Question about Canon PowerShot SD1000 Digital Camera
My Power button isnt working
I have a canon powershot sd 1000 and it wont turn on i dropped it the other day and it still worked with the lens restart error a couple times but it worked and then my battery was low and it died...i recharged my battery but it wont turn on  now...took it to a camera store they tried a new battery say its not the battery thts the problem..... so cant really figure out what to do it jus isnt turning on at all
  • 477 Answers
There could be several thing that could cause this problem like a bad lens. the battery might have to be left out of the camera for 24 hr to discharge the battery, a damaged main board. a defective power button. try taking out the memory card to see if that fixes it. repairs on this unit can start any where from 65.00 and up. goto www.digitalcamrepair.com if you need repair service.
Posted on Dec 09, 2008
How do i restart my cannon ps sd;1000.. the lens is stuck open and i can't shut restart it
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Apr 24, 2010 | Canon PowerShot SD1000 Digital Camera
I have a powershot sd 780 is. i dropped it and it now says to restart the camera due to lens trouble. how do i do that? the lense won't close completely.
I put my Canon SD780iS through the washing machine. The lens was extended when I found it. I did not try to turn it on. I removed the battery and memory card, removed the 5 small screws and opened the front and back to expose the insides. Over the next 2 days I dried it out completely with a hair dryer. When I put it back together, I too found that the lens retract cycle was messed up, and while the splashscreen came on, nothing else worked..
I tried your trick of holding the Function/Set button while turning it back on. The camera reset back to factory condition, and it works like a champ. No loss of pictures either! This is one heck of a tough little camera!
Dec 31, 2009 | Canon PowerShot SD780 IS / IXUS 100 IS...
Canon PowerShot SD780 IS camera lens error. :(...
I did the same thing and it works only be restarting it now but it works lol. I threw it agianst my bed . SO BEAT THE **** OUT OF YOUR CAMERA..then restart and it should work..*** made **** what can you say
Jul 28, 2009 | Canon PowerShot SD780 IS / IXUS 100 IS...
PowerShot SD630 lens stuck out, says lens error, restart camera
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Apr 20, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
My Canon sd 1000 won't power on. Battery is OK.
Check to make sure the batteries you are using have enough strength and volt power, if not it wont work. If they are really cheap, and last only a weak in the remote, they wont power up a camera.
Jan 21, 2009 | Canon PowerShot S1 IS Digital Camera
Canon PowerShot SD630 LENS WONT CLOSE,LENS ERROR RESTART CAMERA
I have the same problem. How do you restart the camera. I have pulled the battery and SD card, but can't get to a menu screen to restart to camera.
Apr 16, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
Canon PowerShot SD1000 Digital Camera Logo
206 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
