I'm looking for assistance with troubleshooting a Goodman GMP100-4 Series furnace. I'm unable to find a local service company that know how to troubleshoot the problem.
  • 85 Answers
I hope I can help, what is the problem?
Posted on Dec 09, 2008
Goodman gmh95
Sounds like the door is open, or there's no power to it. Make sure the furnace door is closed (door switch) and the breaker, disconnect are all on.
Dec 16, 2013 | Heating & Cooling
I have a GDS80703AXBA furnace by goodman but furnace wont ignite
Here is a tip that will help you try to figure out why your furnace is notworking.
BasicFurnace or Heating System Troubleshooting
Sep 28, 2011 | Goodman GMS90703BXA Heater
Goodman air conditioner not starting
Hello my name is Heath it will be my pleasure to assist you. First thing to do is go to the furnace take off the lower blower door and locate the circuit board turn the power off to the furnace. In the circuit board there should ba a small car like fuse usually 3 or 5 amps check the fuse it is probably blown replace the fuse with the same amperage fuse and then turn the power back on on the furnace and check the operation of the furnace.
Sep 04, 2011 | Goodman CKL42AR42 Air Conditioner
What happen when your hvac blows cold air and the heat is set at 73
Sounds like you have a thermostat problem. If your thermostat is not triggering the furnace to ON/HEAT you will not the heat you desire. IF you know how to trigger the furnace you could jump your furnace controller wires BUT DON'T do this. Instead, get another thermostat and try it. But be sure to get the same rated thermostat... take it with you when looking for a replacement.
Not sure about everything going on with your unit based upon what you provided but your thermostat should show the current temp and the temp you set. It also show the mode that the thermostat is in (HEAT / COOL / AUTO) Manually select heat, then increase temp above the current temp setting. listen for furnace to activate or wait a few minutes for warm air output. If not, you'll have to see assistance trom a local heating and cooling company.
Mar 09, 2011 | Goodman Heating & Cooling
Goodman dependable 92,7years old. Furnace works sometimes. Checked out by qualified technican. no problem found. Constant checks shows troubleshooting light blinks three (3) times. Help please. 3...
This indicates a open limit switch on the furnace, the heat exchanger is getting to hot therefore the limit switch is opening and not allowing the furnace to work properly. Did the techinician check the limit switch on the unit?
Dec 30, 2010 | Goodman GMS90703BXA Heater
Goodman furnace ignitor works, blower starts up but no flame, no heat ignitor glows then everything stops
sounds more like a pressure switch problem. If the pressure switch does not make, then the furnace will not attempt to light. Its a safety feature on residential furnaces.
Check the pressure switch and hose for obstructions. Clear any and attempt to re-light. If still not successful, its time to contact a local service company to check the gas valves and electronics.
Apr 27, 2010 | Goodman GMS90703BXA Heater
Need to know proper venting for downflow goodman furnace
Jerry, begin by contacting your gas company. Generally they have a free service whereby they send out a techie to check your system out and answer questions for you.
Mar 29, 2009 | Goodman GMS90703BXA Heater
Heater problems
That pressure switch closes for a run condition. check for continuity between the plugs on it with the induction fan running. If its closed, change the board if not change the switch.
The switch will tell you its pressure rating on the label and its best to just use the same rating. Easiest to get it from a Goodman Parts Supplier. You can order it on the internet, should have a part number on the label or just use the model and serial of the furnace. Locally you will probably have to buy it from someone in the trade.
Nov 09, 2008 | Goodman GDS80904BNA Open Flame Heater
Goodman gas furnace power vent motor and housing replacement
You need to type GOODMAN GAS APPLIANCES into you browser to find you local servicecenter. I must tell you that Goodman only sells to authorized service companies in my experience. So you become EgKraft Company.
Nov 07, 2008 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
144 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
