Question about Kodak EASYSHARE 5100 All-In-One Printer
My printer will not print black ink.
I have replaced the black ink cartridge. The ink cartridge shows plenty of black ink. I have calibrated the computer and cleaned the head.
  • 1 more comment
  • Anonymous Dec 20, 2008
    I have the same problem. Thought it was a faulty cartridge but I just put a brand new on in and it still didn't work.
    I have the same problem. Just started. I have cleaned the print head several times now and no luck. I am now burning through my color cartridge because of this.
  • Alev Dec 20, 2008
    I have calibrated my printer, reinstalled printer cartridges, cleaned the print heads and bought a new black cartridge, and I can't get my printer to print in black. Frustrating!
I had the same problem & I think it was I had the wrong color on the Copy screen.
Posted on Dec 09, 2008
2 Suggested Answers
  • 1218 Answers
SOURCE: I have an HP color printer. When printing the
Black printer ink in HP Printer may fail to be recognized by the printer. Most times an error message will be sent indicating that something is wrong with the black print cartridge. Sometimes the printer may accept to print with the black ink, but the printouts may have horizontal lines and very illegible letters. In such a case a manual cleaning of the print head should be carried out. In doing the manual cleaning, one should spray Windex heavily on paper towel and wipe off the surface of the print head.
http://en.kioskea.net/forum/affich-40171-printer-not-printing-black
Posted on Nov 11, 2010
ESP 7250 Not printing the gray color on the test page
Not much to go on. If you mean the black cartridge is not giving any ink, and the printer does not say the cartridge is empty you still have a problem. But it is possible to solve.
If I'm guessing right, remove the cartridge with the black ink and look in the printhead. You see the little pipe sticking up, where the black ink is going in. with a dropper, just do a few drops of cleaning fluid on that pipe and replace the cartridge. Than let the printer print some black pages, till the black ink is coming through.
It also could be the cartridge with the black ink is empty or dried. If you shake (take care you will spray ink if you don't seal the ink outlet) and you don't hear any ink in the cartridge, unless what the computer or printer thinks it still is empty.
Jan 25, 2014 | Cameras
When i put on black ink cartridge of HP4200 all in one printer it will turn Error and willnot print but if i remove and leave only the colored ink cartridge it will print sometmes colored sometimes black
1. Mono cartridge faulty, replace it
2. Color cartridge dried up/nozzles are blocked..Perform nozzle clean.. after cleaning also not satisfied, replace it..
** Suggestion: If you replace both cartridges at a time calibration and print quality reaches 100%..better go for replace both..
Oct 08, 2012 | HP LaserJet 4200 Printer
Printhead for office hero 6.1
I replaced black ink cartridge and now no matter how many times I clean/calibrate only the black ink messes up. I tried other brand new cartridges and same thing. Even a calibrate shows missed lines or faded lines
Jul 07, 2012 | Kodak Office Hero 6.1 All-in-One WiFi...
I have an HP color printer. When printing the black does not print well even though it shows that the black print cartridge has plenty of ink in it. Is there a way of: 1. Diagnosing if it is the print...
Nov 11, 2010 | HP Deskjet F340 All-In-One Printer
Printer not printing photos with all colors
  1. Lift the printer access door, then remove the ink cartridges from the printhead.
  2. Verify that the label on the ink cartridges is intact, and that the cartridges are not damaged.
  3. Verify that the KODAK Ink Cartridges have not been refilled.
  4. Insert the ink cartridges into the printhead, then press down firmly until you hear them click into position.
  5. Close the printer access door.
  6. Check the printer status monitor on your computer (or the LCD screen on the printer) to determine if there is sufficient ink available for your print job.
  7. NOTE: Once the "Black ink cartridge is low" or "Color ink cartridge is low" message is displayed, print quality can be affected.
  8. Reprint the picture or document that had the quality problem
If still same quality then...
  1. Load inkjet paper into the paper tray.
  2. On the control panel, press Menu.
  3. Select Calibrate Printer.
  4. Select Print Calibration Page
  5. Press Start.
  6. When the print is complete, press Cancel to end the calibration process.
  7. Check the six color bars on the printed calibration sheet.
Are the color bars completely filled with solid color?
If no then:
  1. Press Menu.
  2. Select Clean Printhead, then press OK.
  3. Select Deep Clean, then press OK. The On/Off light flashes green during the cleaning procedure.
  4. When the On/Off light glows steady, press OK.
  5. Select Calibrate Printer.
  6. Select Print Calibration Page
  7. Press Start.
  8. When the print is complete, press Cancel to end the calibration process.
  9. When the print is complete, press Cancel to end the calibration process.
  10. Check the six color bars on the printed calibration sheet.
If again No...
then printhead needs replacement... call Technical Support to get it replaced
May 25, 2010 | Kodak EASYSHARE 5300 All-In-One InkJet...
I changed the black ink cartridge and the printer
Calibrate your new blank ink cartridge, have some nozzle check, cleaning check, and printer alignment. This are procedure that new ink cartridge will have to calibrate before you use. Epson printer are very sensitive when capable of changing ink cartridge. Unlink HP directly work without any print test because the cartridge head and ink join together, Epson with ink cartridge and the head separate.
Have some test on it at Printer Maintenance.
I'm sure 100% works on it.
Sep 23, 2009 | Office Equipment & Supplies
Black ink cartridge not empty, but won't print black...
Try running the cleaning tool included with the HP diagnostic software for your model printer. If that doesn't work, try cleaning the ink jets on the black cartridge directly with an alcohol swab. If this still doesn't work and you're sure that you have the correct model HP cartridge installed properly in the printer, you may have to replace the black cartridge with a new one to see if the cartridge itself is defective.
Oct 02, 2017 | HP PhotoSmart C4480 All-in-One Printer ...
Put in new ink and it is telling me out of ink and will not let me print anythings.. How do you reset ink
Simple oly when you know how ;-)
I think you have a slight blockage, to solve:- (dont know which printer or PCyou have so ill do my best)
Click on Start
All programms
Pick your printer from the list
Open the software
You will have 2,3 or 4 options depending on your printer spec.
You need to 1st remove the cartridge
Print 1 page with no INK a message will pop up saying con not print need ink for example.
You then NEED to calibrate your cartridge, you need to find:-
1 Align Cartridge/Nozzle - Unblocks, and Sets up. (Syncronize)
2 Calibrate Black - unblock black
2 Calibrate Colour - unblock colours
3 Print test Page - See how it looks
5 Align again - Unblocks everything giving good ink flow and gets the print right close to 100%
6 print test page!
It shoud now work ;-)
Good Luck xxx
Jul 15, 2009 | Canon Pixma MP480 All-In-One InkJet...
Kodak EASYSHARE 5100 All-In-One Printer Logo
61 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
