Question about Lexmark X3470 All-In-One InkJet Printer
My printer won't scan
I keep pressing the start button but it doesn't do anything. I can print from it and the copy part works, so i have no idea what the problem is.
  • lvoiles Dec 14, 2008
    copies, prints but will not scan
  • Pivotdude111 Jan 14, 2009
    same with me....
    i have a canon MP620, and it prints and copies, but it cant seem to register that the photo is even there.
I fixed mine by reinstalling the software that came with it.
hope this helped
Posted on Jan 17, 2009
2 Suggested Answers
Kyocera CS-C2525 won't scan
Do you have the option installed on you copier??? Also, there is another ether connector for scanning. If it is installed it is right above the print PCB.
May 22, 2012 | Kyocera Copystar CS-5035 Copier
It says E5, which means I need to replace my FINE ink cartage, but I don't print with this printer, ever, only scan. It won't let me do ANYTHING since it's started flashing this a week ago. Why...
Hello! Here is your solution.
1. Press Stop/Reset button for 5 seconds. 2. After 5 seconds your printer will start one process. 3. Now release to hold the button.
Now your printer is ready to use.... thanks
Sep 13, 2011 | Canon PIXMA MP210 Photo All-In-One Printer
How to print a regular document from Microsoft Word, Excel.
Instead of pressing the start button to print, you need to press the small ON/OFF button. The start button works to copy/scan. But to print, you will need to turn the printer on first. Once the printer is on, the computer should recognize it fine and allow you to print from your applications.
Jul 13, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Red ink run out, can`t scan
you can refill the caterage which will be cheaper for you
Dec 07, 2008 | Canon PIXMA MP510 All-In-One InkJet...
Can't scan or copy...looks all fuzzy
When you say fuzzy, do you mean that you are getting cast or moire? try this and keep me updated on the result
If you are seeing a grey cast to all stand alone copies made with the CX7800 please try the following:
1. Select the SETUP UTILITIES button on the CX7800
2. Press the RIGHT arrow (photo options) button until you have an option for copy quality then press the START button.
3. Use the UP or DOWN arrow (copies) buttons to select the desired copy quality you want then press the START button again.
Now press the copy button and select the START button. Pls rate as fixya if it resolve it, and if you need anything else pls inform me. Thanks!!
Jun 12, 2008 | Epson Stylus CX7800 All-In-One InkJet...
Error ##343 and it didn't print anything Orange light below screen has been flashing, screen message "Waste Ink Nearly Full". No idea where waste ink container is kept? Have changed cartridges. Now saying...
Manual Reset procedure Waste Ink Tank for Canon MP390:
  1. Start with printer on, press additional functions, Scan, Copy, Scan. Now you should be in service mode.
  2. Select Test mode (must be the last available selection).
  3. Select #8 Printer Test, it will start cleaning then it will come up with some other option: push the + or - button until it says 8-3 then hit the select button
  4. The menu will now say EEPROM Clear
  5. Select Ink count which is option (0) and press set
  6. Press Stop/Reset Followed by the power button and then wait for it to restart.
hope it helps
cheers
Jun 09, 2008 | Canon SmartBase MP390 All-In-One InkJet...
HP psc 2110 Printer keeps telling me to Align print cartridges. I follow the steps but it always comes up alignment failed and starts printing Instruction page all over again. I can print from my computer...
Press the cancel button. Then press the "setup" and top "copy option" buttons together to enter maintenance. Use the right arrow (right copy option) button to scroll through the options if you like, but then hit the cancel button to skip the alignment.
May 18, 2008 | HP Office Equipment & Supplies
Canon MPC 190 Imageglass printer
Hi, taken from here: http://www.fixyourownprinter.com/forums/printer/27470
1. Press MENU COPY SCAN COPY COPY
2. This will take you to TEST MODE
3. Use the + key to take you through to PRINTER TEST (option 8)(if you go past, either keep keying the +, or you can use the - to take you back)
4. Ensure that it shows 8-3 on the screen. This is EEPROM CLEAR
5. Press OK
6. It will show 0 INK COUNT
7. Press OK
8. Press the STOP/RESET button
9. Press the ON/OFF button
10. The printer won't turn off, but will "reset" itself (or something).
I'm not sure what this does, but it gets rid of the "WASTE INK NEAR FULL" message and you should be able to print again with no problem.
Feb 03, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
WILL NOT COPY
Dear, after changing the cartridge, printer print a test print. OKAY. Take that test print and put it on the scanner (printed area should on the side of mirror) then press "scan" button on your printer "bottom left". When the light stop fluctuating. Keep out the paper from the scanner. After this Printer will work properly
Sep 09, 2007 | HP PSC 1315 All-In-One InkJet Printer
Lexmark X3470 All-In-One InkJet Printer Logo
348 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
