Question about Kitchen Ranges
Beaumark Millennium stove. Stove it's not working.
Power is on 240v on both phases and when stove it's turned on shows heat 350.
But theres no heat. I've checked both elements they are
ok,same resistance value.
Thank's
jack.
fridgetech
  • 473 Answers
SOURCE: Maytag Gemni Stove
The problem is either in the oven control or the element (in some cases could be both). You will need a meter to check the resistance on the elements as well as power to the element. Remember this is 240 volts and very dangerous. If your not comfortable with it call a professional.
Posted on Oct 08, 2007
SOURCE: Stove elements won't turn off
replace switch for that burner
Posted on Jan 17, 2008
jsrock516
  • 5911 Answers
SOURCE: One element on my KitchenAid
Sure can. One element can easily be replaced. If your model number is correct, you can find replacement parts at searspartsdirect.com. Type in your model number in the Search menu and the surface elements can be found under the "Cooktop Parts" heading. I do not know which element you have that is bad, but they are identified as item 12 and by wattage rating. Use care when selecting to make sure you identify the correct element. The smaller elements have a lower wattage rating than the larger elements. There's also an illustrated view for easy part identification. Some parts come with directions on how to replace. If no instructions are available, or if you need further guidance, go to my profile page and click on "Tips and Tricks. I have a write up listed there on how to replace a glass cooktop. Those same instructions can be used to replace a single element. Instead of removing all the elements and cooktop, you will only have to remove and replace the one element. Just make sure you unplug the range before starting and handle the elements with extreme caution. They are considered fragile. It may also help to have a second person assist. I hope this answers some of your questions. If you need further assistance, please post back and let me know.
Posted on Apr 21, 2008
dragonsthatk
  • 547 Answers
SOURCE: my mother inlaws beaumark stove
re-start selfclean and let it finish it unlock automatic
Posted on Feb 11, 2009
heavyice
  • 374 Answers
SOURCE: My Beaumark Stove is from
there is a lock for each hinge
lay the door down with hinges facing up.take a towel pull long piece
of hinge toward you(BE CAREFUL) take other piece up and lock them together do the same to the other hinge it should then go on easy next time lock before taking off .These are the instruction on how to remove and replace the door, be sure you locate the removal pins to being able to put it back
This [link] http://tinyurl.com/kogjg3 should help you out.[link] http://tinyurl.com/mzgjtq is added to the hold the hinge in place on the self clean doors. The screw and bracket have to be removed to remove the door and hinges. The metal clip bracket has to be reinstalled once the door is put back on. To reinstall the [link] http://tinyurl.com/mszglp just do the opposite, start the hinge blade in the receiver, lift slightly on the door and with your knees push the door and hinges back into place. One thing most people forget about these hinges is that there is a clip that must be moved to hold the upper (A) and lower (B) parts of the hinge together. Once the door is put back on, the clip must be put back in the rest position. To reinstall the door, put the door at a 80degree angle to the range front, push in the larger upper hinge parts first and then lower in the smaller hinge parts, push the clips forward into the rest position and close the door.
On this [link] http://tinyurl.com/lg76wg one common problem is the hinge will sometimes "pop" forward against the range instead of staying still while you reinstall the door onto the hinges. If this happens, use a screw driver at the marked spot to help hold the [Link] http://tinyurl.com/kren2c so you can start the door onto the hinge, them remove the screwdriver to finish installing the door.
I hope it helped.
Posted on Jun 11, 2009
220 stove has nothing hooked up to the neutral
TURN OFF POWER TO THE STOVE OR UNPLUG IT IMMEDIATELY BEFORE TOUCHING **ANYTHING**. I need the make/model of your unit to help you accurately. HOWEVER, the first thing you need to do is(and this applies if I'm interpreting you correctly)replace the power cord--it will be connected to the terminal block--on the vast majority of ovens, you have a left-hand terminal, generally known as L1(a power wire), a center terminal(*normally* the neutral connection), and then the right-hand terminal, generally known as L2(2nd hot supply wire). Take a picture of the AC outlet so you can purchase the correct power cable for your stove. Also, take a picture of the terminal block in the rear of the stove just to make sure. I'm assuming that the wires are all connected in the stove but the neutral wire is either broken or missing from the power cord. Due to how most ovens operate, THIS IS A VERY DANGEROUS CONDITION. When the unit is plugged in, even though the oven is off, there is still 120v applied to the heating elements. When you turn on the oven, instead of being connected to a ground, the other side of the heating elements are simply connected to 120v from the other side of the panel, adding up to 240v and the elements heat up. I hope this helps you!
Aug 13, 2015 | Kitchen Ranges
No heat from burners or oven after relocating stove
Hi Ron - From what you have described if neither the burners nor oven turns on make sure the electrical connecting is 240V. The oven light and clock portions only required 115V. The clock and oven light working may indicate an electrical circuit breaker supplying the range is tripped or a fuse is blown. Confirm household circuit is correct and the range cord is properly wired to the terminal block.
Sep 16, 2012 | Frigidaire Gallery GLEFM397DS Electric...
After a kitchen remodel my stove top is getting power but the burners are not working. What should I look for in my wiring? Thanks
It is possible only one of the hot wires is still hooked up ....then it couild look like you have power nut the 240v power is not there for the heating elements... only the 110v power to the controls...
Check for 240v power at the back of the unit where the power enters...
heatman101
Jan 06, 2011 | Jenn-Air Microwave Ovens
I have 4 -wire 3 phase 220 vac. which is one leg of 240vac, 2 legs of 120vac, and one ground wire On the Stove terminal block I have from left to right on the terminal block at them rear of stove Black,...
First of all I would assume you don't have three phase. Three phase is defined as 208v, 120/240, 240/480 or straight 480v and is used commercially.
Most likely you have a single phase service coming into your house unless you have an elevator or something that would require 3 phase.
A single phase service consist of 2 - 120v legs = 240v and one neutral, if you put a meter across both 120v legs you'll get around 240v and if you place your meter across one leg and your neutral you'll get 120v (not exact but in the range of 124v) Your range will have usually three connectors, red, black and white. So if you run #6 3c with ground, you will have red, black, white and green (its either green or bare). Connect the colors accordingly. You could even have a range that would work off what they call range cable it's legal in most states, which consist of 2 black wires incased in a bare neutral strand and wraped in usually gray insulation, electrical codes vary state to state county to county. The range should have a manual that would tell you what the rating of the electric stove is, such as 40 or 50 amps. 40amp is commonly #8 wire and 50amp is usually #6. I recommend site unseen in using the #6 wire.
Dec 21, 2010 | LG LRG30855ST Stainless Steel Gas Range
Ge jsp42 electric range ..Oven heats up very slowly..sometimes can take one hour to heat to 400 degrees..Stove top also slow..
Check the voltage at the outlet. It should be 208v or 240v. check by putting meter probe into the 2/3 slots. NOT the U shaped,or round looking holes.Check one to another. Check tag on range for voltage of range. If you have 208v at the outlet and range is 240v the oven will take forever to heat, it is not getting the power it needs. If the tag says 230v either will work. On the oven tag it will say either 1ph, or 3ph. If it says 3ph you outlet should have the voltage mentioned above between ALL 3 SLOTS! If you get 120v when testing any slot, you have only 1ph of power. Keeping it simple, the ph, (or phase,) between the outlet and oven have to be the same.
Mar 31, 2010 | GE JSP42 Electric Kitchen Range
Stove burners don't get hot enough and the oven takes a long time to preheat
sounds like its wired incorrectly .. the stove operates on two phases of 120 volts each .. together they form a 240 volt supply .. if its wired incorrectly you may be getting only 120 volts .. it will then take 4 times as long to heat .. have an electrician or someone skilled in that sort of thing, check the voltage at the plug .. and make sure the pig tail is attached correctly to the stove .. check the circuit breakers .. there is one for each phase .. but if one is tripped then some functions wont work at all unless there is a second problem (shorted phase) in which case it will work but have the 4 times as long to heat problem and it will trip the circuit breaker immediatly .. ..
Oct 01, 2009 | Frigidaire Ovens
The cooktop and oven won't come on and seem to have no power. The clock still works.
You only get one juice from one one of the two hot wires. Or both of your hot wires are of the same phase, which is unlikely if it is worked before.
Measure the voltage of each hot terminal and across both terminals. Each one should get about 120v and 240v across. If it looks good, open the back of the stove. Measure the voltage along the way up to the dial switches, when all the burners are in off positions.
In the back of each dial switch for each burner, there is two hot wires. Do you get 240v across it? If you do, then it is not stove. It is in the outlet to the service panel. Something get disconnected as more current is drawn. Perhaps, one of the wires get partially corroded.
Apr 14, 2009 | Frigidaire FES367 Electric Kitchen Range
MY HOTPOINT SELF CLEANING STOVE
how do I get my self cleaning to come on in my hotpoint stove
May 22, 2008 | Ovens
Beaumark stove
I also don't have a manual, but work on computers so tried some buttons and they did the trick.
On the left hand side is the button that has Mode, and then a series of buttons.
On the right hand side there is a series of buttons, and one looks like heat coming from the bottom. Turn this button to that setting.
On the left side, press the mode button, and then press the button that looks like a thermometer. This is the mode for setting the temperature of the over.
Beside the display windows, there is knob that looks like a dial on an analog clock. Turn this dial until the temperature you want appears.
Oct 23, 2007 | Ovens
Kitchen Ranges Logo
48 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
