Question about HP Office Equipment & Supplies
I have an HP 4570c Scanjet that suddenly started scanning images distored with a blue yellow tint and streaks running through the page. I have tried all the "homing" fixes (shut down everything, unplug for at least a minute, hook everything back up and reboot) downloaded and upgraded all drivers available, made sure there were no monitors or speakers within three feet and about 5 other remedies. Nothing has worked. I believe with the suddeness of the failure, it almost has to be a part. Could a failing lamp cause these symptoms or would there just be no image at all? A mother board problem? It is defeinitely a problem with the scanner which strangely enough, all diagnositics I've used on it say it's "functioning properly". TIA.
  • spamsickle May 24, 2009
    Same problem here, with HP 3200 series Photosmart. I can sometimes make the problem go away by unplugging the scanner/printer for a minute and starting fresh. If I do, the next series of scans will be fine, (I typically scan several pages of documents in a batch), but if I start a new scan (click on "Scan Document" button in Photosmart software), and the yellow streaks show up, every scan in that batch will show the same streaks.
    For now, I'm just continuing to unplug & reboot until it comes up clean. It's not "dirty glass" or anything to do with print. It might be illumination (unlikely, since I think it's a single bulb illuminating everything) or sensors on the scanner. Could also be a failing component on a board, since I can sometimes recycle my way out of it. At the risk of stating the obvious (it isn't obvious to me), asking for a greyscale scan instead of a color scan avoids the problem, which is okay for many of my documents. I'm out of warranty, and if the problem goes from intermittent to solid, I'll just use the printer for printing until the ink runs out, and try another vendor's solution pack.
This is driving me nuts, too on my HP d135 multifunction. I hate to give up a working (albeit old) printer/copier/fax because the color scanning goes, but I haven't room for a separate scanner.
Would love to know the fix for this.
Posted on Nov 20, 2009
HP ScanJet 4670 - yellow lines or streaks in scans
You have a dirty glass. Take a lint free cloth and water and wipe the glass making sure you leave no streaks behind. Sometimes you have to take a flashlight and examine the glass. Just a little spec, the laser will drag all the way down.
Aug 30, 2017 | HP ScanJet 4670 Flatbed Scanner
Trying to connect to an HP Scanjet 4570c to a Dell Inspiron 1750 notebook computer. When I connected the USB cable, it said it updated some drivers, but there is no icon on the laptop to scan, and when I...
If you are under Windows 7 , it's because HP doesn't produce anymore drivers for your unit beyond VISTA .
Download the latest driver available from here : http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&lang=en&product=77368&
and try running your scanner with it . If you don't succeed , try in compatibility mode .
If it still doesn't work please don't blame me , blame HP .
Best regards .
Feb 01, 2011 | HP 4570C Flatbed Scanner
Yellow streak through color image scan
http://www.carlmcmillan.com/CanonScanner/Canon.htm
Feb 25, 2009 | Canon CanoScan 8400F Flatbed Scanner
Faulty scanned images
Pls check your color Scan settings. Generally there will be some color difference between the original and scanned Image because, the original is 'reflected light' whereas, the scanned image is a 'source light' on the monitor. The monitor setting can also affect the color output. S. Mohan
Jan 28, 2009 | HP ScanJet 2400 Flatbed Scanner
Hi, My HP 4570C scanjet has an intermittent problem - during scans, the light bar will stop/jam at an arbitrary spot in the cycle. My guess is that the problem may indicate the need for lubrication on a...
Posted by Lonu Feruz,
I have HP scanjet but unfortunately i dont have the driver CD and it is not written anywhere to show HP scan model except this number C7710A. Which driver works on type of scanjet using windows XP
Jan 04, 2009 | HP 4570C Flatbed Scanner
Hp scanjet2300c scans have a yellow tint and black patches.
The best way to check if the scanner is okay or not is by installing on another computer. First try B&W, then try color. IF it works may be your OS or driver (of the old comp) is corrupted.
S. Mohan
Dec 22, 2008 | HP ScanJet 2300C Flatbed Scanner
Scanner Printing Yellow Background (Macintosh)
Same problem as above with my HP scanjet 2400.
Dec 28, 2007 | HP ScanJet 2400 Flatbed Scanner
No picture image when scanning
This looks like a CCD failure. Can the image be corrected in the PC software Which image editor are you using?
Jun 14, 2007 | HP Scanjet 5500c Flatbed Scanner
112 people viewed this question
Seeker5211
Seeker5211
