Ricoh 2035/Savin 4045
Hi Blueyd,
I noticed you seemed very knowledgeable on these machines. I used to lease an Aficio 2022, and now bought a used Ricoh 2035, marked as a Savin 4045. I have the owner's manuals in pdf, and I know I should be able to do this, but I just can't get to print to the machine. It is connected to the network (we've only got 3 computers in our small office) and I've checked the IP address, etc. but I still can't see it on the network. Any help?
Kevin
Pottstown, PA
  • 3 more comments
  • Kevin Giza
    Kevin Giza Dec 09, 2008
    Sorry, running winXP. I have the IP address, gateway and subnet all set to Auto DCHP,
  • Kevin Giza
    I know how to find IP address and subnet, but not gateway. Advice?
  • Kevin Giza
    Kevin Giza Dec 11, 2008
    Blue,
    I put all of that info into the copier and many of the settings are set for AUTO, and it is definitely connected to the network, but I cannot Add it as a printer. I've downloaded and installed the driver set, but still can't see the printer under Control Panel - Add Printer.
  • Kevin Giza
    Interestingly enough, the manuals are not very detailed, or should I say, they are detailed if one has a really good understanding of their copiers. Like I said, I know I'm 90% there, I just can't grasp the last 10%. I've powered down all items including router, just to be sure, tried another network and router, and I can EVEN PING the copier and it answers with no loss, but just can't add the printer in control panel nor see the printer under My Network. That's what has me wondering.
  • Kevin Giza
    Kevin Giza Dec 17, 2008
    Got it. Got it. Got it!! Luckily I had an old computer which was connected to the copier I used to have at another location. IT'S the PORTS! After installing the printer drivers, one has to ADD a port, specifically a TCP/IP port when trying to add the printer in Control Panel. So you go to Add Printer, Local Printer (even though it is actually connected via the network router), Create a Port, TCP/IP port and then add the IP Address from the copier/printer and viola, printing!!!
Sending the data has failed. What it means on savin 4045, scanning
Posted on Jun 02, 2010
    Problem Solver:
  • 13 Answers
What kind of op. systems are you running on your computer. Besides the IP address is the gateway and the subnet mask right?
Posted on Dec 09, 2008
  • 1 more comment
  • Cherie
    Cherie Dec 09, 2008
    turn off auto dchp and put it in the info. manual that should work
  • Cherie
    Cherie Dec 09, 2008
    http://www.more.net/technical/netserv/tc...
    Here is how to find all of your info. Hope this helps.
  • Cherie
    Cherie Dec 11, 2008
    Go to user tools and double check to be sure you have the printer option. Kinda hard to see what actually options you have.
    Problem Solver:
  • 13 Answers
Go to www.ricoh-usa.com from there you can pull up the user manual and it should walk you thru the process. And what drivers did you download? And are you using PC or MAC. Also when putting in the addresses the DCHP is suppose to be off.
Posted on Dec 11, 2008
What's your question? I HAVE AFICIO 2022 COPIER AND ITS GIVING ME THREE ERROR CODES SC548, SC792, SC870 WHAT COULD BE THE PROBLEM AND HOW CAN I SOUGHT IT OUT
some potentially useful information can be found here: what the error codes mean, and the services manual; (I have pointed to error code 792 but the others are different pages), there is a copy of the service manual too. This is only a starting point !
http://printcopy.info/?l=en&mod=free&chap=erc&brand=Ricoh&model=Aficio 2022&page=6
(link hasn't copied well, last line is part of it)
Try also this
http://copierliquidationcenter.com/Copier_Repair_Service/index.php?topic=44.0
for Error sc792 see
http://www.copytechnet.com/forums/ricoh-savin-gestetner-lanier/35515-ricoh-aficio-2022-a.html
for sc870
Thread Ricoh 2238c SC 870 Address book error
for sc548
Thread RICOH Aficio MP C3500 Error Code SC 548 and 549
hope that lot help :)
May 25, 2016 | Office Equipment & Supplies
SC392 ERROR CODE
There's a video showing how to clear SC error codes: Resetting Ricoh Savin Lanier SC Error Code There's also a discussion here: Thread Ricoh Aficio 220 error SC392
Jun 30, 2014 | Ricoh 885288 Black Copier Toner Cartridge...
How do I clear error sc546 on a Ricoh Aficio 2035
replace thermostat in heating section or u yuor tirmistor is directly touching the heat roller
Feb 13, 2012 | Ricoh Aficio 2022 Black and White Copier
Looking for an owners manual for a Ricoh Aficio SP 2022
I do not have a manual for the Aficio 2022SP. However, there is a manual for the Ricoh Aficio 2022 available as a PDF here: http://www.ricoh-usa.com/downloads/local/manuals/multifunction_bw/aficio2022-27.pdf . If the direct link doesn't work, start here: http://www.ricoh-usa.com/downloads/downloads.aspx?d=pm and search for the 2022.
I hope this helps.
Feb 11, 2011 | Office Equipment & Supplies
Change ip address at ricoh aficio 2022
Hi, to change the IP address of a Ricoh Aficio 2022, follow these steps:
- Press the User Tools/Counter button.
- Choose System Settings.
- Choose Interface Settings.
- Choose Network.
- Choose IP Address.
- To specify an IP address, choose Specify, and then enter the address you want to use. To have DHCP automatically assign an IP address, choose Auto-Obtain (DHCP).
- Exit out of the User Tools screen.
Dec 15, 2010 | Ricoh Aficio 2022 Black and White Copier
Error code 320 on startup
SC320, THE ENGINE POLIGONAL OF THE UNITY LASER DOES not TURN PROPERLY BY DAMAGE, HAVE TO CHANGE IT BY ONE NEW.
Apr 06, 2010 | Ricoh Aficio 2022 All-In-One Laser Printer
Ricoh aficio firmare
You must have a Ricoh tech ID in order to download machine firmware. You can get the firmware from Ricoh's tech website, TSCWeb.net if you have a valid Ricoh ID.
Jan 29, 2010 | Ricoh Aficio 2022 All-In-One Laser Printer
Do you know where i can get a ethernet card for a dsm645 cheap or used?
Does you machine currently have the print option and the NIC has just gone bad or are you wanting to add print?
If your NIC is bad keep in mind this machine is the same as Ricoh 2045 or a Savin 4045. You will need to pay close attention to whether you have a 645SP or a 645ESP. The Print Controllers/NIC's are different for the E series.
Just search Ebay or Google for the Ricoh/Savin models and you cand find them. I just bought and installed one from Ebay for a customer last month($200).
If you don't currently have print then you need more than just the NIC card. You will need the Hard Drive, Controller, Chip, and control panel buttons.
Dec 03, 2009 | Gestetner DSm645 Digital Imaging System
925 people viewed this question
jasbo
jasbo
