Question about Kodak Carousel 4600 Slide Projector
Button worn and stuck
I need to open the machine and remove the forward button.  I removed the case screws but the front plate is holding outer case together.  Is there a trick to this?
    President:
  • Kodak Master
  • 412 Answers
There are a series of molded plastic "hooks" on the top & bottom case running along the handle seam. Once you get the 6 bottom screws out, carefully (!) work a large flat-blade screwdriver between the case halves as it opens, working toward the handle. With careful application of pressure, the handle seam will pop apart. These hooks were only in the very first from production Carousel 4xxx & 5xxx and the Ektagraphic III series. Now you know why they were removed - - it's a pain to get the projector open !!!
Posted on Jan 05, 2011
Nelco sewing machine 234F - stitch length knob wont turn
My Nelco Sierra 234F stitch length dial was stuck. Turns out it's pretty easy to repair if you are handy with tools.
Remove top of the machine. Remove set screw holding stitch length mechanism to body about half-way down inside. I loosened the screw and used a magnet to retrieve the screw and washer. Gently pull mechanism out the front, jiggle a bit to disengage rear cylinder from lever and pin inside body. When out remove two screws holding rear cylinder to mechanism and remove, note that the opening in the cylinder should be up when the dial is set to "button hole."
Remove the small snap ring holding the reverse button push rod and spring and pull it out. Remove snap ring holding outer cylinder onto inner cylinder...this probably requires a snap-ring removal tool.
Work the outer cylinder free from the inner cylinder by using lubricant (maybe let it sit over night), twisting with a wrench, whatever it takes. The problem is that the oil/grease between the two cylinders has dried out and become sticky.
Once the outer cylinder is off clean everything and verify the cylinders turn freely when assembled. Lightly file the cylinders smooth if you gouged them when taking them apart. Lubricate with oil or light grease, reassemble and reinstall the snap ring. Reinstall reverse button push rod, spring and small snap ring. Reinstall rear cylinder with the two screws, note orientation of opening in rear cylinder.
Installation is a bit tricky, you have to turn and wiggle the mechanism to get the pin on the lever to enter the side opening of the rear cylinder. Lifting the lever and pin mechanism from the top can help by moving the pin rearwards. It took me a few tries.
Once it's in orient the set screw hole in the outer cylinder under the set screw opening in the body and reinstall the set screw and washer (I used a magnet to lower the pair into the screw hole).
Reinstall cover and you are good to go. If you drop the set screw or washer remove the bottom and retrieve them, or fish them out with a magnet if you can see them.
Jun 01, 2012 | Sewing Machines
ReMove faceplate
Remove the Outer Case Panel on the side by removing the screws on the back that holds it. Now once one side of the case is removed, look down the front on the metal part of the case. You will probably see the plastic catches or hinges from the face plate, push them in to release them and you can remove the face plate.
Apr 11, 2012 | E-Machines D2046 PC Desktop
Kenmore top-loader washing machine is leaking water (6yrs old)? Replaced the hoses and drain line already
If the leak is front and center under the machine, it may be a pump hose leak, but my guess is the impeller has worn through the pump case. Disconnect the power and prop the front of the machine up enough to see under the front. The pump is front and center, mounted on the front of the motor. Use a flashlight to inspect the front of the pump for a curved wear spot on the front of the pump case. If this is the problem and you want to fix it yourself, the pump is available from www.sears.com under the "parts direct" tab. If its just a hose, they are available there also. You'll need your model number, usually found at the back of the main case under the lid. If self fix is possible, here are directions to remove the outer case.
Disconnect the power cord. There is either two screws, one at each front corner, holding the control panel in place or hidden clips. 1. If you see the two screws remove them. If no screws are visible you have a clip at each front corner of the control panel. The best tool to use to unhook these clips is a putty knife. Push the putty knife between the machine top and the control panel at either outer corner. You will feel a spring tension. Push firmly, but not to forcefully toward the back. When the spring releases the corner will lift easily. Repeat at the other corner. 2. Now, if there was two screws holding the panel, remove the two screws at the top on the back of the control panel. If just clips, simply and carefully roll the control panel over the back. 3. Unplug the wire that connects the control panel to the machine top. Stop here and take note as to how the case connects to the back panel. There is an aligner there that will be your hardest part to deal with later. This will help when reassembling. 4. OK, Put a slotted screw driver into the clips at the back corners on the top and release them, once again take note to their positioning. The outer case hooks under the front of the frame and the sides have a slot that goes over a pin near the back of the frame side. (Front under, sides on top of frame)Tilt the case up on back and pull forward. Congrats you are there. Make needed repair and reassemble reversing procedure. Good luck.
Nov 07, 2009 | Avanti W851 Top Load Washer
90 series washer leaks underneath
It may be a hose leak, or the impeller has worn through the pump case. Disconnect the power and prop the front of the machine up enough to see under the front. The pump is front and center, mounted on the front of the motor. Use a flashlight to inspect the front of the pump for a curved wear spot on the front of the pump case. If this is the problem and you want to fix it yourself, the pump is available from www.sears.com under the "parts direct" tab. If its just a hose, they are available there also. You'll need your model number, usually found at the back of the main case under the lid. If self fix is possible, here are directions to remove the outer case.
Disconnect the power cord. There is either two screws, one at each front corner, holding the control panel in place or hidden clips. 1. If you see the two screws remove them. If no screws are visible you have a clip at each front corner of the control panel. The best tool to use to unhook these clips is a putty knife. Push the putty knife between the machine top and the control panel at either outer corner. You will feel a spring tension. Push firmly, but not to forcefully toward the back. When the spring releases the control panel corner will lift easily. Repeat at the other corner. 2. Now, if there was two screws holding the panel, remove the two screws at the top on the back of the control panel. If just clips, simply and carefully roll the control panel over the back. 3. Unplug the wire that connects the control panel to the machine top. Stop here and take note as to how the case connects to the back panel. There is an aligner there that will be your hardest part to deal with later. This will help when reassembling. 4. OK, Put a slotted screw driver into the clips at the back corners on the top and release them, once again take note to their positioning. The outer case hooks under the front of the frame and the sides have a slot that goes over a pin near the back of the frame side. (Front under, sides on top of frame)Tilt the case up on back and pull forward. Congrats you are there. Make needed repair and reassemble reversing procedure. Good luck.
Oct 01, 2009 | Kenmore 24032\24036 Top Load Washer
I HAVE A KENMORE WASHER THAT IS LEAKING IN THE BOTTOM.
It may be a hose leak, but my guess is the impeller has worn through the pump case. Disconnect the power and prop the front of the machine up enough to see under the front. The pump is front and center, mounted on the front of the motor. Use a flashlight to inspect the front of the pump for a curved wear spot on the front of the pump case. If this is the problem and you want to fix it yourself, the pump is available from www.sears.com under the parts direct tab. If its just a hose, they are available there also. You'll need your model number, usually found at the back of the main case under the lid. If self fix is possible, here are directions to remove the outer case.
Disconnect the power cord. There is either two screws, one at each front corner, holding the control panel in place or hidden clips. 1. If you see the two screws remove them. If no screws are visible you have a clip at each front corner of the control panel. The best tool to use to unhook these clips is a putty knife. Push the putty knife between the machine top and the control panel at either outer corner. You will feel a spring tension. Push firmly, but not to forcefully toward the back. When the spring releases the corner will lift easily. Repeat at the other corner. 2. Now, if there was two screws holding the panel, remove the two screws at the top on the back of the control panel. If just clips, simply and carefully roll the control panel over the back. 3. Unplug the wire that connects the control panel to the machine top. Stop here and take note as to how the case connects to the back panel. There is an aligner there that will be your hardest part to deal with later. This will help when reassembling. 4. OK, Put a slotted screw driver into the clips at the back corners on the top and release them, once again take note to their positioning. The outer case hooks under the front of the frame and the sides have a slot that goes over a pin near the back of the frame side. (Front under, sides on top of frame)Tilt the case up on back and pull forward. Congrats you are there. Make needed repair and reassemble reversing procedure. Allow 30 to 45 minutes for the first removal. Good luck.
Aug 25, 2009 | Washing Machines
10 year old Kenmore series 80
Aug 10, 2009 | Kenmore Washing Machines
Kenmore washer 70series
It may be a hose leak, but my guess is the impeller has worn through the pump case. Disconnect the power and prop the front of the machine up enough to see under the front. The pump is front and center, mounted on the front of the motor. Use a flashlight to inspect the front of the pump for a curved wear spot on the front of the pump case. If this is the problem and you want to fix it yourself, the pump is available from www.sears.com under the parts direct tab. If its just a hose, they are available there also. You'll need your model number, usually found at the back of the main case under the lid. If self fix is possible here is directions to remove the outer case.
Aug 07, 2009 | Kenmore Washing Machines
How to change a door seal on a hotpoint wma58
Firstly remove band holding front of seal then remove the screws from the door lock and push lock through.
Remove kick plate from bottom of machine &take out 2 screws holding front of machine.
Remove soap drawer &take out screws behind it then bring facia forward & slide to right to remove. Take care at this stage not to disturb wiring on cicuit board. An extra pair of hands would be helpfull to hold it.
Remove screws holding front as you did at bottom then lift and remove front panel.
Seal is now easily accessed.
Post back if any further assistance needed.
Thankyou for using Fixya.
Jan 26, 2009 | Hotpoint WMA58 Front Load Washer
Need to remove case of hotpoint wma 63
The drum comes out through the front on this one.Take off kick plate and remove screws holding front panel to frame. Take out soap drawer & remove screws behind it. Take off band holding door seal & peel seal back.Remove 2 screws holding door lock &push lock through. Pull control panel forward at left side &slide to right to remove being carefull with board & wiring.Remove screws holding top end of front then lift slightly &remove front.Remove back panel &take wiring off heating element & pump. Disconnect the pump hose at the drum end, disconnect the hose from the soap dispenser, note that wiring is fastened to the drum at several points and will need to be disconnected. Remove panel from behind control board then carefully move everything away from the front of the machine, the drum can now be lifted clear.
Forgot to mention unplugging motor but common sense will prevail.
If you need any further assistance please post back
Good luck & thanks for using Fixya
Nov 27, 2008 | Hotpoint WMA64 Front Load Washer
I cannot open my compaq evo d51s, any ideas?
I just removed one of these cases.
The silver face-plate is attached to the cover that you wish to remove. The black plastic just below the silver is a part of the base.
  • With the face of the computer towards you, place your thumbs on the black plastic below the face-plate.
  • Use your fingers to press into the side-buttons.
  • Using your thumbs to push against the base, pull the cover towards you.
Nov 20, 2008 | Compaq Evo D500 PC Desktop
Kodak Carousel 4600 Slide Projector Logo
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
