Question about Sprint Hitachi P300 Cellular Phone
TV SHUTS OFF RANDONLY
I HAVE A HITACHI 57 INCH PROJECTION TV MODEL 57XWX20B AND JUST RECENTLY THE TV WILL RANDOMLY SHUT OFF AND I CANNOT TURN IT BACK ON UNTIL I UNPLUG THE TV AND PLUG IT BACK IN, I WILL HAVE TO DO THIS SEVERAL TIMES IN A ROW AND SOMETIMES WILL HAVE TO LET IT SIT FOR AWILE, THEN IT WILL WORK AGAIN FOR AWHILE SOMETIMES DAYS THEN IT WILL REOCCUR, ANY SUGGESTIONS?
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, pls determine if all the 5 diagnostic LED's as well as the front panel LED are lit and not flashing.
  • If yes, then pls check the inside of the TV with special attention to disconnected or loose connectors/plugs. You may want to start on the vertical yoke of any of the CRTs.
  • If no, pls post back the LED blink/lit codes.
Good luck and Thank you for using FixYa. Happy Holidays.
Posted on Dec 09, 2008
  • Louie  Role
    Louie Role Dec 12, 2008
    Hi again,
    Any updates or developments so far?
    Genius:
  • 1,550 Answers
The protection circuit is cutting in and out and it is really just a high current detection system.
This is very typical of loose connections and cold solder joints which are easily diagnosed by giving the set a whack with your hand in a few strategic places.
Tops would be dried out thermal compound on the VOT and HOT (Vertical and Horizontal Output Transistors)
    Genius:
  • 1,199 Answers
This sounds like a power source problem...it may be your flyback or your transformer!
  • 4,806 Answers
Is this a phone or a TV as your post doen't give any definate description
regards
We have a Hitachi 57XWX20B Rear Projection TV. We moved this week and now the TV picture is very dark. We have tried the magic focus and adjusted the brightness, yet the picture is still very dark. Any...
one of two things on this model==clean the lens on top of the chassis--the round large black ones.
Second: there is a resistor in the power supply that changes value and will cause this----also with set unplugged and back off since set was moved carefully look for any plugs not fully seated etc.
Apr 10, 2012 | Hitachi Director's Series 57XWX20B 57"...
Tip
Hitiachi Convergence Circuit Resistor Values
This site has been very helpful in diagnosing and repairing my Hitachi 57XWX20B. I recently changed the IC's and a resistor to fixe a convergence problem and had to use the small button on the convergence circuit to get set to return from static mode and enter dynamic mode. I searched everywhere trying to locate the correct resistor values and noticed many other's needing the same information. Here are the results of my research. I obtained some from manuals and others from comparison of the different models. My main focus was finding the values for the 57XWX20B. The resistor values are given in ohms at 1 watt. This means RK42 is a 3.3 OHM 1 watt resistor. RK58 was the problem in my set. It was giving a value of 2.3 and needed to be 4.7. I first replaced the IC's and thought the resistors were all good, but I later noticed my convergence was off. I could manually align it but the magic focus initiation would not save. It gave an overflow error. I bought the sanyo brand of IC's, not the cheap inports and found that if you use a desoldering wick then the repair is easy. The new IC's restored the beautiful color the set had when new. Now it is brilliant as well as converged. My repair cost was:
STK-110 13.00 Bought from local electronic supplier
STK-150 15.00
RK58 3.00 Bought from a local TV repair shop
The elecronic supply store gave me 6 inches of desouldering wick
Total cost: 31.00 Dollars
51UWX20B DP23
57UWX20B DP23
51GWX20B DP23G
57GWX20B DP23G
43FWX20B DP24
51XWX20B DP23
57XWX20B DP23
51SWX20B DP27
57SWX20B DP27
65SWX20B DP27
57TWX20B DP27D
65TWX20B DP27D
DP 23 DP 24 DP 27 RK42 3.3 3.3 3.9 RK46 2.2 1.8 1.8 RK50 2.7 3.3 2.7 RK54 1.8 1.8 1.8 RK58 4.7 4.7 4.7 RK62 2.7 2.2 2.2
on Apr 02, 2008 | Hitachi 57SWX20B 57" Rear Projection...
I have a Hitachi 57" projection TV Model 57F510.
You may well have either poor contact on the tube base of the colour that is missing or a poor contact in the tube itself. The latter is not repairable.
Dec 31, 2010 | Hitachi 57F510 57" Rear Projection...
I have a Hitachi Ultravision Projection TV Model 57XWX20B. My TV will not stay on. I tried unplugging it, then plug it back in. It will then click once to turn on; then after 15 seconds it will turn off. ...
The power source detects an overload on one of its exits and shuts down to protect itself. The tv must be opened and tested by a knowledgeable person who can identify and replace the failed part.
Aug 22, 2010 | Hitachi Director's Series 57XWX20B 57"...
The set is a Hitachi Ultravision Digital Model #57XWX20B. The picture "Ghosts" red. When runnung the Magic Focus, it stops on the 5th red line and goes no further. In low light scenes, it blacks out in a...
The Convergence IC's need to be replaced. They are located on the Board to the right, mounted on a large heat sink. They should be replaced with STK392-150's. The original IC's are probably STK392-110's.
The Stk392-150 is a updated replacement. Be sure to use Heat Sink Compound between the IC's and heatsink because these IC's do draw alot of current and heat up alot. Also look for any heat stressed Resisters.
I hope this helps,
Sky Assoc
Feb 07, 2010 | Hitachi Director's Series 57XWX20B 57"...
Hitachi model 57SWX20B , Sound, but no picture
I had similar problem with my 57xwx20b TV as well. I'd unplug it from the wall for at leas 30-40s and plug it back in, the picture would return as normal. It will come back from time to time but the same procedure will reset the video board and the picture will return. I'd also check to make sure that the TV has the latest firmware from Hitachi as well. The FW for the ATSC tuner is upgradeable via the SD card and Hitachi website will give you the procedure. This fix all kind of problem with my TV from blank screen, green screen, flashing screen, pinkish screen because the old FW was built before the final standard. Apparently, it interferes with the video board and causes it to go amock. Good luck.
Jul 28, 2009 | Hitachi 57SWX20B 57" Rear Projection...
I can't find upgrade cards for hitachi 57F59 projection tv
I have a hitachi 57f59a projection tv. I had lighting storm and shut tv off and power was out and when it came back on i turned tv on now my hdmi port on tv doesnt work. any help please
Jun 15, 2009 | Hitachi 57F59 57" HDTV
57 hitachi ultravsion rear proj hdtv :ps3 hdmi issues
TRY ON THE DISPLAY PS3 SETINGS TO NOT LET THE HDMI DO AUTOMATIC,,CHECK OFF A FEW ,,LIKE TRY JUST DION IT CUSTOM,,CHECK 480P,,AND 1080I,,,NOT 720P OR 1080P,,TRY THAT AND IF YOUR TV IS A 1080P,,JUST CHECK THAT,,OR IF ITS A 1080I,,JUST THAT
May 15, 2009 | Hitachi 53FDX01B 53" Rear Projection...
Sprint Hitachi P300 Cellular Phone Logo
81 people viewed this question
Top Sprint Cell Phones Experts
Vernon Taylor
rgnestle
Level 1 Expert
Are you a Sprint Cell Phone Expert? Answer questions, earn points and help others
