Question about Whirlpool Duet GHW9150P Front Load Washer
HELP. i have a whirlpool front load washer and it keeps stopping during the cycle and shows like 02 remianing minutes. i then hit the pause button and it restarts with like 20 minutes left or some other number. it ends up taking hours to wash a load of laundry cause if have to keep pressing pause and restart till it narrows down to the end of the cycle. i tried to unplugg it and it didn't help either.thanks lauri
Hoe do i fix this? thanks
Posted on Dec 10, 2008
  • 3 Answers
Http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
follow the instructions here
Good Luck
Posted on Dec 09, 2008
My washer will run for a short time and them stop and just beep repeatidly
Frigidaire washer beeps for no reason, driving us crazy ...
? 1:03
https://www.youtube.com/watch?v=gP51k2bhbbg
Nov 6, 2011 - Uploaded by NatalieJonathan
Our Frigidaire washer keeps giving us ridiculous beeping issues, and for no reason. ... Mine stack dryer above ...
My washer pauses during wash cycle and will not restart ...
www.shopyourway.com > Manage My Life > Questions
The washer will stop during wash cycle and just beep. Sometimes we can turn it off and it will run again. Getting worse ... My washer is a Whirlpool 3.5 cu. ft.
FIXED Whirlpool Duet Washer Stops and Beeps - ApplianceBlog
www.applianceblog.com/.../48786-Whirlpool-Duet-Washer-Stops-and-B...
Jan 16, 2015 - 6 posts - ‎2 authors
It's a front loading Whirlpool Duet Washer 4.0 cu ft, with Tumblefresh ... wet it stopswashing and starts beeping (three beeps, pause, three beeps, pause, etc). ... The clip that holds them into the CCU (I think that's the right term) has a ... with my fingers so I could get a couple loads of laundry done until I can .
Jan 05, 2016 | Washing Machines
I pressed the pause button to add a garment to my Whirlpool frontload washer. After doing so, I pressed the hold to start button, but the washer would not restart the cycle.
Switch the power off from the power outlet for a few minutes , then switch on and reset the wash cycle . Front loaders are not designed to add clothes mid wash.
Mar 18, 2015 | Whirlpool Washing Machines
I need help with my Duet washer
it sounds like an electronic problem with the board.
Nov 07, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Stopped in middle of cycle with F2 fault flashing on timer screen
F-2 Long Drain
If the drain time exceeds eight minutes, the water valves are turned off
and "F/02" is flashed. Press PAUSE/CANCEL two times to clear the
display.
These videos show what to do
More repair photos and a service manual with error codes and component ID are here
Feb 06, 2011 | Whirlpool GHW9250M Front Load Washer
During wash cycle the washer stops at 11 or 12 minutes left and screen reads F . i have a frontload whirlpool duet HT
Just F on its own?
Try to clear it doing the following:
Select PAUSE/CANCEL twice to cancel the cycle. Select
DRAIN/SPIN if there is excessive water in the washer.
Re-select cycle and select HOLD TO START. If the problem
remains, call for service.
Hope this helps comment back if you need further help,
Jul 06, 2010 | Whirlpool Duet GHW9150P Front Load Washer
We have a front load washer that I just started a load with, went back to check on it and found the power off, the door still locked and it flashing ''F 20'' while it is sucking out suds..any help!!
clean your filter out on the bottom of the washer... take off the front panel which has 3 t20 screws holding it on and than remove the filter which is right in front, you can do this by hand... clean that out, put it back in than hit the pause/clear button twice than start a new load than hit the pause/cancel button again to stop that cycle and unlock the door
Dec 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Have error code f 02 showing up on my Duet fronload washer, during rinse and spin cycle
F/02
DURéE EXCESSIVE DE LA VIDANGE
and “F/02” is flashed. Press PAUSE/CANCEL two times to clear the
display.
NOTE: After four minutes the “Sud” error will be displayed, then four
minutes later the “F/02” error code will be displayed.
Si la durée de l’opération de vidange est de plus de huit minutes, le système commande
la fermeture des électrovannes et l’affichage du code “F/02” clignotant. Appuyer deux
fois sur la touche PAUSE/CANCEL pour commander l’effacement.
NOTE : Après quatre minutes le code d’erreur “Sud” sera affiché; quatre minutes plus
tard le code “F/02” sera affiché.
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and
make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Nov 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Duet washer stopped during wash cycle.
take off the panel below the door three screws and look for the tech sheet located on the right side. It will coach yoou thru the codes and common problems. Sounds like it may be the door swithch does it lock when you push the start? If not the door switch my guess would be a machine control. 877-262-1479 parts.
May 30, 2009 | Maytag EPIC MFW9700S Front Load Washer
WASHER KEEPS STOPPING DURING CYCLE need to pause and restart x's
i would remove hte bottom access panel (3 screws across the lower front) o fmachine. form there you will gain acess to the "button trap" its a clean out for the pump assembly, sounds as if there is a something clogging the drain there fore preventing washer form high speed spin. beaware when the plug is removed there will be a bunch of water behind so be prepared with some towells, ( i use a kitchen plastic bag to collect water and any other gunk that may come through
Dec 09, 2008 | Whirlpool Duet GHW9150P Front Load Washer
WASHER KEEPS STOPPING DURING CYCLE AND DOOR STAYS LOCKED
Try this I had the same problem and it fixed it when the washer stops it will flash a code I got F 02 but this is really easy and need to be done I wish I had known about it sooner
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
Whirlpool Duet GHW9150P Front Load Washer Logo
182 people viewed this question
Dan Webster
Dan Webster
Sal De
