posted by headdn on Feb 25, 2007
installed a new dishwasher today and it fills with water but did'nt start the wash cycle checked the door to see if that was it but still nothing
Solution #1
posted on Mar 11, 2007
It is possible that the motor pump seal is locked and needs to be freed up. Remove the filter and sump screen and place an 8mm nut driver or socket into the circulation pump opening ont eh right hand side. The nut driver will engage a nut on the center of the circulation pump impeller rotate it 2 revolutions clockwise to free it up. If it does not turn at all then the motor needs to be replaced. Remove the nut driver replace the screens and check for operation.
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Siemens 24 in. SL34A006UC Built-in
Email this problem
Email this problem
Can you Help with these Dishwashers problems?
Siemens 24 in. SL34A006UC Built-in Dishwasher
does not stop running
Hi, I have a siemens... Answer This...
Dishwasher does not drain well
dishwasher was working fine... Answer This...
Repair Service
Find Dishwasher Repairman Near You:
