Question about Epson AcuLaser C900 Printer
Black cartridge noise - Epson AcuLaser C900 Printer
  • 1,141 Answers
I can t get the TV to respond to anything other than on/off I have tried from the side buttons and
Posted on May 06, 2009
Clicking noise
Check the printer thoroughly for any small pieces of paper caught on a roller in the printer. If your printer is making a grinding noise, you may have a loose gear or roller in the printer.
If the noises started shortly after you installed a toner cartridge, turn off the printer and pull out this toner cartridge. Look up into the printer where this toner went. Make sure that both the charge roller and the transfer roller are still seated in the printer properly.
  • The charge roller is a tan-colored or gray roller attached to the inside of your top lid. Remove the toner cartridge from your printer. Close the top lid halfway with the cartridge still out. You will see the charge roller come down as you lower the top lid. Make sure that the charge roller is installed correctly within the two black arms on each end and that the roller does spin freely.
  • The transfer roller is the black, spongy roller in the bottom of the printer, under the toner cartridge. Push lightly down on it at both ends to make sure it is seated properly in its housing. NOTE: Try not to touch the charge roller with your bare hands. It is susceptible to the oil and may cause a permanent fingerprint to remain on the roller surface.
  • When you have checked the charge roller and the transfer roller, look around inside the printer. See if you can find any rollers that look loose or broken inside. Also look for any loose shreds of paper. If you do find a loose or broken part, you printer will probably require service to fix the problem.
If the rollers look fine, go ahead and reinstall the toner cartridge. If the squeaking/grinding noise continues and none of the rollers looks out of place, try swapping out the toner cartridge. There is a small chance that the toner cartridge is causing the squeaking/grinding noise. If you have any extra toner cartridges in stock, try another toner cartridge and see if that clears up the noise. If you have another working printer of the same model, try swapping the toner cartridges. See if the problem follows the toner cartridge or stays with the printer.
If replacing the cartridge does not cause the noises to go away, there are a few other things you can do to help pinpoint the source of the noise.
If the noise continues on the main printer, try opening the rear exit door while printing. See if you can tell if the grinding noise might be coming from one of those rear exit rollers/gears. If it does sound like it is coming from the rear of the printer, again look for any loose or broken part or any small pieces of paper.
If you have added any additional feed options (like a tray 2 or 3 option, duplex option, or envelope feeder), please remove these options. Try printing a few prints without these feed options attached. This will eliminate one of the feed options as the cause. If the noise goes away when you remove the options, reattach them one at a time. If the noise returns on one specific option, a roller or gear on that option may be the cause of the noise.
Is your printer making a rhythmic THUMP - THUMP - THUMP - THUMP noise when printing? This noise is a side-effect of a feature called Envelope Enhance. The Envelope Enhance feature is built into the fuser unit of the printer to help keep envelopes from wrinkling. This sound is perfectly safe and normal if the printer is printing on envelopes.
If none of the above fixes eliminates the noise, the printer will probably need service to return it to working condition.
***If you need any technical help on printer then you can reach at here
Feb 15, 2013 | Canon imagePROGRAF iPF8000S 44"...
Clicking noise when printing
Had similar problem. Putting my hands on the front surface of the printer, the click seemed to be felt strongest in front of the pink ink cartridge. I took the cartridge out, looked at the back of it, where there's a little black wheel, and tried turning it. That wheel was stuck (whereas the other colors & the black would turn). Tried printing with the pink cartridge out and no more clicking noise. I guess I'll just replace my pink cartridge. Maybe see if there's a similar problem with one of your cartridges?
May 13, 2010 | Samsung CLP 300 Laser Printer
Ink cartirdge cannot be recognized even though correct cartidge was installed
Hi there
You can try this but it lots to do but may help
This message may be resolved by resetting the unit. Please follow these
steps:
1. With the printer powered on, open the cover. The ink will move to
the left hand side.
2. Push down on the end of the black cartridge. A clicking noise will
be heard.
3. Slide the cartridge out of the holder towards you.
4. Push down on the end of the colour cartridge. A clicking noise will
be heard.
5. Slide the cartridge out of the holder towards you.
6. Once both cartridges are removed, unplug the power to the printer
(without turning it off).
7. Reconnect the power cord.
8. Turn on the printer.
9. Open the cover. The carriage that holds the ink will move to the
left hand side.
10. Make sure the orange cap is off of the bottom of the black
cartridge.
11. Place the black cartridge in the bottom of the printer.
12. Slide the black cartridge back until is cannot go back any further.
13. Push up on the end of the black cartridge, a clicking noise should
be heard.
14. Make sure the orange cap is off of the bottom of the colour
cartridge.
15. Place the colour cartridge in the bottom of the printer.
16 Slide the colour cartridge back until is cannot go back any further.
17. Push up on the end of the colour cartridge, a clicking noise should
be heard.
Please note that the colour cartridge will stick out further than the
black cartridge.
Close the cover. The printer should make some noise for a few moments,
and then return to standby.
If the message persists, to clear the low ink-warning message, press and
hold down the button for at five seconds, and then release
it. This will disable the ink detection until that cartridge has been
replaced.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 10, 2010 | Canon PIXMA MP470 All-in-One Printer
Error - says can't recognize an ink cartridge
Hi there
steps:
the left hand side.
be heard.
be heard.
left hand side.
cartridge.
be heard.
cartridge.
be heard.
black cartridge.
replaced.
Feb 09, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Lexmark C510 is making grinding noises while printing large jobs
I found another posting stating that the culprit was the black toner cartridge. Sure enough I changed our black cartridge and the grinding noise has stopped. No wonder the grinding noise was not happening all the time only when the black cartridge got low. Thanks for the help!
Oct 15, 2009 | Lexmark C510 Laser Printer
Printer says, "Ink scrubber" is full and it will no longer print
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
toi-i-6
Aug 06, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Non printing epson c20ux
Sounds like color cartridge ran out. Were u using color to print black?
Try new color cartridge.
Then if you don't need color go in and set to use black cartridge to print black (text).
If you need color on something only takes a minute to turn color back on.
Since printer worked you can go in and select black which uses the black cartridge and if it prints gives validity to a bad/empty color cartridge.
Good luck.
JC
Nov 27, 2008 | Epson Stylus C20UX InkJet Printer
Printer says low level color ink fitted new ink printed ok at first but still said low ink order now and will not let me print or scan
Dear customer,
The most common solution is to follow the steps as follows
1. unplug the power cord
2. press and hold down the <ON/OFF> button and reconnect the power cord
3. press the <STOP/RESET> button 2 times and then release the <ON/OFF> button
4. Display LED show "0" press the <+> button 1 time Display LED show "1"
5. press the <Start Color > button 2 times and then press the <ON/OFF> button waitng for testing out 2 pages
6. Open the cover. The carriage that holds the ink will move to the left hand side. and then unplug the power to the printer
7. Push down on the end of the black cartridge. A clicking noise will be heard.
8. Slide the cartridge out of the holder towards you.
9. Push down on the end of the color cartridge. A clicking noise will be heard.
10. Slide the cartridge out of the holder towards you.
11. Once both cartridges are removed, unplug the power to the printer (without turning it off).
12. Reconnect the power cord.
13. Turn on the printer.
14. Open the cover. The carriage that holds the ink will move to the left hand side.
15. Place the black cartridge in the bottom of the printer.
16. Slide the black cartridge back until is cannot go back any further.
17. Push up on the end of the black cartridge, a clicking noise should
be heard.
18. Place the color cartridge in the bottom of the printer.
19 Slide the color cartridge back until is cannot go back any further.
20. Push up on the end of the color cartridge, a clicking noise should
be heard.
hope its udeful. thank you.
Jul 09, 2008 | Office Equipment & Supplies
Samsung 3160fn all in one printer. making loud clicking noise when printing
Here's what I posted in regards to my CLP 300 which had the same problem. Might be the same thing??...
Mine did this after I replaced a toner cartridge (the round ones). Here's what causes the loud clicking:
Some (most?) replacement ink cartridges have a little square chip -- like a mini circuit board -- on them which gives the printer information about how full they are. This is located on the insertion end, right next to the round black thing with the little gears on it.
For the cartridge to go in all the way, and allow the gears to properly "seat," the square "circuit board" needs to "float" just a little on the spongy thing it's attached to. So when you push the cartridge in FIRMLY, the gears seat, and the "circuit board" will end up getting pushed in about 1/16 of an inch.
I think what happens in some cases (at least with mine) is some cheap replacement cartridges don't let the "circuit board" push in at all, which means the gears don't quite seat properly, and, as they are trying to connect on the printer's gear receivers, they are constantly connecting and disconnecting, causing that loud clicking noise.
On one cartridge just pushing in the "circuit board" really hard freed it up and allowed it to "float" (be pushed in little when the cartridge was then inserted). In another case, I ended up getting a butterknife and prying off the circuit board (breaking the plastic or glue seal that was holding it) then setting back in, on top of the little spongy sticky thing it's supposed to float on.
In both cases, the cartridges were then able to go in all the way, and the clicking noise stopped.
Hope this helps!
May 05, 2008 | Samsung CLP 300 Laser Printer
Epson AcuLaser C900 Printer Logo
65 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
