Question about Dynasty DGRSC 60-6G Gas Kitchen Range
Explosion in heating chamber when oven is lit.
Dynasty DGRC 60-7GV The burner unit is a "U".the ggas enters one of the unit flows all around to the other end of the "U." By the time the gas is ignited the burning chamber is partially filled with gas and there is an explosion. The igniter should be at the other end of the "U."
    Habit-Forming:
  • 171 Answers
The air adjustment is open just a little to much the flame will have a hard time to go to the other side, try closing the vent to the burner just a Little bit and try the oven,another problem that i see is that the ignitor is getting to weak to ignite the flame on time.
Posted on Dec 10, 2008
Oven often takes half hour to heat up
it is the problem with your gas supply jet.
well the jet could be blocked
check the gas jet and open it with a pin or needle
Feb 01, 2008 | Dynasty DGRSC 30 Gas Kitchen Range
This just happened over night the oven is on but there is a bad gas smell when it is in use. There is a hissing noise too.this oven runs on propane
When the burner is burning, are both sides of the burner lit and is it lit all the way down the burner? If it is and you are still smelling gas you should not use the oven until you have it serviced, so you do not have an explosion. Propane is heavier than air, and will settle in low areas, so smell low by the floor around the oven before you light it to make sure you don't have a leak first. To be safe until then, close the shutoff valve on the gas line at the appliance until you get it looked at and fixed. Douglas
Jul 02, 2010 | Ovens
Dynasty oven fails to get enough gas to light.
I think you are talking about the oven safety valve or thermal valve. before you change you oven safety valve, I would check the Amperage on the oven ignitor first, install AMP meter on one of the ignitor wire, it should draw above 3AMPs, if not then you have problem with the oven ignitor and not the safety valve. we hardly change the safety valve, I'll try to change the ignitor first. Have fun.
Mar 28, 2009 | Dynasty DGRSC 30 Gas Kitchen Range
Oven burner
try ajmadison partsquik. com   enter the model number, its on there and available for about $140
Nov 26, 2008 | Dynasty DGRSC 30 Gas Kitchen Range
Dynasty range, oven does not heat up enough
30 inch oven has only one oven tube, 36 inch oven has 2 burners in it, most comment is the oven ignitor is out. If you have 2 burners, I'll change both oven ignitor at the same time, because they worked together. also check the oven tube, if it is corroded at the ignitor area, change the burners. Have fun.
Mar 22, 2008 | Dynasty DGRSC 30 Gas Kitchen Range
Oven
Sounds like you have a Natural GAS unit that is Connected to LP Gas you will need to convert it
Nov 12, 2007 | Tappan TGF320 Gas Kitchen Range
Toyostove Laser 56 (F type) making loud humming noise
the toyostove is basically a glorified monitor heater.  its components are a combustion blower, an air circulator fan, a flame pot, a flat wick or burner mat, a solenoid pump, an ignition element, double  walled intake, exhaust pipe.   the combustion blower is a glorified vacuum cleaner motor. it sucks in cool air and channels it to the combustion chamber along the sides (round cylinder) kero enters on the burner mat where it ignites. the solenoid pump keeps adding kero until the flame detector spots or heats up. air flow to the pot is regulated by a damper in the combustion air blower line. if the "O" ring in the damper is missing or hardened it will not regulate the air flow which is necessary for combustion.  replace this "O" ring should take care of your problem.
Oct 17, 2007 | Rinnai Toyostove Direct Vent Heater:...
Oven Blows Igniters
sounds like you have a short somewhere. you may need an expert.
Feb 02, 2007 | Dynasty DGRSC 48-4GCB Gas Kitchen Range
Dynasty DGRSC 60-6G Gas Kitchen Range Logo
174 people viewed this question
Top Dynasty Kitchen Ranges Experts
Ismael Rodriguez...
Sal DeAngelo
Are you a Dynasty Kitchen Range Expert? Answer questions, earn points and help others
