Question about Philips HTS3400/37B System
Audio buzz i just hooked up a home theater for a friend. but the audio is buzzing. i mounted the unit on the ceiling and ran romex from plug in wall up through wall into attic. plug unit into plug in attic...buzz, plug unit into wall plug...no buzz. i checked the ground connection in attic and it was fine.
Check to see if reversing the plug takes away the buzz. Some times turning the plug over in the wall socket i.e. reversing polarity, will remove the buzz.
Posted on Jan 17, 2009
Eliminate buzz from insignia tv to bose system
It sounds like a ground loop interference issue. The equipment grounds of all devices need to be a common ground.
http://www.coreaudiotechnology.com/audio-system-grounding-and-misconceptions/
May 10, 2015 | Bose Audio Players & Recorders
I have a Philips MCD-735/37 that ONLY buzzes, no music or pictures. Please help!?
if it sounds fine in the head phones and not though the speakers - unit has a faulty pa stage
Jul 30, 2014 | Philips MCD-735 System
Just bought the RCA1023 and i have a buzzing sound trying to fix it i have it hooked to my tv through the HDMI cable i also have the audio cords (red and white) hooked up and i am still getting a very...
Buzzing is usally AC line noise leaking into an un-shielded cable somewhere or a floating ground. If the AC plug is reversible, try that. Sometimes the buzz is from an attached device. Make sure all audio cables are plugged in tightly at each end and routed away from or at right angles to any power cords and away from other sources of strong magnetic fields like TV's. I've also seen variable track lights induce noise but it's usually minor.
Try rotating the power cord in the wall outlet.
If it still does it with no cables or anything external attached it
Apr 01, 2011 | RCA Audio Players & Recorders
Have been trying to connect speakers to my samsung AV-R720 receiver but I am getting a terrible buzzing sound and only the center speaker is playing. I have lost the manual and would like to know about...
http://www.retrevo.com/support/Samsung-HT-AS720-Home-Theater-Systems-manual/id/6333ci454/t/2/
Page 10 discusses speaker connection.
Disconnect everything but the speakers and evaluate the buzz. It may be coming from external hardware or loosely connected analog cables.
Sometime juts rotating the ac plug on one device eliminates the ground loop buzz.
Feb 07, 2011 | Samsung HT-AS720ST Theater System
I have periodic buzzing from the right rear speaker
I had that followed by no audio. I had the system for a year but just hooked it up last month, used it a handful of times and it worked great...anyway, a reset didn't help so LG said to mail it in to Huntsville, Alabama along with $69.
Jan 14, 2011 | LG LHB535 Theater System
KEF Audio KIT100 System - I have similar buzzing/clicking.
if you have still the problem, I got the solution from Kef USA. It is somewhat involved in taking the unit apart and replacing a resistor and capacitor. With the instructions supplied any electronic technician or TV repair man can do it in less then 1 hour. email me and I forward the instruction in PDF: Xxel_g@mail.coX . Replace the first X with a and last X with m in my email address.
Jun 21, 2010 | KEF Audio KIT100 System
Ceiling fan
isolate the buzz: 1. completely disconnect it from the mount and have an assistant hold it...turn it on ms 2. if buzz stops, then remount using packaging foam (or wood tile under-layment foam) 3. if buzz, then electric coil for ms is faulty...new motor
Apr 09, 2007 | Hampton Bay 24002 Ceiling Fan
Philips HTS3400/37B System Logo
244 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
