Question about Nintendo GameCube Console
Power light My problem with the game cube is that when the system is turned on the power light coms on then goes out again altho I cab hear the fan running but it will not play the disc or anything else. I played with it some got it to work 1 time then it quit again as soon as the game was finished. Anyone know a way to fix it?
    Problem Solver:
  • 14 Answers
The problem could be that the lens is waring out... not problem though, this can be fixed quite easily (if it salvageable, that is, and that it hasn't degraded too much..) There is something called a POT of the lens, which is basically the power and spread the laser uses to read discs.. over time, its figure reduces, and if it reaches too low, or beyond a certain point, it could render the lens and machine useless.. if you want to try, you can open up the machine to tweak the POT level.. which is in no way harmful if you adjust it within reasonable limits... Here is a guide to doing it, and what will be required, if it seems to be the only option you have left... http://modthatcube.pxn-os.com/content/pot.htm I'd personally recommend adjusting the POT once in a while anyways, for maintenance, and once you do it once, will only take 5-8 minutes each time.. I've also noticed that stuff loads faster since I adjusted mine..
Posted on Apr 30, 2007
SOURCE:
1993 OLDS CUTLASS CIERA Engine cooling fan SHUTS OFF WHEN ENGINE IS TURNED OF, THEN STARTS RUNNING AGAIN 30-40 SECONDS AFTER ENGINE TURNED OFF. hAVE TO DISCONNECT THE BATTERY TO STOP IT.
Sounds like the fan relay is failing, altho normally it keeps powering the fan as you turn the key off.
I suppose the spring could be weak and allowing the points to close.
I would change the relay and see what happens.
Apr 11, 2013 | Cars & Trucks
Disk is clean and all, but when I turn it on, its starts fine until the little box finish making the Game Cube Icon and then start turning and goes straight to my memory card. I can hear the cd running but...
Your Gamecube's laser may be dirty. Try this:
Grab a cotton swab (A Q-Tip), and some rubbing alcohol. Lightly wet one end of the cotton swab with the rubbing alcohol and open up your Gamecube's disk tray. LIGHTYLY rub the wet end of the cotton swab on the disks laser in a circular motion. The laser is the shiny part pointed to by red arrows in this picture: http://i.imgur.com/MAXRQ.png
Now leave it for a minute or two to dry and attempt to play a game again. If this doesn't work your problem may be an underlying hardware error that can't be solved without opening up and gutting your gamecube. Let's hope for the best though!
-Risonhighmer
Feb 27, 2011 | Nintendo GameCube Console
In the middle of a game online it went black and now the game disc will not eject. Also when we turn it off and on again , when we press the front right to turn it on the console light goes green for 1...
HARD RESET
1. Power Off the PS3 via the power switch in back and power back on w/switch. (60gb FAT if no switch in the back unplug it then plug it back in after a few seconds)
2. Hold Power Button on the Front until you hear 3 beeps.
3. Then go through the initial setup and then run a full Format via System > Format. (will take approx 3 1/1 hours). You may need to have our AV cables ready if your using HDMI (in case HDMI isn't detected after initial reset).
4. Restore your backup you made prior to doing factory/hard reset (optional, if you created a backup).
Oct 17, 2010 | Sony Playstation 3 (PS3) Console
When i power on ps3: light goes green to blue to red (3 beeps)?
This is the yellow light of death i got it some time ago and had to buy a new ps3 there is a way to fix it but i costs more than a new ps3 i had to buy a new one so your screw lol.
Dec 06, 2009 | Sony Playstation 3 (PS3) Console
My ps3 will not turn on. the light comes on then beeps and turns off
try rebuilding the database and the file system in recovery consol
to get to the recovery consol press and hold the power button when ps3 is in standby mode(red light) till you hear a double beep. sometimes the ps3 does a beep then another beep and goes back into standby thsi is fine just release the power and quikly press and hold it again till you get double beep.
like on my 80g system it goes like this
ps3 standby...press hold power.......beep .........beep........stanby again....release and hold power again.......beep .........double beep...release power now you should be in recovery menu.
Oct 28, 2009 | Sony Playstation 3 (PS3) Console
My ps3 turns on but only the theme background appears it turns on and it says ps3,that goes away and when the icons should be coming up,they dont! help please!!
Oct 24, 2009 | Sony PlayStation 3 40GB System
Hi- we are having a problem with our ps3....it just started overheating....we forgot to open the door...I heard the fan kick in...so we turned off the ps3 to let it cool down....now the ps3 is running...we...
try video reset
press and hold the power button till you hear a second beep.
standby mode press hold power........"beep"......"beep"..release power button
then try rebuilding the database and the file system in recovery consol
Oct 20, 2009 | Sony Playstation 3 (PS3) Console
My ps3 stopped showing picture ,it was working i turned it on i saw user screen then nothing,already replaced video cord
try video reset
My ps3 wont turn on
HI, the power supply is unstable or weak. you will need to replace this failing power supply soon. it is damaged.
Jun 16, 2009 | Sony Playstation 3 (PS3) Console
Light goes on and off
If the power comes on the power box, that is good, so the only the is the mother board is bad, replace it. they have nubers on the that tell you what kind it is. search the web, you can find the new on ebay check, and you can put it in your self and save time and money.
Sep 02, 2007 | Computers & Internet
Nintendo GameCube Console Logo
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
shevantha perera
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
