Question about Lexmark X5150 All-In-One InkJet Printer
Hardware error code 0502
This is on my Lexmark X5150 injet printer, could you tell me what this actuall y means. Thanks Larry
  • Anonymous Dec 12, 2008
  • 4 Answers
You have to use oil (olive oil) or petroleum jelly and wipe, using a paper towel, the horizontal silver bar that the cartridge carriage rides across. The ink builds up on this, making it difficult for the carriage to slide across. This works for me every time, and you'll notice a lot of ink on your paper towel!
Posted on Jan 16, 2009
  • Lexmark Master
  • 4,338 Answers
Hardware Error 0502 on LCD Display
Check the encoder strip on the printer. (This is a clear strip running the length of the printer, above or behind the cartridge carrier.) Do the following:
1. Switch off the printer using the power button.
2. Disconnect the power cable from the back of the Lexmark X5100 / X6100 Series.
3. Leave the power cable disconnected for 30 seconds.
4. Slide the cartridge carrier to the middle of the printer by taking the top part of the belt and moving it gently to the right.
5. Take out both cartridges.
6. Place an index finger on the encoder strip on either side of the cartridge carrier.
7. On the back of the cartridge carrier, there is a small slot that the encoder strip fits into. Slightly push the encoder strip down and then back up to get it into the slot.
8. Lightly press the strip first to the rear and then forward, if necessary.
9. Clean the encoder strip with a dry tissue. Also clean the contacts of the printer.
10. Reconnect the power cable and switch the printer on again.
11. Perform the hardware test without cartridges first and then with both cartridges.*
12. Make a standalone copy.
13. If the copy is satisfactory, repeat the test once to confirm that the error is gone.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Dec 09, 2008
  • JDTec
    JDTec Dec 09, 2008
    How to Perform the Hardware Test on the Lexmark X5150
    Using the operator panel on the printer:
    1. Press the Option button 10 times until Cartridges appears on the LED display.
    2. Press the + button 4 times until Self test appears on the LED Display.
    3. Press Select. The printer should print a sheet of paper with one black bar and one grey bar.
    4. If the printer fails to print, remove both cartridges and try the test again. (It will feed the paper through and print a blank page.)
    5. If the test works with no cartridges in the printer, run it again with one cartridge at a time installed.
  • JDTec
    JDTec Dec 09, 2008
    Also, clean the rollers the best you can.
Lexmark 5150 has stopped printing. press print and get error code0502 how do I fix the problem
The 0502 error code can be caused by either faulty cartridge or a dislodged encoder strip (transparent strip) in the cartridge area. Refer to this article in the Lexmark website on Error 0502 on the Lexmark X5130/X5150/X5190 Pro LCD Display. This will help you determine and resolve the problem. Thanks.
Feb 16, 2011 | Lexmark X5150 All-In-One InkJet Printer
Printer error 0502
The 0502 error code could be caused by an unseated encoder strip or a faulty cartridge. Please refer to this article Error 0502 on the Lexmark X5130/X5150/X5190 Pro LCD Display for the troubleshooting steps. Let me know if you need further assistance. You can also contact Lexmark technical support for additional assistance. Thanks.
Nov 11, 2010 | Lexmark X5150 All-In-One InkJet Printer
Printing stops and gives error code
The error is caused by either the cartridges or the encoder strip. Here's a link to the Lexmark website to guide you on what to do. Just click on this link: http://bit.ly/affECc .
Mar 31, 2010 | Lexmark X5150 All-In-One InkJet Printer
Hardware error 0502
Follow the instructions on this Lexmark link to fix error:
http://support.lexmark.com/perl/support/support.cgi?ccs=229:1:0:133:0:0&docid=ENUS16536
Click on this link or copy and paste the complete link into your browser.
Thanks, Joe
Mar 01, 2009 | Lexmark X5150 All-In-One InkJet Printer
Lexmarx X5150
see on this site. I had the same problem before 15 minutes and it helps :)
http://blog.forret.com/2006/02/lexmark-printers-with-hardware-error-0502/
Feb 15, 2009 | Lexmark X5150 All-In-One InkJet Printer
Hardware error : 0502
  2. Disconnect the power cable from the back of the Lexmark X5150.
  4. Reconnect the power cable and switch the printer on again.
  5. When the printer powers up, you will need to select the desired settings.
Jan 29, 2009 | Lexmark X5150 All-In-One InkJet Printer
Lexmar X5150 Printer whit Hardware error 0502, can you Help Me?
http://search.lexmark.com/printer/US/en/17K0000
Download and install updated drivers from this link. If you need a walk through e-mail me your number and I will help you if you rate this fixya. Geokohler@gmail.com
George
Jul 14, 2008 | Lexmark X5150 All-In-One InkJet Printer
Hardware Error 0502 displaying on the LCD of my Lexmark X5150
The 0502 error can have any of four possible causes:
- A faulty black/photo cartridge
- A faulty color photo cartridge
- A dirty encoder strip
- The encoder strip being out of position
There is a very good walkthrough on resolving these issues:
http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:133:0:0&framed=&docid=ENUS22800&relevance=1
May 26, 2008 | Lexmark X5150 All-In-One InkJet Printer
Lexmark X5150 All-In-One InkJet Printer Logo
134 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
