Question about LG 37LP1D 37 in. LCD Television
DELL LCD monitor E151FPb turn white
Dears, My DELL LCD monitor E151FPb screen turns white when power on, no other display at all. Can someone help to provide solution. Next, after taken out all screws from the back panel, I have difficulty to open the monitor casing. Does anyone know how to open the back panel ? Where are the plastic catches at the back casing? I am afraid to break the casing and the LCD panel. thanks !
  • Anonymous Dec 11, 2007
    the screen is white when i turn it on and when i switch monitors the new one works.
I also tried re-soldering joint L781 on the main power control board (see Solutions #2 and #7). It worked. My 15 inch Dell flat panel LCD is working again, white screen gone. The solder around the pin did looked different to to the other joints...a very slight gap around the pin as though it wasn't contacting properly. To locate L781, look at the bottom of the PCB (the side with the soldering) with the power plug socket at the edge closest to you. L781 is in the top left quadrant of the board, about 2 inches in from left, 1 inch down from the top. For good measure, I also tried the solution that suggested trimming a millimeter of the end of the two data ribbons that plug into the smaller control board, although I couldn't see anything wrong with the data ribbons. I did this at the same time as resoldering L781 so not sure if it made any difference.
Posted on May 02, 2009
My screen was washing out to white and would end up with checkered lines through it. I tried soldering where i could but quite by accident discovered that one of the ribbons was the cause. Mine was the little ribbon from the control board (The smaller board on the right when the back is off). In my case pushing on the connector brought back the picture. I fixed it by cutting off 1 millimeter from the end with scissors and reconnecting it.
Just check you data ribbons- it's cheap and easy.
Posted on May 07, 2008
Holy cow look at this it worked for me, fixed my white screen in three steps, 3 knuckle knocks on the screen thats all
http://www.pechorin.com/m/2006/07/26/Sony_DSCS40_white_LCD_screen_problem-268493.html
Posted on May 18, 2008
  • knocks May 18, 2008
    holy cow it worked for me try this
    http://www.pechorin.com/m/2006/07/26/Son...
Cold solder joints on the power board, Most likely L781
Posted on May 29, 2007
Well what do ya know! I just saved a couple of $20.00 bills! I had a E151FPB monitor with a solid white screen the solder connections holding the coil L781 where indeed bad you can't see the defect with the ***** eye or even a magnifying glass but I have a hi powered hand held scope viewer and even with that it was difficult to see the bad connections but let me assure you they were there. The monitor is now in use and has a wonderful picture! Thanks yall! and God Bless!
Posted on Feb 26, 2012
  • 49 Answers
Thank you all L781 solder was bad!
Posted on Jul 09, 2010
Same thing here with the white screen and I FIXED IT!!!! Just had to re-solder the L781 joint. Note: It did not look bad to the eye, but there must have been some sort of issue, because I just used some handy dandy solder wick from RadioShack and got it nice and clean, then re-soldered the connection.
Thanks to all of the previous posts about the L781 connection. You are all genius material.
Bow to you Sensei!!
Posted on Apr 16, 2010
Can someone tell me where the heck L781 is? Like take a picture or something? I feel like a blind idiot.
Posted on Jan 28, 2010
Wow, I was skeptical that this could solve my problem, but sure enough, resoldering L781 did the trick. Thanks!
Posted on Mar 25, 2008
I have the Dell E151FPb and when u plug it in u hear this churping sound and does nothing. i heard that by replacing the Q604 which is 2n7000 transistor. now also heard u can substitute it with 2n2222 and use 10k resistor at base.. please email me at ohio_man_26@yahoo.com thank you
Posted on Jan 04, 2008
Mr. L781.  You are simply amazing!  Thanks!
Posted on Oct 22, 2007
If you've installed A knew Video card on A PC which has an integrated one w/o Using the correct jumpers this will occur or if your video card goes out. don't open the back of your monitor you really could get killed, but if you do the plastic snaps are on the sides (2 each) 1/3 of the way up & 1/3 of the way down. A you won't break it.
Posted on Jul 21, 2007
If you need ,pls contact to me .mail :sglvod@hotmail or sawyer88@gmail.com supply LCD screen display panel for HP ipaq,Dopod,O2, Qtek, Imate,HTC,MDA,XDA, Acer,Asus,FS LOOX,Orange SPV,Mio,Dell Axim,Palm Treo,Zire,Cingular, Audiovox,Himalaya,Toshiba,Sony etc. If you don't find your interested LCD models in this list, please feel free to contact us, we'll check if we can supply them, Thank you! Toppoly LCD TD035STEB1:Acer3230/3250, N30/N35/N50, ASUS A620/A620BT, Asus MyPal A716, Holux GPS mile 60, HTC Magician TD035STEB2: O2 XDA II,O2 XDA IIi,Hp iPAQ 3115/ Hp iPAQ 3700, Hp iPAQ 3710/ Hp iPAQ 3715/ Hp iPAQ 3717/ Hp iPAQ rx3115/ Hp iPAQ rx3710/ Hp iPAQ rx3715/ Hp iPAQ rx3717/ Qtek 2020 Qtek 2020i/ Dopod 696 Dopod 696i Dopod 699/ orange SPV M1000 M1500 M2500/ T-Mobile MDA M1500 MDA M2500/ Fujitsu Loox 420 TD035STEB3: HP1717/2110/2410/2750, HP ipaq hx21xx, ipaq 24xx/27xx TD035STEB4: Acer N30/N35/N50 TD035STEC1 TD035STEE1: Loox N560 TD035STED1: Dopod D700( 1st Generation with silver cable ) ,O2 XDA IIs ,O2 XDA III ,Qtek 9090 ,Orange SPV M2000 ,i-Mate PDA 2000 ,Siemens SX66 ,VPA 1620 ,AudioVox PPC 6600 ,Verizon VX6600 ,Sprint 6600 TD035STED2:MP4,PDA TD035STED3: HP iPaq 2490b/ 2790b/ 2795b & Fujitsu Siemens LOOX N500/N520 TD035STED4: ASUS 632 636 A632 A636 TD035STED5: HP iPAQ 1950 ,HP iPAQ 1955 ,HP iPAQ rx1950 ,HP iPAQ rx1955 TD035STED6: PDA TD035STED7: PANDA/HTC P6300/O2 XDA Argon TD028STEB1: Cingular 8100 ,Cingular 8125 ,Cingular 8500 ,Cingular 8525 ,HTC 8125 /TyTN/Hermes/Magician/Wizard/Apache/Prophet/Prodigy, HTC Blueangel/UTStarcomm PPC-6700/VX6700 ,O2 XDA II mini ,O2 XDA mini pro ,O2 XDA Trion ,Orange SPV M3100 ,Qtek S100/S200/9100/9600 ,Dopod 818/818pro/828/838 ,T-Mobile MDA Compact II ,T-Mobile MDA vavio ,T-Mobile MDA smartphone ,T-Mobile MDA Vario II ,i-mate K-Jam ,SPV M500/M600,SPV 5000 ,Sprint PPC 6600 ,Vodafone VPA compact III TD028STEB2: PDA TD028TTEB1:HTC P3300,DOPOD P800/P800w,T-Mobile MDA compact III,O2 Xda orbit,HTC Artemis. TD028TTEB2 TD028SHEB2 TD028TTEC1: Eten X500+,X800 TD028TTEB3(60H00091-00M): HTC Kaiser/TyTn II/P4550 TD028TTEB5(60H00084-00M) TD028TTEB6 TD028TTEA6 TD022DHEA1 TD022SREC6 TD022SREC1 TD025TTEA1 TD036THEA1 TD024THEB2 TD030MHEA2 TD028THED1(60H00095-00M): HTC Touch,Dopod S1 TD022SHEB2: Dopod 565/575/585/586, Audiovox SMT5600, I-mate SP3i, SP3, 02xphone, Orange SPV C500, Qtex8010, HTC Amadeus TD022THEC1: Dopod 566/586/c600/595/596, I-mate SP5m, I-mate SPJAS, Orange SPV C700,Qtex8300/8310/8600, T-Mobile SDA TD025THED1:HTC Excalibur,O2 Xda Cosmo,Dopod C720, Sony LCD ACX502BMU/W: HP iPaq 1930/1935/h1930/h1935 ,HP iPaq 1940/1945/h1940/h1945 ,HP iPaq 4100/4150/4155/h4100/h4150/h4155 ,HP iPaq 4300/4350/4355/h4300/h4350/h4355 ,HP iPaq 6300/6315/6365/h6300/h6315/h6365 ,Palm Z125 ACX502AKN: Dopod 696(1st gen)/696i/699, HP2200, ipaq h2210 ACX502BMV-7: Dopod D700( 2nd Generation with gold flex cable ) ,O2 XDA IIs ,O2 XDA III ,Qtek 9090 ,Orange SPV M2000 ,i-Mate PDA 2000 ,Siemens SX66 ,VPA 1620 ,AudioVox PPC 6600 ,Verizon VX6600 ,Sprint 6600 ACX526AKM: Dopod D900, I-mate jasjar, Loox720, MDA Pro, Orange SPV M5000,Qtex9000,XDA Exec, XDA Executive ACX525AKM: Sony Ericsson P9xx, P900 ACX501AKM: HP H3970 ACX517AKM/ACX517AKM-7 ACX517AKQ-8 ACX523AKM: HP ipaq hx47xx ACX524AKM/ACX524AKM-7 ACX533AKM: Treo650 ACX544AKM/ACX544AKN: Treo680 ACX342BKM8: Orange SPV C600, Cingular 2125 ACX346AKM-8: Blackberry 8700c ACX346AKZ-8: Blackberry 8700c ACX502ALM-7: PSC FALCON 4220 ACX507ALQ-3: Sony Clie PEG-TJ27 ACX709AKM-2: Sony Clie-n750c ACX361AKM-7 ACX357AKM ACX502ALM-7
Posted on Jun 04, 2009
White screen
The white screen you are getting is it just right after turning on the computer? If yes it means that you were not able to see the Dell logo correct?
Try connecting an external monitor thru VGA. While monitor and laptop is on with white screen please do this. Hold down Fn key then press F8 at the same time. This will toggle the display from the laptop to external monitor. If laptop displays to external monitor means that laptop LCD needs to be replaced.
If you do not have an external monitor try this.
While laptop is OFF. Do this. Hold down the D key then press power button at the same time.
Check if the laptop will display colors the whole screen. If you still see white screen then LCD needs replacement.
LCD mean LCD panel or the whole screen together with LCD cable and Inverter.
Hope this helps.
Mar 25, 2011 | Dell Inspiron 1525 Notebook
Dell Monitor Failing
its the problem in the EST of the monitor.just get it replced to solve the problem.
pls do rate the solution
thanks.
regards.
fixya expert team
Sep 02, 2008 | Dell E152FP 15" Flat Panel LCD Monitor
My dell E151fpb 15' monitor screen turns white
Look for loose connection between the LCD panel T-CON board and the logic board first, it may also have lost the 5vdc for the T-CON board.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Capacitors kit: http://lcdalternatives.auctivacommerce.com/
Aug 05, 2010 | Dell E151FP 15" Flat Panel LCD Monitor
My DELL E151FPb LCD Monitor turns to white screen.
unplug the monitor on at the back fo the computer but leave the power plugged in and if you can see red,green ,blue bars jumpign around the screen it means that the monitor is good check the video card, but if you cant see the colored bars you need to get it repalce.this is monitor selft test process
Apr 15, 2010 | Dell Computers & Internet
My computer monitor will not stay on.
The problem may with the Ram inside your computer
Jul 07, 2009 | Dell E153FP 15" LCD Monitor
If the screen is all white light then you can have a number of problems.
One could be a bad video board, the next could be a simple loose wire from the video board to the back of the lcd screen OR a simple blown fuse on the back of the actual lcd screen can cause the same thing.
Snaps are all sround these things and can be really stubborn at times. Best to start the bottom first then work up each side to the top.
Something flat, thin and with a decent sharp edge on it will help. A pocket knife held parallel to the joint between the front and rear plastic works, you can also sharpen the edge of an old credit card with a file (nail file works) This isn't as strong as a blade , but safer if you slip !!
Fran
Oct 10, 2008 | Gateway FPD1975W 19" LCD Monitor
Dell E151FPb 15" LCD with power LED blinking.
The problem may be a loose connection. When I turn on my monitor, the green light blinks and a flickering white screen appears for a brief second every time. There must be a loose connection on the power board which may be causing this. The easiest solution is to tap at the back of the monitor. This will reconnect the loose end and the monitor will work fine until it gets disconnected again. I will open my monitor soon to find the real problem. But it will take some time to find it.
Aug 17, 2008 | Dell E151FPp 15" Flat Panel LCD Monitor
Wacko Dell E151FPB
that sounds like a computer problem, not a monitor problem.  Plug the 'old' monitor in and see if your computer will boot with it.
Oct 14, 2007 | Dell E173FP 17" LCD Monitor
Lcd monitor goes white
The E151FPb's seem to have a problem of this sort. After doing some research online I've found that the most common problem is a few dry solder joints on the large circuit board inside the monitor. There was also some talk of a connector suffering from heat creep that sound be connected better on the inside, but usually that would make the screen turn black if it were to become disconnected. The monitor can be opened by unscrewing all the screws on the back, there should be 6 screws you need to pull out before being able to open the case. After those, insert a thin, but strong piece of metal into the side and sort of twist/slide it along the side and it should pop open some clips and just work your way around the perimeter. After that it's just some simple and obvious screws to get to the circuit boards.
Apr 11, 2007 | Dell E153FP 15" LCD Monitor
LG 37LP1D 37 in. LCD Television Logo
3,366 people viewed this question
Steve Allison
Steve Allison
