Question about GE Monogram ZFSB23DRSS Stainless Steel Side by Side Refrigerator
Temperature control problems with GE refrigerator
Model ZFSB26DNA SS side by side refrigerator. Have set fresh food temperature selector to 40 but actual temp is at 27. Produce freezes up and ice forms in milk, juices, etc. Cannot get refrigerator to maintain selected temperature. Have not made any inputs to Express Thaw, Express Chill, or Select Temp on Custom Cool panel. In addition, water dispenser is not working even after following all troubleshooting fixes listed in manual.
  • fotogchick Jan 10, 2009
    I have a similar problem. My produce keeps freezing, and water dispenser suddenly will not work. I have been researching on www.applianceblog.com and trying to see if there is anyone else that can solve this.
  • triciasaz Feb 09, 2009
    I have the same problem, along with our ice maker not working. Not sure if the problems are all connected. But I'm getting tired of my produce freezing. I have tried changing the settings but with no luck. Have you been able to find anything out?
fridgetech
  • 473 Answers
SOURCE: Items sometimes freeze on refrigerator side of unit - model GSS25LGMA
It is most likely a bad damper motor.  This is where the cool air comes out into the fridge section.  On this model it is a fairly common problem and comes a whole assembly.  The part # is WR49X10091 and will cost anywhere from $100 to $122.  Knowing this model I would bet this is your problem.  If the damper is bad and stuck open cold air will just keep blowing in.  It is suppose to open and close based on the temp setting.  Let me know if you have any other questions.
Posted on Oct 11, 2007
  • 74 Answers
SOURCE: GE Profile fresh food getting TOO cold
Faulty air damper is the usual cause , or possible sensor fault
Posted on Aug 28, 2008
  • 531 Answers
SOURCE: 16 month old GE Profile
see if the back wall inside of freezer have ice if so you have to change tiker board or check your doors if closing
Posted on Mar 31, 2009
  • 47 Answers
SOURCE: GE Profile Side-by-Side Refrigerator gets to too cold
turn the temp setting up to40 then check in a couple of hrs
Posted on Nov 20, 2009
heatman101
  • 43501 Answers
SOURCE: 48" ge monogram refrigerator not staying cold
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
sfjfg
Posted on Sep 29, 2010
HOW DO I ADJUST REFRIGERATOR TEMPERATURE
    1. Refrigerator Adjusting Temperature Controls. At initial startup both fresh food and freezer controls should be set at the normal setting or mid point settings. Temperature controls can be found in the back of the fresh food compartment, near the top of the fresh food compartment, or on the dispenser panel.
      Refrigerator Adjusting Temperature Controls - GE Appliances
      products.geappliances.com/appliance/gea-support-search-content?contentId...
    Feedback
  1. Refrigerator Temperature Control Dial - What Do The ...
    removeandreplace.com/.../refrigerator-temperature-control-dial-what-do-...
    Mar 4, 2015 - The more food you have in your refrigerator, the more stable thetemperature will be. Set the thermostat to the middle of its range and leave it for ...
Nov 28, 2015 | Refrigerators
PSC23NSTESS FREEZING VEGTABLES
Side by Side ModelsIf foods, such as fruits and vegetables, in the refrigerator are freezing, it can be caused by several things. First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenheit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • If food in the bottom of the refrigerator is freezing, this could be caused by a refrigerator not having enough food to absorb the cold air.
  • If food in the door is freezing, move the door bins up or down so they are one notch away from freezer vents (Side by Side models only).
  • The fresh food control should be at the normal setting of 5.
Freezer on Top Models
First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenehit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • Since the cold air coming into the fresh food section originates in the freezer above, the rear of the top shelf will be the coldest spot in the fresh food area. Avoid placing delicate items that freeze easily on the back half of this shelf.
  • If food is freezing in the produce (fruits and vegetables) or meat pan, it may be that the temperature controls are not set high enough. Since cold air naturally falls, the pans can get too cold if the refrigerator is not running long enough to maintain good air circulation. Adjust both controls up one notch.
Nov 01, 2012 | GE CustomStyle PSC23NSTSS Stainless Steel...
GE ZIS420NX Refrigerator temp control not effective, food is freezing
you have a few things that could be wrong, a bad thermistor, a bad air defuser, or a bad main board. changing the thermistor could fix it but if not, i would call a pro that order the right part. lots of varibles.
Apr 08, 2012 | General Electric GE ZIS420NX (25.4 cu....
Fresh food side is running too cold (Liquids freezing), regardless of temperature control settings. G E Model GSS20IETE
There is a vent opening on the bottom or in the back. Make sure it is not one sided or blocked with items since the temperature settings make no difference. This is all it can be.
Jan 02, 2011 | GE Refrigerators
Refrigerator is too cold (28 degrees)
this is likely one of the thermistors on the fresh food side has failed. They are usually located under a small cover inside the fridge. They should have a reading of 15.5k-16.5k ohms at 72 degrees. They are easy to check and replace. Here is a link that should help. You can also enter your model # for diagrams and illustrations of your specific model. http://appliancehelponline.com/sxsfreshthermistor.html
Jul 16, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Temperature does not go below 59 deg. refrigerator side.
Auto Damper models, The Auto Damper model refrigerator has
two controls and both have capillary sensing.
The Auto Damper controls the fresh
food temperature and the Freezer Temperature
Control guides the freezer temperature.
The fresh food compartment temperature
is maintained by a damper assembly located
at the back of the temperature control
housing. Changes in air temperature
cause the damper door to open and close.
A control rod and gear connect the fresh
food control knob to the damper control.
Turning the fresh food control knob to the
COLDEST position increases the flow of
freezer air into the fresh food section. The
freezer compartment temperature control
warms at a faster rate and cools at a slower
rate, increasing the compressor run time
necessary to maintain a satisfied freezer
temperature control.
Turning the fresh food control knob to a
WARMER setting decreases the flow of
chilled air into the fresh food section. The
warms at a slower rate and cools at a faster
rate, decreasing the compressor run time
It is ver possible that the auto damper has failed and will need to be cosidered as a likely cause. Part Number Click here=> 61005971 or 1005641 Auto damper control assembly here is the Service manual=> MSD2756G Instructions can be foun on pages 38 and 39 in your manual.If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, www.pcappliancerepair.com
Feb 28, 2010 | Maytag MSD2756G Side by Side Refrigerator
Side-by-Side: Refrigerator will not maintain temp below 50 Deg. Freezer works fine - where is the problem? Model Number MSD2757AE
Your problem may be with:
* the "damper control assembly", which is located in the upper left side of the fresh food compartment. This control regulates the amount of cold air originating from the freezer compartment that enters the fresh food compartment.
* there may be an issue with the "fresh food temperature control assembly"
Check the temperature settings in the fresh food compartment (should be located up front). I recommend the "one-half way mark" for both freezer and fresh food compartments.
Contact an appliance service company.
Feb 19, 2010 | Refrigerators
Erratic temperature control. Freezer temperature varies from -4 to +2 even though set to -1, refrigerator also with wide variation. refrigerator is about 2.5 years old and this is a new problem.
Unles this is a big change and is not affecting the fresh food sect temperatures.Those should be 38 degrees for food safety. As far as the temperatures measurements those are easily altered by placing articles of packages near the thermistors in freezer and fresh food compartment. There are many issues you need to consider with the model refrigerator Artic/Profile. They are very sensitive to power surge and simple failures. Hopefully your being only 2.5 years out GE has resolved the problems of the past.GE is a good company and they do support their customers through the 5 year sealed system replacement. There are very many models of your type. Could you send me the model number listed for example PSS26MRSS. If you could I will get you some information that can help you save you repair cost in the end, Now if there is a problem with the thermistors we will need to resolve that because it will cause more problems later. Thanks Sea Breeze
Nov 10, 2009 | GE Profile¿ Arctica® Energy...
Fresh food side too warm
Refrigerator nguyen@ite.net 40 F or lower is the recommended refrigerator temperature to slow bacterial growth and maintain quality. Freezing occurs at 32 F; adjust refrigerator accordingly between 32 F and 40 F to prevent unwanted freezing, such as freezing milk.
http://lancaster.unl.edu/food/ciq-fridge-freezer-thermometer.shtml
Jun 09, 2009 | GE GSS25JFM Side by Side Refrigerator
Water freezing at bottom of refrigerator/Temperature not right
thats a water tank holding water dfor the dispensor, if everything in refrig is freezing quite possible that the water in tank froze as well, which would explain no water,
Feb 24, 2008 | GE PSS26NSWSS Profile 25.5 Cu. Ft....
GE Monogram ZFSB23DRSS Stainless Steel Side by Side Refrigerator Logo
797 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
