Question about Garmin Nuvi 760 Handheld GPS Receiver
Just updated my Garmin Nuvi 760 on line last nite. Today it won't even power up.
  • 3 Answers
Someone suggested holding the power switch on for 8 seconds to reset unit.
It did in fact power up after that.
Thanks
Posted on Dec 10, 2008
  • Garmin Master
  • 2,130 Answers
Have you tried pressing the reset button?
- Jim
Posted on Dec 09, 2008
Garmin nuvi 760 map update free download
Garmin Express Garmin Express but it probably won't be free. $50 for one time or $90 for lifetime... dont get the lifetime, get a new unit instead.
Jul 29, 2014 | Garmin Nuvi 760 Car GPS Receiver
Update file on garmin corrupted
Same happened to my Garmin Nuvi 760, power failed during upload. Files corrupted. Garmin could not locate it with Sat. Told me to trash it and they would give me $70 towards purchase of a new one, which would not fit in my cars receiver. My solution was to purchase a used one that had a good Garmin File folder. I copied the folder to my pc. It was important to remove the device file from the copied folder. I then formatted my corrupted 760. Then copied the folder from my pc into the formatted 760. Next step was to use Garmin Express to replace the missing device file, do the updates, and reinstall the maps. Product code to unlock maps was inside the rear plastic housing to unlock the maps. Whole process took about 4 hours and it works like new now.
May 02, 2012 | Garmin nuvi 255W GPS Receiver
Garmin Nuvi 760 gps Unable to calculate route No roads near starting point
I have same issue Garmin Nuvi 760 gps Unable to calculate route No roads near starting point started this morning. Has worked fine for 2 years till today. David W
Aug 02, 2010 | Garmin Nuvi 660 GPS Receiver
Garmin nuvi 760 ...updating bluetooth firmware
You have a software problem with your NUVI . I recommend you to reset [ restoring default factory settings ] your NUVI
To reset your NUVI , please follow one of these procedures :
1:Turn the Nuvi on.
2:Touch the tools icon on the main screen. The tools icon is represented by a wrench surrounded by a blue circle.
3:Touch the "Settings" icon which appears as a wrench.
4:Push the "Restore" button at the bottom of the screen. A confirmation message will appear asking to confirm restoring the Nuvi to factory settings. Push yes to restore the factory settings
Try this for hard reset .
Turn off Garmin device. Press down on bottom right corner of the touchscreen [ Don't let go ] , and then power on the GPS unit. You should be prompted whether do you really want to erase all user data, or asked if do you really want to start up in maintenance mode. Press “Yes” to reset (warning: all data will be erased and lost, so backup before proceeding) or enter maintenance mode.
After that you can try again with updating .
PLEASE DON'T FORGET TO RATE !
Apr 20, 2010 | Garmin Nuvi 760 Car GPS Receiver
We pourchased online the unlimited Garmin nuvi 760
Hi
You have to go to GARMINS web site and download the map updater program called Garmin Download Manager. to your pc - then put it on the Garmin.
Here is the download page with many of the Garmin features - I have found Garmin very good about this.
http://www8.garmin.com/support/download.jsp
Mar 22, 2010 | Garmin Nuvi 760 Handheld GPS Receiver
Are there free road info download available
No. If you want usefully updated maps, then you have to pay for them. Garmin do offer a "lifetime" maps subscription, but it's only for the lifetime of your product: given that most Garmin SatNav units don't last long enough to benefit from more than a couple of years worth of updates it's usually cheaper to buy the single update option, although the lifetime subscription gives you four updates per year and one-off is just a single annual update.
If your unit also needs updated traffic and camera alerts then it can be cheaper to buy a new satnav.
Mar 01, 2010 | Garmin Nuvi 760 Car GPS Receiver
Garmin won't come on
plug it in to the wall charger or car charger for about 4 hours, then slide and hold power button for up to 15 seconds till it starts.
if that fails, unplug the nuvi then press and hold the lower right hand corner of the screen until you see the message " Do you really want to erase all user data?" remove your finger from the screen and select YES. (this will erase all your saved data) this should reset your nuvi to the factory settings.
use the web updater to update your nuvi once you get it started again.
you can get it HERE
let me know if you need further help.
bill
Sep 05, 2009 | Garmin Nuvi 760 Handheld GPS Receiver
GARMIN nUVI 760 will not power on.
Can be hardware try to send it to a repair centre
try this one www.satnavservice.com
Sep 02, 2009 | Garmin Nuvi 760 Car GPS Receiver
Garmin Nuvi 760 memory card
Does the Garmin Nuvi 760 require an additional memory card for normal use?
The simple answer is : no it does not need and SD card to work
Jan 26, 2009 | Garmin Nuvi 760 Handheld GPS Receiver
Garmin nuvi won't turn on
folks, the garmins have an on-board battery that needs to be powered up (at least occasionally) via the usb port - like from your computer. just using the dc car power cord does nothing for this battery. i've had this exact same problem on both my 760 and 780 nuvi units. fixed it using the usb charge. seems to run down differently for all the various nuvi models. my regular charge will hold for 7 hours on my old 660, my 760 and 780 work about 5 hours. my 'power up' failed on the 660 after 10 months with no internal battery charge, but the 7xx models only took about 5-6 months to 'fail.' hope this helps. jack b :-) in midland, tx usa
Jan 13, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 760 Handheld GPS Receiver Logo
203 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
