Question about HP Photosmart 3210 All-In-One InkJet Printer
Print will not print in color when using word 2007
HP all in one 7410 printer will not print in color when printing a word document using color font
  • 60 Answers
Hi have you check the propertie when printer to makesure is not set to due to not in colour
have a look if not sure let me know
cheers
Posted on Dec 09, 2008
I Need to ask how do I change my font larger I have a H P Photosmart 5510
The printer prints out what it sees in your document. You need to resize the font in your document, which the printer will then see and print.
Jan 12, 2015 | HP Photosmart 5514 B111H Inkjet...
How do I get my HP Deskjet D1455 to print in color?
Select the document which you want to print.
give the print command.
Open the printer properties.Look for the option features and printing
Select color printing .
Your printer will print the document successfully.
May 21, 2012 | HP Deskjet D1455 InkJet Printer
Pcl xl error error: insufficient memory operator: rectanglepth position : 751 How do i correct this problem
Solution
The possible reasons for this error message are as follows:
  • The document is containing both image and text.
  • The font is not supported.
  • Embedded fonts are used.
  • A special plug-in is used.
This issue can be fixed by enabling the following option in Printer Preferences .
To access Printer Preferences , follow these steps:
  1. Open the Control Panel .
  2. Open Printers and Faxes .
  3. Right-click HP Color LaserJet CM2320 MFP Series PCL 6 , and select Printing Preferences .
  4. Under the Advanced tab, change the Print Data Optimization from Auto to Optimize for Text and Vector .
  5. Now try printing the document.
  6. If the document did not print then try turning the printer off then back on. Try printing the document again.
Rameshkumar . R
cberamesh@gmail.com
Aug 24, 2011 | HP LaserJet P2015 Printer
Insert HP color inkjet print cartridge 99 into HP OfficeJet 7410 I am replacing the HP 97 color print cartridge with th 99 print cartridge (both are color). The 99 will not go in all the way. I notice the...
The HP 99 cartridge is used if you would like to print photos. The HP 99 replaces the HP 96 (black) cartridge in your printer. The HP 99 cartridge has black, photo magenta, and photo cyan inks in it. When you pair this with the cyan, magenta, and yellow in your HP 97 (color) cartridge you have the full set of photo colors represented.
Jan 13, 2010 | HP OfficeJet 7410 All-In-One InkJet...
My HP Officejet 7410 All-in-One Inkjet Printer is doing the following: 1) It prints in color even when the document is black and white (using up the color ink) 2) It prints much more slowly than it did...
go into your driver and change your color preferences to black and white. that way when you want to print color you actually have to tell it to do so. which will save your color ink, and will print much faster. full color printing of a black and white document uses all ink colors except black to make what is called process black.
Dec 18, 2009 | HP OfficeJet 7410 All-In-One InkJet...
My HP 7410 will not print in color. Black
my hp printer officejet7410 made a wierd noise and now the only color that anything prints is in reds and pinks.
Jul 13, 2009 | HP Office Equipment & Supplies
HP Laserjet 1500 Color, Print out Blank
Hi devi960:
Pages print, but all
colors do not print or
the pages are
completely blank.
One of the print cartridges might be
low or empty.
Run an engine test and see if all four colors print. If
not all colors print, replace one or more of the print cartridges. If the
engine test is successful, replace the formatter.
If the printed pages are completely
blank, the file might have blank
pages.
Check the file to make sure that it does not contain blank pages.
A print cartridge might be low or
empty.
Check the printer control panel for a Supplies Status message,
print a Supplies Status page, or use the embedded Web server
(HP color LaserJet 2500 series printers only) to see the levels
remaining in the print cartridges. Replace any print cartridges that
are low or empty. Messages are not created for non-HP print
cartridges.
If you are using non-HP print
cartridges, one or more print
cartridges are low or empty. The
control panel lights do not indicate
low or empty for non-HP print
cartridges.
Replace one or more of the print cartridges.
Font DIMM might be selected but the
font DIMM is not physically installed in
the printer. (This issue applies only to
printers using an Asian-language font
DIMM.)
In the settings for this printer, clear the Font DIMM check box on
the Configure tab if no font DIMM is installed in the printer. Select
the Font DIMM check box only if the font DIMM is physically
installed in the printer. If you think that the font DIMM is installed,
make sure that it is installed correctly.
The paper curls when
exiting the top output
bin.
The paper needs to print to the
straight-through paper path.
Open the rear output door to print to the straight-through paper
path. Remove each sheet as it exits the printer.
The stack was slightly curled when it
was placed in the tray.
Turn the stack over in the tray.
The paper does not meet
specifications.
See the user guide for information about print-media specifications.
If you are printing on light media, the
Type setting might not be correct.
Select Light in the Type is field in the printer driver.
Nov 13, 2008 | HP LaserJet 1500L Printer
Quicken 2008 printing vista 64
There is an issue with Quicken 2007 and 2008 printing to many HP printers. Workarounds: 1) print to the Quicken PDF virtual printer, then print the resulting PDF file. or 2) Install a Deskjet 990 driver (using the add printer command) using the same port as the Officejet 7410 is installed.
Regards,
Bob HEadrick, MS MVP Printing/Imaging
Nov 02, 2008 | HP OfficeJet 7410 All-In-One InkJet...
HP Photosmart 3210 All-In-One InkJet Printer Logo
230 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
