Question about Tomtom GO 300 GPS Receiver
Frozen tomtom i tried to change my splash screen image and i must of messed up because my tomtom onlu displays a blank screen i can not turn it off or connect it to my pc to load my back up settings, because it wont give me the option to connect obviously because it wont progress from this blank screen
TomtomXL doesn't really have a hole except there is a covered hole on the bottom and if you pierce it and try to reset it, you cannot make any contact through this hole. All was working fine until I registered it and downloaded updates...guess I have to take it back to sears...thank God for sears, they always honor their stuff.
Posted on Nov 02, 2008
Worked a treat!!! seemed to freeze after downloading stuff from TomTom website But after your advice on the reset button which in truth I didn't know existed it fired up straight away.
Posted on Sep 21, 2008
Thankyou it done the job
Posted on Sep 18, 2008
    Problem Solver:
  • 7 Answers
Try the reset button on the hole in the bottom of the unit. I had a frozen unit after attempting to upgrade and this made it work. Use a paperclip to press into the hole, it will reset the unit.
Posted on Apr 27, 2007
SOURCE:
Screen frozen on tomtom image. Can't switch on or off. May have dislodged memory card when moving the device.
I had this problem with a frozen screen and could not turn tomtom off,i was getting very frustrated and nearly got my 1 wood out to it, I resolved the problem by going to tomtoms support page and clicking format internal memory(or memory card) ps, before doing this make sure you have made a back up then went to tomtom home to update device it took a couple of goes but it did the job mine is working perfect now hope this helps
Jul 18, 2009 | Tomtom GPS
Samsung T629 stuck at splash screen
Take your sim car out and try using these codes to reset the phone.
*2767*2878# and *2767*3855#
Your phone software could also be corrupt.
If you go to samsung you may be able to update the firmware in the phone over the internet.
If all else fails have the phone re-flashed by a technician.
Mar 02, 2009 | Samsung SGH-t629 Cellular Phone
Start up screen
I had this same issue on my 930. You need to edit the bitmap with paint and make sure the dimensions are the exact same as the splash file. Rename the new splash screen with the same filename for the old startup screen and delete the old. That should fix it
Jan 04, 2009 | Tomtom One XL GPS Receiver
I have a tomtom one 2nd edition. It is frozen on.
Easy, simple take a pen and press the reset on the bottom of the Tomtom, just like any other electronic device.
Dec 30, 2008 | Tomtom ONE GPS Receiver
Frozen tomtom
You can get your original splash scren from here. You can also download free splash screens created by user through TomTom HOME.
To correct your device, try:
1. Hit the reset button on the back of the device - inside the serial connector.
2. Make sure the device is off and connect it to your computer via USB dock and connect the charging cable (green light should be on)
3. Hold down the power button until the device restarts.
4. The device should automatically connect to your computer.
5. Run TomTom HOME and check for any updates.
6. If there is no new application, try: www.tomtom.com/9091 <-- that will show you how to remove and then reinstall the application.
Dec 22, 2008 | Tomtom GO 510 GPS Receiver
Frozen tomtom go 910
Hi, Not a nice problem that. Try connecting your tomtom to PC ( not through home ) so the tomtom will look like a USB drive in "My Computer". if TomTom Home tries to load up , cancel it. Look in "My Compuer" If you do see the TomTom as a drive , open it up and copy the folders and files to your PC. If that works, now you have a backup and you can have a mess around knowing that if you mess things up , at least you can put things back as they were and you won't have made anything worse than it was before. Once thats done , try a harder reset in normal way but also hold the ON button in whilst doing the reset . Many people press too hard on the reset button and also hold it too long so just give one single press , only hard enough to feel it click in , then out. Thats all it needs for a reset and it avoide damaging the switch ( yes , I have seen many reset switched stuck in or broken ). I think theres 2 possible causes for your problem . 1/ You now have a corrupted file on your TomTom preventing the boot-up continuing. 2/ Your Tomtom is still trying to perform the last function ( backing up through TomTom-home ) and has somehow got stuck in that loop. For the moment , try the above and see how you get on and if you donn't solve it please post on this forum again .
Good luck .
Nov 12, 2008 | Tomtom GO 910 GPS Receiver
Blinking white blank display after turning on
Try resetting your tomtom by inserting a paper clip through the reset hole found underneath. One quick press is all thats needed. Charge the tomtom first now and then switch on after its had a good charge.
If this doesnt work , please reply again and i'll try and help further.
Good luck
Nov 08, 2008 | Tomtom ONE GPS Receiver
Touch screen not working. frozen
i have a tomtom xl i conected it to the computer and now the touch screen doesnt work it turns on ok and displayers the map but if i touch the middle of the screen it selects some thing else is there a way to reset the touch screen back to the centre if you can help plz email me at nissanpatrol92@bigpond.com.au
Sep 23, 2008 | Tomtom GO 700 GPS Receiver
Downloaded pictures
For a Gox20:
Both images must be 480x272 pixels big.
All images should reside at the root of the unit.
May 31, 2008 | Tomtom GO 720 GPS Receiver
Frozen tomtom
Is there a reset button? See this from PocketGPSworld.com: Reset hole The Reset hole is hard to find, you need to first remove it from the mount, turn it upside down, and within the mounting base area of GO you will see two interface slots (currently only one is being used) and towards the front of the unit on the base you will see a little hole marked reset. This is just like soft resetting a Palm or Pocket PC, it requires something small like a paperclip, and nothing was supplied with GO to enable you to easily reset the device.
Feb 25, 2007 | Tomtom GO 510 GPS Receiver
Tomtom GO 300 GPS Receiver Logo
361 people viewed this question
Top Tomtom GPS Experts
k24674
Marvin
Marvin
Archie Ferrarini
Archie Ferrarini
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
