On button on printer both lights flashing flashing green redprinter comes up on screen in trouble shooting program cannot find sign of hp in application program hp officejet 4255 all-in-one
    Problem Solver:
  • 10 Answers
Check the catridge is it in place or any material stuck in between the feeding roller.
Posted on Dec 09, 2008
How to turn on hp 3600
Unplug the power cord from any surge protector, extension cable, or power strip, press the power button on the printer several times. Plug the power cord directly into a wall outlet.
Feb 21, 2015 | HP DeskJet 3650 InkJet Printer
It is showing a triangle with excalamtion mark blinking
That would be the attention light.... Indicates that the input tray is empty, the print- cartridge door is open, or bad toner. Is there any lights that are on solid or flashing? (could also have a bad fuser ... need to trouble shoot this a little more)
If you hit the green button does it do anything?
- www.trusttechnology.biz
Mar 13, 2014 | HP LaserJet 1320 Printer
My hp laserjet 1300 printer shows blinking the orange light instead of the green one and I couldn't find out what is the reason
1. Go light/button blinks twice with solid green and orange lights
2. Green light starts blinking with go light twice and then both go off
3. orange light goes off.
4. green light followed by orange light followed by go light cycle twice and a third time by the green light
5.followed by the orange light continuously blinking.
I have already tried the following trouble-shooting:
1. Put in a new cartridge
2. Made sure there is paper properly seated in the tray
3. Made sure all doors closed (I even took off left side to verify no memory cards
4. Verified all doors closed
5. Done a cold reboot by holding the Go button while turning the unit on.
6. Repeated steps 1-5 multiple times.Hope It's resolve all Your Printer Problem,
Or
Still having Problem Then follow Us For HP Support
Mar 06, 2014 | HP LaserJet 1300 Printer
Is not working more
Switch the printer off.
Press and hold the green button on your printer and turn the printer on. You will see that the lights flash for a moment and then turn off. After a few seconds, the attention light will turn on followed by ready light and the green light. Keep pressing the green button. In a few seconds, the attention light and the ready light will turn off.
Push the toner rotate button while you continue pressing the green button. As you briefly push the toner button, you will see the light flashing. Release both the toner button and the green button.
Repeatedly push the red button (cancel button). Now all the working lights on the printer will turn off.
Open and close the lid of HP printer once. The light will start blinking.
Press the green button. Your HP toner cartridge chip will be reset.
Jan 29, 2013 | HP DeskJet F4280 All In One Printer InkJet
My on button stays on will not turn off and the cancel button flashes orange
try this below....
turn on/off, unplug, plug in, should reset configs.
go to applications folder for your computer, dbl click printer icon for make of printer. check settings. print 'test document and clean cartridge heads', this should ensure proper printing formats.
lastly, go to web site of printer model and check site for trouble shooting if this does not work above. HP has an awesome website for trouble shooting
hope this helps and good luck
Apr 28, 2010 | HP Photosmart C5180 All-In-One InkJet...
HP DeskJet 812C Hardware Problem! with Printer cartridge carriage. Printer Cartridge retracted into right side of case will not come out. There is No paper jam in machine to prevent it from doing so. ...
Disconnect the "data" cable (parallel or USB).
Disconnect the "power" cable.
Reconnect the "power" cable.
Turn the printer on.
Lift the printer's lid -- the print-carriage should slide the printer-heads to the "middle" position.
If all else fails, take the printer to a qualified technician, for more trouble-shooting.
Feb 02, 2010 | HP DeskJet 812c InkJet Printer
HP 920c Deskjet feeds blank paper constantly. Will not print. Just shoots paper out.
deskjet 920c will not print, green light flashes and blank paper comes out. Printer will print test page perfectly.
Nov 07, 2009 | HP DeskJet 920c InkJet Printer
HP 5500 can not print with 59.CK error code on display
You probally need to contact an engineer on this one, from HP trouble shooting manual
Description
A printer motor error has occurred. This message might also appear if the ETB is missing or incorrectly installed. Ensure that the ETB is installed correctly.
Action
1. Press the green <Tick Symbol>(Select) button to continue.
2. Turn the printer off, and then turn the printer on.
3. If the error message returns, turn the printer off.
4. Perform a cold reset.
a. Turn the printer on.
b. Watch the control panel.
c. When the memory starts counting, press and hold the green <Tick Symbol> (Select) button.
d. Continue holding the green <Tick Symbol> (Select) button until the Ready, Data, and Attention lights flash once, and then stay on steady.
e. Release the check button when the Ready, Data, and Attention light are on steady. The control panel will display SELECT LANGUAGE.
f. Press (Down Arrow) button once. The control panel will display COLD RESET.
g. Press <Tick Symbol> (Select). The printer will perform a cold reset and then continue its power-on sequence.
5. If this message persists, contact an HP-authorized service or support provider.
Sep 22, 2009 | HP LaserJet 5500 Printer
Green on/off button not working. Just HP logo in display box disp
Open the printer and check the voltages at the power points. If they are present then power module is ok.
Jul 17, 2009 | HP OfficeJet 7410 All-In-One InkJet...
When I trouble shoot, it tells methe device is not connected
try to uninstall the driver and software of the printer
then a compete new installlation
Jan 26, 2009 | HP Deskjet D4260 Printer
jasbo
jasbo
