I have an HP Pavilion dv6000, and out of the blue, after i shut the lid, and let it hibernate, when i open it again, it will not turn back on. The only way to get it to turn on again is to hit the "Quickplay" touch buttons above my keyboard. Then it will wake up and go into the quickplay screen, which i have to then exit. then it will go back into hibernation, then imediatly resume windows just like nothing ever happened. Also, at this same time, my sound stopped working all together as well.
  • 2 more comments
  • Seth Wright Dec 09, 2008
    im sorry, i kinda thought that it was a given that that doesnt work. as i said, the ONLY way to wake it up is as i desribed. let me know what you think the problem is. thanks!
    i using
    it totally glitched just then, sorry. i am using XP
    ok i just tried that, and its still doing it. its VERY bizaar. And why would the sound go out at the same time?
  • 4,806 Answers
Hit the on/off button to wake the machine up
regards and please don't forget to rate us once the problem is solved or you find us helpfull
Posted on Dec 09, 2008
  • Lee Hodgson
    Lee Hodgson Dec 09, 2008
    are you using XP or Vista?
  • Lee Hodgson
    go into power options in the control panel, and set your options to never turn off display or never go to sleep and monitor settings, this should resolve your settings, don't forget to save the settings.
    post back if more problems
    regards
Hp pavilion ze1115 stuck on hibernating..
Open Control Panel, Power, power settings, change power settings to high performance, Disable Hibernation, sleep. When your laptop is not in use shut it down and unplug. It will last longer and a boot everyday will reset the laptop.
Dec 17, 2012 | HP Pavilion ze1115 Notebook
Hp pavillion dv6000 shuts off and wont power back up
make sure laptop is having sufficient power on battery remove the battery and directly connect the main power and see it is switching on or not otherwise connect the battery and connect the power adopter and don’t switch on the laptop keep for 10 minutes and then switch it on.
Jan 15, 2010 | HP Pavilion dv9000z Notebook
I have an HP dv6000 laptop computer, and, starting last week, the laptop acts like it's turning on (all the lights illuminate, fan starts for a second) but nothing on the screen, and then the laptop turns...
Common issue on HP dv6000. You will need to get to the GUP and reflow it with a heatgun. Try this hp pavilion repair guide. It contains step by step instructions on how to take apart the system and fix the issue with the video. www.msbin.com/hp
Dec 18, 2009 | HP Pavilion dv6000 dv6100 dv6200 dv6300...
I have a hp pavilion dv1000 laptop and it randomly hibernates
Go to the control panel > Power Options, click on the hibernation tab and uncheck it. Click on apply and ok. Hibernation can damage older HP systems such as the DV1000 that is running XP, make sure it is turned off and also go through the power settings and change the setting for closing the lid on the laptop. Change the setting to "Do Nothing". This will keep your system from getting corrupt.
Nov 26, 2009 | HP Pavilion dv1000 Notebook
HP Pavilion PC blue screen shutdown and startup problem
the blue screen is known as the Blue Screen of death
refer to this article
http://pcpills.blogspot.com/2009/05/escape-blue-screen-of-death.html
Aug 07, 2009 | HP Pavilion tx1000z Notebook
My battery is at 0% and does not charge and whenever i take out the power chord my computer automatically turns off. Any help
here is a good resource I found:
Solution for HP Pavilion DV6000 Battery Not Charge
  • Reinstalling the power management software has just fixed it for me. Go to device manager and under batteries, unistall the Microsoft ACPI Compliant Control Method Battery. Go to Actions on the menu bar and select ’scan for hardware changes’. It will reinstall it and hopefully start charging immediately (mine did anyway).
  • If your HP Pavillion dv6000 has a battery that won’t charge yet still turns on when plugged in, turn off the laptop and remove the battery then wait for around 30 seconds, re-insert it and turn it back on, the charging update should say, plugged in, charging.
  • I made the bios update, and works for me. My Dv6000 battery problems were fixed. The battery led always blinking every time and the battery didn’t charge. Now it’s ok !
    http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01087277&lc=en&cc=us&lang=en&dlc=en&product=3245619
  • If it is still under warranty you can chat with an online hp tech who will check it out over the internet and send you a replacement for free. the dv 6000 laptops have a recall on a few problems and there is a bios update to fix it before it happens but will not correct it after the fact the recall on specific problems extends the warranty to 24 months http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01087277&lc=en&cc=us&lang=en&dlc=en&product=3245619 should get you to the warranty page.
  • Just got it to charge again.While the laptop is powered and in Windows XP, press and hold the POWER button until it dies. Then, remove the dv6000 laptop battery. Power it back up and enter Windows. Then, re-insert the battery.
  • So I always remove the Hp dv6000 battery after I have powered down the laptop, and I have not had any battery problems since then!
  • I had the same issue my fix was a new cmos battery that was only $10.00 and install updated bios software from HP
  • I had the dv6000 battery problem where it showed my battery NOT CHARGING. I took it apart because my QUICKPLAY would not work either and the QUICKPLAY lights stayed on even after I shut down the laptop. I found that the black ribbon cable on the right (the other looks the same but you can see it is for the power button) was slightly kiltered in the flat socket it goes to underneath the area where the quickplay button is. I straightened it out and made sure it was pushed all the way in and locked and put it all back together and everything worked perfectly after that. About a month before that my POWER and SOUND didn`t work. I did the same thing to fix those problems. MAKE SURE YOU HAVE THOSE CABLES EXACTLY RIGHT in there, IT MAY JUST BE YOUR PROBLEM TOO.
  • Some people dont realise that you should avoid short charges and discharges, if your batery does not go above 40% mabe its charge memory thinks its full. to fix this problem let the batery run fully down, then charge it all the way again. try it a few times if it doesnt work. and you have to go all the way, not let windows go into hibernation. to do that you need to get the batery low, then boot to some boot disk and let it sit till the batery dies.
  • HP has posted BIOS updates to address battery problems as well as the auto startup on some.If you will post the full model number,someone can help you find your driver/updates page.
Hope this helps, please rate! ^_^
Jun 23, 2009 | HP Pavilion dv6000z Notebook
Locks screen when I close the lid on my hp pavilion dv9740us
computer has gone into hibernation. Best to shut that function off, and replace with standby.
If you want it to hibernate, press the power button once, and it should come back on to the log in screen.
Mar 14, 2009 | HP Pavilion DV9740US Laptop
Shutting down ,HIbernating
open control panel then display then click screen saver
then power at bottom of page In there you will find Hibernate and other settings that you can change you can disable able hibernate standby and sleep
Then click apply
restart let me know if this was helpful
Jan 19, 2009 | HP Pavilion dv9000z Notebook
AUTO SHUT OFF HP DV6000
Youre cpu heatsink is clogged with dust not breathing properly and causing it to over heat and shut down.Must remove keyboard heat sink should be on top right removed heat sink and clean dust .Use air can and spray whole laptop.
Oct 02, 2008 | HP Pavilion dv6000z Notebook
Hp pavillion laptop dv6000.
have you tried hard reset? means holding down the power bottom until it shuts down.
Feb 10, 2008 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
David Payne
David Payne
