 0xE4783995 have just crashed processes, press CTRL+ALT+DELETE to open the Windows Task Manager. Click on the "Processes" tab, search for System process at address 0xE4783995 have just crashed, then right-click it and select "End Process" key.
You'll also need to remove System process at address 0xE4783995 have just crashed registry keys. To remove System process at address 0xE4783995 have just crashed registry keys, click on the Windows "Start" button and select "Run" to open Windows Registry Editor. A window will popup. Type "regedit" into the box, and click "OK". Search for the registry key "HKEY_LOCAL_MACHINE\Software\System process at address 0xE4783995 have just crashed." Right-click it and select "Delete."
Finally, you'll need to manually delete other files to clean your PC of System process at address 0xE4783995 have just crashed. These System process at address 0xE4783995 have just crashed can be in the form of EXE, DLL, LSP, TOOLBAR, BROWSER HIJACK, and/or BROWSER PLUGIN. For example, System process at address 0xE4783995 have just crashed might create a file like
%PROGRAM_FILES%\System process at address 0xE4783995 have just crashed\System process at address 0xE4783995 have just crashed.exe. Locate and remove these files.
Jul 04, 2011 | Computers & Internet
Hi i have labtop acer emachine e 510 when i wanna log in this message appear system process at address 0x3bc3 have just crashed please follow these steps to deactivate it from your system * i cant...
IT is a fake warning and the only visible part of the infection which is defined as a Trojan/Ransomware. It's a piece of malware that blocks pretty much everything on your computer and demands payment in exchange for the identification key. In order to remove the "System process at address 0x3bc3 have just crashed"
STEP
HOW TO UNINSTALL IT
3bc3 have just crashed files, you must kill all System process at address 0xE4783995 have just crashed processes that are running in your computer's memory. To kill System process at address 0x3bc3 have just crashed processes, press CTRL+ALT+DELETE to open the Windows Task Manager. Click on the "Processes" tab, search for System process at address 0xE4783995 have just crashed, then right-click it and select "End Process" key.
3bc3 have just crashed registry keys. To remove System process at address 0x3bc3 have just crashed registry keys, click on the Windows "Start" button and select "Run" to open Windows Registry Editor. A window will popup. Type "regedit" into the box, and click "OK". Search for the registry key "HKEY_LOCAL_MACHINE\Software\System process at address 0x3bc3 have just crashed." Right-click it and select "Delete."
3bc3 have just crashed. These System process at address 0x3bc3 have just crashed can be in the form of EXE, DLL, LSP, TOOLBAR, BROWSER HIJACK, and/or BROWSER PLUGIN. For example, System process at address 0x3bc3 have just crashed might create a file like
3bc3 have just crashed\System process at address 0x3bc3have just crashed.exe. Locate and remove these files.
Jun 29, 2011 | Computers & Internet
It said that my mozilla firefox has crashed,how will i be able to fix it as soon as possible
A browser "crash" is not a permanent problem. It simply means the browser has encountered a problem during that browsing session, and cannot continue running. The browser will then usually close. (If not, you should terminate the browser program - Use the Windows Task Manager, or restart the computer if necessary.) When you restart the browser, it should then function normally again.
There are many factors that can lead to a browser crash. Those can include glitches in the browser's code, or problems with the operating system, or problems with a particular site that has been visited. Most current browsers (Firefox, IE, Chrome) are quite stable, but nearly every browser will experience a crash from time to time. It's a small annoyance, but not a cause for serious concern.
To minimize the likelihood of a browser crash (and other system malfunction), you should make sure that:
(1) your browser is up-to-date, and
(2) your operating system has all patches and updates installed.
The current version of Firefox is 3.6.15. It's also good idea to run a full anti-virus scan of your computer periodically, and to do other forms of regular maintenance (disk defragmentation, eliminate temporary & junk files, scan for registry errors).
Feb 11, 2011 | Mozilla Firefox
Hi I am trying to copy a video to dvd on this recorder What dvd disc do i use as after recording says this disc cannot play- would appreciate the exact direction how to do this Tks
The DVD-burner inside the DVDR520H is a very cheap LiteOn-burner (model: DDW451S). It would be better to replace the burner, but it would be difficult to find a product which will fit in the limited space. I'm having troubles with burning DVD's since I had bought this peace of ****. The machine have been repaired three times, but it is still not functioning properly. Shame on Philips for assembling such a weak product and their very bad support!
Sep 19, 2010 | Philips DVDR520H DVD Player/HDD
How to turn on/off browser cookie functionality
Hello
If you're receiving an error message that says, Your browser's cookie functionality is turned off. Please turn it on:
Open Internet Explorer, and click Tools along the top of your browser window.
Select Internet Options... and click the Content tab at the top of the dialogue box. If the Content Advisor is enabled, please disable it.
Click OK.
Next, please clear your browser's cache. To clear your cache in IE:
In Internet Explorer 6.x:
  1. Log out of Gmail. Close all other open browser windows.
  2. Click the Tools menu at the top of your browser, and select Internet Options.
  3. Click the General tab at the top of the dialogue box.
  4. Click Delete Files under Temporary Internet files.
  5. Select Delete all offline content by checking the box.
  6. Click OK.
In Internet Explorer 7:
  1. Log out of Gmail and close all other open browser windows.
  2. Click Tools > Internet Options.
  3. Select the General tab.
  4. Click Delete under Browsing History.
  5. Under Temporary Internet Files, click Delete Files.
  6. Click Delete Cookies.
  7. Click OK.
In Internet Explorer 8:
  2. Click Tools > Delete private browsing history.
  3. Click the box next to 'Temporary Internet files' and 'Cookies.'
  4. Click Delete.
If you still can't sign in, try logging in securely by changing the URL to https://mail.google.com. if(document.getElementById('kb_ie8') != null) showLayer('kb_ie8'); if(document.getElementById('kb_ie8_win') != null) showLayer('kb_ie8_win'); if(document.getElementById('z_ie8') != null) toggleZippy('z_ie8'); if(document.getElementById('z_ie8_win') != null) toggleZippy('z_ie8_win'); if(document.getElementById('kb_ie') != null) showLayer('kb_ie'); if(document.getElementById('kb_ie_win') != null) showLayer('kb_ie_win'); if(document.getElementById('z_ie') != null) toggleZippy('z_ie'); if(document.getElementById('z_ie_win') != null) toggleZippy('z_ie_win'); if(document.getElementById('kb_win')) showLayer('kb_win'); if(document.getElementById('z_win')) toggleZippy('z_win'); if(document.getElementById('kb_winxp')) showLayer('kb_winxp'); if(document.getElementById('z_winxp')) toggleZippy('z_winxp'); if(document.getElementById('kb_NG')) showLayer('kb_NG'); if(document.getElementById('z_NG')) toggleZippy('z_NG'); if(document.getElementById('kb_non_US')) showLayer('kb_non_US'); if(document.getElementById('z_non_US')) toggleZippy('z_non_US');
Thanks
Sep 06, 2010 | Cell Phones
I have a philips DVD home theatre system HTS8100. Its fine except that NO dvds play in synch. I have checked them on my normal DVD player & they are fine. The synch button on the remote sometimes fixes...
Synch problems on Philips machines can be caused by the video output setting.
Usually there are 3 options for video output:
  • PAL
  • NTSC
  • AUTO
PAL & NTSC force playback in that setting, regardless of DVD format, and sometimes cause a time delay in the conversion.
Try changing this option to AUTO. IF you have a modern TV, it should allow both PAL & NTSC playback.
May 12, 2008 | Televison & Video
IBM R40 2681
Here is a link to all the drivers and software you need to put back on your R40 laptop. The one you were asking about is a bit more than halfway down the page, listed under ACPI Power Management. http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=MIGR-46024
Nov 03, 2007 | IBM ThinkPad R40 2722 Notebook
Rolling picture on Philips DVDR 520H
If you are using an American TV, then it's because your DVD player is set to PAL. Set the DVD player to NTSC and all should be good. peace. p.d.
Dec 31, 2006 | Philips DVDR520H DVD Player/HDD
Philips DVDR520H DVD Player/HDD Logo
152 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
