Question about White Sewing Speedylock 1600 Mechanical Sewing Machine
Hand operated free start wheel is not turning
This wheel does not turn by hand or by foot petal.
    Problem Solver:
  • 8 Answers
Try holding down the foot pedal & turning the wheel at the same time.
Posted on Dec 09, 2008
  • Lee Montoya Dec 09, 2008
    or u might have to oil it up
Brother sewing maching
On the hand wheel there is the lock that is used to stop and start the needle from being used. This is necessary for refilling the bobbin with thread. If the hand wheel doesn't make the needle work then you will need to do some minor adjustment.
1. On the hand wheel find a small screw and loosen it until it is just about ready to remove.
2. Now tighten the hand wheel.
3. Tighten the small screw again.
It should be ready to use now.
Aug 31, 2016 | Brother Sewing Machines
The hand wheel is stuck and does not move.????
HAND WHEEL NOT TURNING EASY
If the hand wheel isn't turning freely here are possible problems.
1. Clean bobbin area and ensure bobbin case is inserted properly.
Also, put one drop of oil on race (bobbin case sets on it).
2. Check/remove material from feed dog.
3. Remove the thread and rethread with the pressure foot up while giving small tugs as you go to check for snags.
4. Afterwards put the pressure foot down and give a small tug to check for excessive resistance on thread. It is a good idea to start at four. Now place thread in needle.
5. Put oil on needle arm and pressure foot arm.
6. When done it should work.
7. If this is still a problem the interior of the machine may need cleaned and lubricated.
May 06, 2015 | Sewing Machines
Need to put bobin in a merritt 4530
Flip the presser switch up to raise the presser foot. Turn the hand wheel counterclockwise until the needle is in its highest position.
  • 2Hold the hand wheel in place with your left hand while turning the hand wheel knob counterclockwise with your right hand to loosen the hand wheel knob.
  • 3Place the desired spool of thread on the spool pin so that the pin fits all the way through the hole in the center of the spool. Put the spool holder onto the end of the spool pin that is sticking through the spool of thread and press firmly to ensure that the spool holder keeps the spool in place.
  • 4Grasp the end of the thread and hold it taut between the thumb and index fingers of both hands. Snap the taut section of thread into the thread guide post located to the left of the spool pin.
  • 5Pull the end of the thread gently. Wrap the thread around the bobbin winder tension disk near the left front on top of the machine, starting at the side of the tension disk facing you and wrapping around in a clockwise direction.
  • 6Poke the end of the thread through the small hole in the bobbin from the inside out so that the loose end of the thread sticks through the top of the bobbin. Put the bobbin on the spindle, or bobbin winder, and gently slide the bobbin winder to the right.
  • 7Hold the loose end of the thread in place while pressing down on the foot pedal to start the machine. Hold the foot pedal down until the bobbin is as full as desired. The machine will automatically stop once the bobbin has reached capacity.
  • 8Cut the loose end of the thread using scissors. Slide the bobbin winder to the left and remove the bobbin. Hold the hand wheel in your left hand and tighten the hand wheel knob with your right hand by turning it clockwise
  • Apr 05, 2012 | Singer 6510 Sewing Machine
    Hand wheel turns bobbin but not presser foot
    it needs to be checked by a sewing machine repair shop to see what wrong with it
    Jan 28, 2012 | Singer 3116 Simple
    I have a singer cxl electronic sewing machine and i have a problem with the needle either not moving or stopping when stitching the larger motifs or the zigzag stitch, somtimes the needle jut moves too...
    The needle either not moving or stopping is a sign that the machine is jamming. Here's the answer for the question "My machine is jammed" from the FAQs on Singer's web site at http://www.singerco.com/support/faqs.html
    A jammed machine is caused by thread being caught in the hook. Remove the upper thread and the bobbin case, turn the hand wheel towards you (counterclockwise) by hand and remove any thread in the bobbin case area. *Always turn the hand wheel towards you. Turning the hand wheel away from you (clockwise) can cause the machines timing to become unaligned and jam your machine. Also, always make sure the presser foot is in the down position before you start sewing. Sewing with the presser foot in the up position will jam your machine in the bobbin case.
    Your description of the needle hitting the plate or foot is an indication that the machine's timing has become unaligned which can be caused as indicated above by turning the hand wheel away from you - the correct way is to *Always turn the hand wheel towards you.
    Mar 03, 2011 | Singer Sewing Machines
    The thread hangs up inside the bobbin holder
    Sep 26, 2010 | Singer 2517 Mechanical Sewing Machine
    Hand wheel loose
    In the middle of the stop motion screw wheel there is a screw, undo the screw and unscrew the stop motion wheel all the way off, you will now see a three pronged washer, take it off and put it in a different position, put the stop motion wheel back on and just tighten finger tight, tighten the small screw all the way, now loosen the stop motion wheel and press on the foot control gently, the balance wheel should move with moving the machine, if the machine turns then start over again, you can put the three pronged washer upside down if you wish.
    May 09, 2009 | White Sewing 1418 Mechanical Sewing...
    Kenmore 10 stitch needle won't move
    hi there,
    push or pull hand wheel clutch to engage
    motion of needle and shutter.
    if not check belt on downside of hand
    wheel open cover motor,loosen bolt cover
    see belt check if engage on pulley by
    holding hand wheel move belt if
    hand wheel move,if not tighten screw on
    pulley from hand wheel and moter.
    have a nice day and thanks
    Apr 03, 2009 | Sewing Machines
    Sewing machine won't sew but does other things.
    is there a wheel inside the hand wheel on the right?  tighten that by holding the hand wheel and turning the inner wheel away from you.  let me know if that doesn't work!
    Jan 12, 2009 | Brother Sewing Machines
    Singer Stylist 834
    It needs a good cleaning of lint, thread etc. take your bobbin case out and make sure that there is nothing in there. DO NOT TURN YOUR HAND WHEEL BACKWARDS! It will mess up your timing. If you cannot free it up take it for service
    Nov 04, 2008 | Singer 132QRFB Mechanical Sewing Machine
    White Sewing Speedylock 1600 Mechanical Sewing Machine Logo
    239 people viewed this question
    Top White Sewing Sewing Machines Experts
    Tally Girl
    Tally Girl
    tsalagi152
    Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
