Mitsubishi WS-55809 55" Rear Projection Television Logo
Posted on Dec 09, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
True HD1080 no hdmi connection. how do i get true hd1080 picture with this tv. thanks.?
Anonymous
Level 2:
Sergeant:
  • Expert 233 Answers
  • Posted on Dec 21, 2008
Anonymous
Expert
Level 2:
Sergeant:
Answers
233
Questions
6
Helped
104319
Points
555
You can use the DVI connection, or the digital HD rca connections on the back. You can also get a dvi to hdmi converter plug.
I have a mitsubishi HD1080 series TV and wanted to know how do I plug in a dvd player. Then how do I get it to play.
Connect an HDMI cable from the DVD's HDMI port to an unused HDMI port on the TV. Select the input from the settings menu and name it DVD or select the DVD name. Turn the DVD player ON. Using the input select button on the remote, select the HDMI DVD input. Wait a few seconds while the TV and DVD player establish a connection. The DVD player menu should appear. Insert a DVD and enjoy a movie. Hope this helps. Regards.
What channel does my hd1080 tv have to be on to work with my dvd player ?
Not on a channel, but an input number. when you connect the dvd player with hi def cables or an HDMI cable look at what input nimber it's connected to. Then select input button on the remote and choose the same number you saw on the back of the TV.
How do get the tv to work with my dvd player
You should be able to just connect the set via an HDMI cable to your DVD player for it to play. You then will have to select using the TV remote the HDMI connection the DVD is connected to.
I do not believe the TV will switch to the DVD player automatically when connected via HDMI. My TV doesn't, though it's not the same as yours.
Why can't I receive in HD? i have the hd1080
Your set will only convert to 480p. There is no way a conventional crt based tv will get 1080p. The proper connections will be using the RGB component inputs on the jack panel ( red,grn,blue ) then the white and red for audio. The picture will be a lot better than standard cable but not as good as HD. ( 720p )
1helpful
4answers
Does this TV have a more than one HDMI in port.
My WS 55311 HD1080 series has hd obviously but i cant fiund any hdmi ports...
Picture on the mitsubishi HD1080 VS-50111
Nope, But your convergenjce chip is about to die. i would turn it off and leave it off and call a tech to rectify it before it takes out the whole board or all 3 as some capacitors are also overheating. Parts $100+Labour of about 1.5 hrs at this stage! later it will be $600
Please rate my help++++Thanks for using FIXYA
Where does the HDMI cable plug into Hitachi HD1080 TV other than front?
Here is a Picture Diagram for you, This shows where your HDMI etc are all located.
http://www.hitachi-homeelectronics.us/supportingdocs/forhome/ubcg/plasma_tvs/P50H401.pdf
Hope this Helps you out.
If this Does then please Leave a Thumbs up
Cheers
Little Dish Fitter
Mitsubishi HD1080
I will need to know your model number in orderto help you locate a PC board for it.
Mitsubishi HD1080 60in TV
First do a self test diagnosis. you can search Mits tv or read my solutions.
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
