Question about SanDisk Sansa e130 MP3 Player
Sandisk e130 using it today and the power shut completely off- i use AAA batteries (not re-chargeables). I replaced the batttery and nothing happened. I tried multiple batteries. Any ideas?
  • MommaV May 15, 2008
    Player shut down when I tried charging it on my computer and plugged in my earphones. HELP. I'm 63. Player was a gift and I have no idea what to do.
GR8 JOB!!!! was going to buy a new one, worked like a charm. Thanx
Posted on Dec 03, 2008
Yeah it worked. Did just like it said above and everything works fine now thanks so much
Posted on Aug 16, 2008
Worked like a charm, my daughter will be very happy!
Thank you!
Posted on Mar 05, 2008
I tried above soulution and it worked with a new AAA Battery. Thnks.
Posted on Jun 13, 2007
My Sansa seemed dead. I followed the solution described and it worked. Thanks.
Posted on Jun 11, 2007
Get out the battery and let the device "calm down" without any source of power for 5-10 minutes. After that push the menu/start button, hold down for 30 or more seconds and holding down, insert the battery. It has to reset the power circuitry and should help.
Posted on Apr 24, 2007
Canon Powershot SX120is wont turn on
This kind of problem happen because not all of AAA batteries in market are match with canon standards. so changed his mind about using disposable batteries on new models. your camera need new DC/DC board which is expensive(between 50 to 90 dollars). there is video in you tube to how replacing the board. But better suggestion is getting a new camera with chargeable battery.
May 28, 2012 | Canon PowerShot SX120 IS Digital Camera
Sandisk e130 says it is full but has nothing on it.
plug it in your computer, when its on , go and look into your recycle bin, there might be the songs u have delitet ,delite them once and for all and you should have room again
Mar 08, 2009 | SanDisk Sansa e130 MP3 Player
How do i get the ''key hold'' off of e130?
If you look on the left side of the e130, there is a slide switch. Slide that switch up, that is your hold switch. In order to get your player powered on, you have to have it out of the key hold function. Now after you get to playing the music you want to hear, then you can reactivate the key hold. However, this will disable you from turning the volume up or down, or skipping through the songs. In order to be able to do this, then simply turn off the key hold again by sliding it down. I hope this helps!
Nov 18, 2008 | SanDisk Sansa e130 MP3 Player
My mp3 freezes up..can anyone help??
Thank you for the help in reformating my sansa e140. It worked perfectly!!!
Jan 18, 2008 | SanDisk Sansa e130 MP3 Player
Sansa e130
ok, for everyone with e130 "keeps getting an I/O device error, only language screen, than something about 4MB memory..." problem, I just spend six hours of my life trying to solve it and fix my dad's e130 and I succeeded ;)
so, step by step, how EXACTLY I did it:
0) my system was windowsXP SP2
1) remove the battery
2) keep holding the menu button and plug in the usb, keep it for a few seconds more, untill the system will tell you it found a stmp3500 and want to install the hardware
3) allow it to reach windows update for that matter and install the drivers
4) now you have new device that is called "Player Recovery Device Class" you can check it in device manager (Right-click My Computer, click Properties, click the Hardware tab, and then click Device Manager)
5) and now is time for flushing new firmware...I managed to find two versions of firmware for e130:
1.0.101e - http://www.sandisk-karty.cz/sandisk-katalog/sansa-e100-series-mp3-players/dokumenty/
2.0.0.01e - http://www.sandisk.com/Retail/Default.aspx?CatID=1295
6) I tried both of them in many different combinations and finally one and one only miraculously worked for me and that was the one when
I HAD THE SD CARD IN THE MP3PLAYER, THE PLAYER WAS RECOGNIZED AS "Player Recovery Device Class" BY THE WINXP AND I STARTED EUROPIAN sansa-2.0.0.01e.exe !
PS: i don't think that there's a big difference between europian and american version of firmware I mention it just to be accurate about the situation. and big thanks to anonymous guy who turned me to right direction with stmp3500. hope that help to others ;]
Oct 26, 2007 | SanDisk Sansa e130 MP3 Player
San disk e130 mp3
Hi. The E100 series players (including your E130) can only support up to 2GB SD cards.
Apr 21, 2007 | SanDisk Sansa e130 MP3 Player
I hate blue
goes off because the backlight is on a timer. after 20 seconds or so it turns off if no buttons are pushed. if the player will still play music but nothing shows on the screen, then the display is shot. The screen is not replaceable on these players. sorry, but it's most likely junk now. You could use it as a data storage device still. Best bet is to buy a used player off ebay or amazon.
Feb 11, 2007 | SanDisk Sansa e130 MP3 Player
Display not working
You may have to open the player and reconnec the LCD.
Jul 24, 2006 | SanDisk Sansa e130 MP3 Player
Battery
I'm having the same problem! I've had my Sansa e130 for exactly one year today. I loaded new music on it last night and when I tried to turn it on, it said "searching internal memory for new music." I left it on and this morning it wouldn't come back on with new batteries or even when hooked to a computer! I sent an e-mail to the company for help since there is no reset button. I haven't heard anything yet. I suggest you contact SanDisk too. They may have a problem. And I can't believe someone actually suggested as a solution to put a new battery in it or hook it up! No duh! We're looking for real help here, not the obvious things to try.
Apr 01, 2006 | SanDisk Sansa e130 MP3 Player
SanDisk Sansa e130 MP3 Player Logo
229 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
