Question about Taylor 7506 Precision Tech Lithium Battery Electronic Glass/Chrome Scale
Instant-on isn't working
When I step on the scale, it doesn't register (perform the weighing function) - no "0's" going across the screen. Getting on and off several times will sometimes work. There doesn't seem to be any rhyme or reason to when it decides to come on. And, yes, I have replaced the battery. Thanks for any help you can give.
  • 74 Answers
This link allows you to trouble shoot directly with the company... I hope this helps. http://www.taylorusa.com/advantage/root/contact.html
Posted on Jan 07, 2009
I replaced the batteries and followed the instruction.
You need to initialise the weighing process by tapping your foot on to the scale to start it...but wait for it to zero...then step on it.
Jul 02, 2015 | Taylor 7404 Ultra Thin Lithium Scale with...
Escali scale wont turn on
Step on the scale and immediately step OFF and the scale will then be ready to weigh you. If this does not work, then you need to replace the battery.
Apr 05, 2013 | Escali BFBW200 Body Fat/Water Bath Scale
I just received product JB5413. Batteries were just purchased today. The remote is working fine, but it will not weigh. The instruction manual is minimal. I need help getting this to work.
If it's any consolation my Jobar/Ideaworks JB5413 scale has the a similar problem: will not weigh, yet the remote control functions okay. About one attempt out of ten will cause a weight display, though. Can't figure out why scale works occasionally, vs. never works. Batteries are new, and the battery compartments are free of corrosion.
Jan 15, 2011 | Jobar International Ideaworks Remote Read...
Keeps showing err. Thinner scale
Tap the scale twice with your foot so 0.0 appears first, then weigh yourself. If you step on the scale before 0.0 appears, the scale will not function properly.
Sep 26, 2010 | Conair Thinner Scale by TH304 Glass Body...
How do you adjust the tanita 1479 scales
what do you mean by adjust it? to calibrate it follow below
Switch off.
2. Press and hold OFF key.
3. Quickly press ON/ZERO key three times then release both keys together. The timing is rather critical, so if it doesn’t work first time, try again.
4. Display shows [ 0.-0- ], followed by [ 0.-1- ].
5. Place 50gm weight on plate.
6. Display shows [ 0.-2- ].
7. Place 100gm on plate.
8. Display reverts to weighing mode.
Mar 12, 2010 | Tanita Health & Beauty
Scales not working properly- weighing too light with battery symbol dotting across screen - have changed the battery, no difference.
scale may need to be calibrated or you may have something causing the scale to be unstable or something could be binding
Mar 08, 2010 | Taylor Health & Beauty
Taylor 7532S, battery replaced, error message 0-Ld
Try to reset the unit. Use the following steps
- Open the battery compartment on the bottom of the scale. Push the tab on the door and lift the cover.
- Remove the battery from the compartment. Close the battery compartment door.
- Sit the scale right side up on a hard surface floor.
- Step on the scale and stand still on it for five to ten seconds. Step off the scale.
- Turn the scale over and open the battery compartment. Re-insert the battery. Close the battery compartment cover.
- Place the scale right side up on the hard surface floor.
- Press one foot on the scale until the display shows zeroes or dashes. Remove your foot.
- Wait for the scale to shut off by itself. When you step back onto the scale, it will be reset.
Hope this solution has been helpful?
Jan 26, 2010 | Taylor 7532 Ultra Thin Glass Digital Scale
I need a manual for a Berkley fs50 scale
Operating Instructions1
A. Powering-on the scale
1. Press and hold the POWER button for two seconds. Scale will perform a self-test by displaying four 8s for three seconds. When "0.00 kg" or "0 lb 0 oz" is displayed on the screen, scale is zeroed-out and ready for normal operation.
B. Normal Weighing
1. Hang fish on the attached hook. Weight is displayed in either kilograms or pounds and ounces.
C. Switching between unit weights
1. Press and hold the POWER and CHOOSE button simultaneously for three seconds. Unit will change from weighing pounds and ounces to kilograms and vice versa.
D. Taring Weights
1. Weigh a bag or container till its weight is steadily displayed on the screen.
2. Press the POWER button once. Scale will zero-out and show "0.00 kg" or "0 lb 0 oz" and is ready for weighing multiple fish together.
E. Holding a weight
1. With the weight displayed on the screen, press the CHOOSE button. This will hold the current weight and is indicated by displaying an H to the left of the screen. To unlock the hold, simply press the POWER button.
F. Storing weights into memory
1. With a weight in the hold mode and an H displayed to the left of the screen, enter the memory mode by pressing the CHOOSE button. While in the memory mode, pressing the CHOOSE button will allow you to navigate through ten stored memories. These are indicated on the left and numbered 0 through 9. There are also 4 letters that indicate other options. An A shows the average of all stored weights. An E displays the total and a C resets the memory.
2. To store a weight, simply hold down the CHOOSE button for three seconds. Weights will automatically store into one of the number registers. To see the numbers with their weights, simply scroll through the numbers by pressing the CHOOSE button as described above.
G. Resetting the memory
1. With the unit in the C mode, press and hold the CHOOSE button for six seconds and scale will reset memory and zero out. Press the POWER button and scale is ready to begin weighing again.
H. Powering-off manually
1. Press and hold the POWER button for 6 seconds.
Dec 09, 2009 | Berkley Twist Lock Rod Rack
Err 4
Sounds like it wasn't initialized, even though it says Er 4 instead of Er 0... According to my manual, to (re)initialize it and reset it to zero, tap the platform lightly. It should show zeroes running across the display for a second or two, then show all zeroes and turn off. It should be re-initialized...
Error Codes for the 5757 (according to my manual):
Er 0 Initialization error (remedy described above)
Er 1 Instability error (step off the scale, then back on)
Er 2 Overload warning (registering weight beyond the 440 pound max)
Er 3 Contact error (body impedance beyond technical limit - try dampening feet and try again for better contact)
Er 4 Bodyfat error (bodyfat percentage is beyond range - try dampening feet and try again for better contact)
Er 5 Bodywater error (bodywater percentage is beyond range - try dampening feet and try again for better contact)
Jul 02, 2009 | Taylor 5757 Digital Glass Body Fat Scale
Taylor 7506 Precision Tech Lithium Battery Electronic Glass/Chrome Scale Logo
539 people viewed this question
Top Taylor Health & Beauty Experts
Ankit Chandel
Ankit Chandel
Are you a Taylor Health and Beauty Expert? Answer questions, earn points and help others
