Question about HP Photosmart R707 Digital Camera
When I connect my camera to my USB port the camera screen says "establishing connection" but it never establishes. I've transferred pictures before onto this same computer and never had this problem. I even bought a new cable because I thought that might be the problem, and it's apparently not.
  • 43 Answers
You can transfer the pictures from your camera by setting the USB Configuration to Disk Drive in the Setup Menu.
I suggest you to reinstall the HP Photosmart software from Software & Downloads on www.hp.com.
Posted on Jan 29, 2010
My hp photosmart 8886 dock will not transfer my pictures to my computer. I checked all of the cables and tried all of the USB ports on my computer. When I press the transfer button, it reads,...
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Jan 17, 2011 | HP Photosmart 945 Digital Camera
How to upload photos on my computer
They are several ways to upload a picture to the computer. The common way is through the USB cable that should of been provided with the camera. Once the connection is establish, the computer will show an external drive is connected in the My Computer window. Locate that drive and open it. In there you will find the pictures. Then you can copy those files and transfer them to anywhere in the computer. Another method is to remove the memory card from the camera and insert it into a computer that has the slot for that particular card. If it doesn't, you can purchase a multiple card reader and connect it to a USB port. The computer will recognize them as external drives. Insert your card into the appropriate slot. Then do the same as I mentioned above.
Oct 28, 2010 | BenQ DC C840 Digital Camera
"establishing connection..." not connecting
I suspect the problem lies with the HP software on your computer. You can download the HP Photosmart software from www.hp.com. Look for Software & Driver Downloads for R707 camera. You can still transfer your photos by setting USB Configuration in your camera, to Disk Drive in the Setup Menu.
Jul 06, 2009 | HP Photosmart R707 Digital Camera
My camera won't be recognized when it's hooked up...
Make sure the camera is on and pc is selected on the camera screen when connected to the computer. You will need to have PC highlighted and select ok on the camera as this starts the camera and computer to communicate. Once communication established the LCD screen of the camera goes dark and the computer should generate a removable disk drive. Check the System Tray (lower right corner beside the PC time) for Safely Remove Hardware. When you click on it, it should read "Safely Remove USB Mass Storage Device Drive ?:" If you dont see that, then check the Device Manager to see if the camera is recognized as USB Mass Storage Device. The camera uses the driver usbstor.
May 17, 2009 | Olympus FE3010 Digital Camera
HP Photosmart M437 not establishing connection
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Apr 20, 2009 | HP PhotoSmart M437 Digital Camera
I HAVE A SONY DIGI CAM MODEL DSC W-5. MY PC IS NOW UPGRADED WITH WINDOWS VISTA AND SINCE THEN IT IS NOT POSSIBLE TO DOWNLOAD THE PICTURE TO PC. THE INSTALLATION CD ISSUED WITH CAMERA DOES NOT COMPITABLE...
  1. Turn on the camera.
  2. Insert the recording media containing the pictures into the camera.
  3. Depending on your camera, set the USB Connection or Transfer mode setting in the menu to the Mass Storage , Normal , or PTP .
  4. Use the USB cable supplied with the camera to connect the camera to the computer. IMPORTANT:
    • Connection through a USB hub or other USB device -- such as a printer or keyboard -- is not supported and cannot be guaranteed. Connect the camera directly to a USB port on the computer.
    • If the USB connection from the camera is not recognized by the computer, disconnect the USB cable and repeat steps 4 and 5 using a different USB Connection or Transfer mode setting. If the connection is still not recognized, further troubleshooting is available.
    NOTES:
    • The computer will automatically install the USB driver for the camera.
    • When the camera connection is established, an AutoPlay window will appear.
  5. In the AutoPlay window, click Import pictures .
  6. In the Importing Pictures and Videos window, click the Import button. NOTE: After the pictures have been imported, the Windows Photo Gallery window will appear and display thumbnails of the imported images.
If this doesn't work there is an updated driver available
Here
(from Sony Website)
Mar 19, 2009 | Sony Cameras
Camera says "establishing connection" when trying to transfer
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa.
Organize edit and share your photos
Dec 09, 2008 | HP Photosmart 433 Digital Camera
Transfer the photos
This can occur due to 2 reasons..
1) Bad USB port: Try connecting to a different USB port and see if it works. If it does then its probably a problem with the USB cable.
2)Bad USB cable: You can resolve this by Changing the cable or by getting a USB card reader. Specify the details of your Memory card and i will help you find a card readr that suits your card..
Jun 16, 2008 | HP Photosmart R717 Digital Camera
Transferring pictures
Buy a card reader to transfer your photos. It is much easier and faster. A decent SD card reader can be found online for about $5.
Nov 01, 2007 | HP Photosmart M417 Digital Camera
USB Connection problem Optio S4
have you turned the camera ON after connecting the cables? Next, does this USB port on the computer work with other USB devices such as memory sticks? My O555 has a USB socket that feels really "fragile" and I fear I will damage the socket with improper insertion (alignment seems touchy). I bought an external USB card reader and am really happy with that. You don't use up battery power transferring your files. Much better solution, IMO.
Sep 08, 2005 | Pentax Optio S4 Digital Camera
HP Photosmart R707 Digital Camera Logo
77 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
