Question about Whirlpool GEW9250 Electric Dryer
Code "PF" = N/A
I have a duet GEW9250PW1 electric dryer, it is just past warrantee. The machine started blowing the circuit breaker and thus shutting down. When power is restored, the code is ?PF,? no help. Have attempted to monitor to the shutdown point and have observed no other codes. Have removed vent hose to physically feel flow, the flow seems to fluctuate slightly, and the heat seems to fluctuate, is not constant. Can you aid in a direction to determine real problem? Thank you. Soft Touch PS I hooked up another older dryer to the same circuit and the breaker stays on.
  • Anonymous Apr 21, 2008
    I have changed the special fuse fuse and the circuit breaker and still PF.
    Scholar:
  • 76 Answers
Soft Touch -PF- means power failure, nothing else. Most likely the problem is not with the dryer. The circuit breaker became too weak for the dryer load. I beleive replacing the circuit breaker will solve the problem. Gendos...post back
Posted on Feb 26, 2007
Take off the front lower panel and look for lint around the sensors that are on the top of the air duct that runs from the fan to the heat tunnel. Mine had an electrical arc between a sensor and the duct, which tripped the circuit breaker. You can see a small scorch on the duct if it has arced. The dryer still works once you flip the breaker back on, but on mine, it opened the loop on the dryness sensor so that no longer works. Only solution for me is to replace the whole circuit board. Hope this helps :)
Posted on Jun 08, 2007
My whirpool dryer panel comes on but when you push the start button!, it clicks off and then displays the pf code.
PF is a Power Failure error meaning electricity has been interrupted to the machine.
Any electrical interruption to the machine such as a circuit breaker being reset or weather related power outage can cause a PF error code.
To remedy;
Press the Pause/Cancel/Stop button twice to clear the PF in the display.
Try to start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button.
If you continue to receive the PF error code, the control board may need to be replaced
Apr 23, 2015 | Dryers
Kenmore Elite Oasis Electric Dryer - no power (PF code)
Press and hold the "Start" button to restart the dryer cycle if the "PF" (power failure) error code appears. This code often appears when a cycle is interrupted before it completes. You may also check the breaker or household fuse, and ensure the machine has not come unplugged.
Read more: How to Repair Kenmore Elite Oasis Dryer Error Codes ' eHow.com http://www.ehow.com/how_7703883_repair-oasis-dryer-error-codes.html#ixzz1u
May 12, 2012 | Kenmore Elite Oasis 6808 Electric Dryer
I have a whirlpool duet # gew9250pw1 it won't
my whirlpool dryer has power but does not start
Jul 02, 2011 | Whirlpool Dryers
Have kenmore 61951 dryer PF comes on go thru the steps it turns on and then shuts off what could be the problem
PF is a power failure error meaning electricity has been interrupted to the machine. Any electrical interruption to the machine such as a circuit breaker being reset or weather related power outage can cause a PF error code. Try resetting the appliance by disconnecting it from the outlet or switching off the circuit breaker for 20-30 minutes, then restore the power. If the reset doesn't work I suspect the control board has failed.
Jan 12, 2011 | Kenmore Dryers
What does PF stand for? getting that message several times lately
What you could do is get the service panel off the base of the machine.
On the backside of it is the tech sheet which gives explanations of the codes given.
You would thin it stands for Power failure and it might just be a faulty breaker. They recommend the washer have its own dedicated line without any other things on that line. Some codes require a ground fault interupter on the receptacle near any machine that uses water in case of flooding. That could be causing the PF. themobilian_2.png
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 26, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whirlpool duet GEW9250PW1 electric dryer squeals
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Apr 06, 2010 | Whirlpool Dryers
PF singal on dryer. Can not start dryer something electrical possibe pf power failer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
Jun 03, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Dryer kicks off circuit breaker, pf code is on dryer. now won't let me do anything
pf is for power failure. sounds like You may have a short somewhere. Be careful of electric shock.
Apr 21, 2009 | Dryers
Whirlpool Duet Electric Dryer will not get hot
Here are the source codes that pop up on the dryer with the "fix" PF Power failure "PF" flashes to indicate that a power failure occurred while the dryer was running. Press HOLD TO START to continue the cycle, or press OFF/Pause to clear the display. E1 Thermistor open Replace thermistor if found defective E2 Thermistor shorted Replace thermistor if found defective
Sep 12, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool GEW9250 Electric Dryer Logo
385 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
