Computers & Internet Logo
Posted on Jul 07, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My admin password i forget how can i open my pc without using hackin softwer thanks
Anonymous
Level 1:
  • Contributor 42 Answers
  • Posted on Jul 09, 2012
Anonymous
Contributor
Level 1:
Answers
42
Questions
0
Helped
16888
Points
83
What OS are you having?
On XP you can try this:
Boot computer and press Ctrl+Alt+Delete twice when you See Windows welcome screen / login screen. It'll show classic login box. Now type "Administrator" (without quotes) in username field and leave password field blank, press Enter and you should be able to login Windows.
Now you can reset your account password from "Control Panel -> User Accounts".
On Win 7 or Vista:
Ctrl+Alt+Delete won't work, you have to use some windows password recovery software. I recommend Windows Password Reset
Learn more methods: http://www.windowspasswordreset.net/article/article.html
Brett
Level 2:
New Friend:
  • Expert 125 Answers
  • Posted on Jul 07, 2012
Brett
Expert
Level 2:
New Friend:
Answers
125
Questions
Helped
29125
Points
283
You might try removing the cmos battery for 10 minutes or so Usually it does not take that long. This will set the pc back to original default settings, the date will be wrong also make sure you enter the right date before booting if you are able to enter bios after the battery. Make sure the unit is unplugged and if it is a laptop remove the main battery. the cmos battery is usually the size of a quarter.
3 Related Answers
jmgldsmth
Jim Goldsmith
  • 2005 Answers
  • Posted on May 28, 2009
SOURCE: please help me bios password, which is admin system dell latitude D620
remove the laptop and, bios battery wait 10 minutes then reconnect the bios battery and repower with the power supply
Anonymous
  • 499 Answers
  • Posted on Jun 08, 2009
SOURCE: I forget my administrator password for lenovo laptop using visita
restart ur laptop -> hold F8 buton till a list of safe mode appear->move ur up or down arrow to move the highlight on safe mode->enter as Administrator
Anonymous
  • 112 Answers
  • Posted on Sep 23, 2010
SOURCE: I have passed without using my laptop and the when
sorry no other option :(
2helpful
2answers
Forget Admin password in Windows 8
If you can sign into your Windows 8.1 using another admin account, you can also reset password to login Windows 8.1 free from the command prompt. Go back to Windows Password Recovery tool if you don't have another admin account. Press "Win Key+R" and type "cmd" in the "Run" command box and hit enter to open command prompt. Type the command "net user UserName NewPassword", in the command prompt and hit "Enter".. If you want to remove this password, just replace NewPassword with *.
How to install a router without a cd
1)hardline connect (no wireless)
2)look up your default gateway ip
3)open browser (IE, chrome, safari, whatever)
4)type in your default gateway ip (maybe 192.168.1.1 or something)
5)type in the username and password (admin, admin or admin, password or admin, blank)
6)select wireless
7) SSID is the name of the network and i usually select WPA WPA2 mixed for password type
8)don't forget to save changes
8helpful
2answers
How do i set a password
Setting the router's administrator password
All Belkin Router's ship without an admin password. If you require an admin password then follow the below instructions.
Setup steps:
  1. Connect the computer to one of the four LAN ports on the router.
  2. Open a web browser on the computer.
  3. In the address bar of the web browser, type http://192.168.2.1
  4. Click Login in the upper right-hand corner of the page. The router does not ship with a password, so just click Submit.
  5. Click on System Settings under Utilities on the left-hand side of the opened page.
  6. You will see a feature called, "Administrator Password". Type in your current password (default leave blank).
  7. Click "Apply Changes". Your new password is now active.
Note: Do not forget the new password and keep it somewhere safe. If you forget your password, you'll be unable to access your router's settings. If you forget or lose your password, you'll need to "Perform a hardware reset on the router". This will reset the password to its default, as well as erase any and all other settings you may have changed.
3answers
How do I set a password? I've been using this router for years without one... thanks
Connect Wired cable to the linksys Router via PC/Laptop
Go to browser and point to IP address 192.168.1.1 (Can be different if manually changed)
Default username : admin password: admin
Go to Wireless TAB -> Security
Select Security type as WPA2 or WPA (WPA2 preferred)
Select passphrase as YOUR KEY
Make sure to click Apply afterwards.
You have now a password on your SSID.
1helpful
2answers
Hi i forgot my mac password what do i do
Here’s how to create an admin account without knowing the current administrator password.
This is nothing new to people familiar with unix, and can’t really be classified as a “hack”, but it’s an easy way to make an admin account without a password. This particular method is used if you, for some reason, can’t get into your account at all, for example: you lost MAC Admin password and you account is protected with FileVault. This process basically forces your computer to re-run setup, which is what you see when you setup a new Mac.
This process will take about 5-10 minutes. If you have a password, or WEP code for your network or internet, be sure to have that at hand.
Source: http://www.macpassword.com/mac-admin-hack.html
3answers
Reset password
Unfortunately we can't remember it for you
Can not open wizard
You can reset your router.
To reset your router, use the following steps (from http://technicallyeasy.net/2008/02/how-to-reset-d-link-di-524-wireless/):
  1. Press the reset button [the tiny button on the back of your router, marked Reset] for 10 seconds. You can use a small object, such as a paper clip to hold down the button.
  2. Do not power off the unit while the router is being reset.
    The unit should now reboot, and once the WLAN light stops blinking the router should be reset.
  3. Open up your Web browser and enter 192.168.0.1 in the address bar.
  4. For the login, enter admin as the ID and leave the password blank.
The router has now been reset. Follow the steps in Securing D-Link DI-524 Wireless Router to secure your router.
admin username: admin
Default admin username: admin Default admin password: <blank>
Forgot password can not use my computer
Format the pc and choose repair... from the blue screen it will install only program files and it will rest the. admin password
if any problem ask me
1helpful
Administrator password brake without third party softwere used
need to reformat your PC. Maybe its a virus which closes admin password. I also encountered same problem and i reformat it and then it fix my pc.
Grand Canyon Tech
Grand Canyon Tech
