Question about Canon PIXMA iP1600 Printer
Printer does not print
Paper does not feed. Thank you for whatever help you can provide
  • 4,041 Answers
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 27, 2010
How do I change HP Laserjet 1100 to NOT manual feed under Printer Properties?
I suspect the printer is defaulting to manual feed because it thinks there is a page in the manual paper feed. Make sure no bits of paper debris are jamming the sensor.
Dec 03, 2014 | HP LaserJet 1100 Printer
I have a Dell 5210N mono printer. And I want to use the manual feed tray as a second paper drawer for letterhead paper only, ie leave a whole stack of paper in the manual feed. Then when I select manual...
Check the software provided or installed on your Computer you use for work(printing software), look for print properties, check for print settings, look for manual Feed, Under manual Feed, set it for letterheads, however this has to correspond with the Applications you are using to print letterheads out of( under print, into the preferrences you should be able to have the settings as well). If your printer software does have these settings, then you will have to do it Manually upon every print.
Dec 03, 2010 | Dell 5210n Laser Printer
Paper won't feed in my printer
try reinstalling the driver of your printer. or change the settings to default. make sure that all software requirements are met. Or if none of these works pm me. Thank you
Aug 07, 2009 | Epson Stylus CX9400 Photo Printer
Magicolor 2400w won't feed paper
CLICK HERE for the manual
See page 55 for cleaning the media roller.
Jan 26, 2009 | Minolta magicolor 2400W Laser Printer
Lexmark X5495 Feeds paper in part of the way
I own this printer, it has to do with how you load the paper, it's very touchy, just keep readjusting the paper and you will get it right, you don't want the paper to far into the printer, or you will get a paper jam error, but if it's not in far enough it will sound like it's printing but not feeding the paper. Hope this helps, Julia
Dec 21, 2008 | Lexmark X5495 Printer
Hi, Photo paper loads at start of print job but locks up and paper jamb error comes on. Have loaded 10 or 15 sheets of just photo paper that does not help. I can run standard paper thru and it prints pics...
Is this the first time you have used the heaver paper ? Also is it the same brand? You did not provide the printer model, but you can typically go to the manufacturers site, and check the specs for proper ( Mim / Max ) paper requirements. Above # 60 the paper feed rollers may have worn, and may need to be replaced. If 20 # copy paper works, then this may be the problem.
Nov 19, 2008 | HP Office Equipment & Supplies
HP P3005 Will not pull from Tray 1
Click File > Print > Properties to check your settings.
To verify that tray 1 is working, put paper in tray 1. Press green check until you see Information Menu. Scroll using arrows until you see Print Menu Map then press green check. If it prints from tray 1, your problem is not with the printer, but with the PC settings.
i has follow this step, but need to press green check button to resume print menu map.
tray 1 manual feed set to A4 paper plain size
manual feed is on.
there is paper on tray 1
ps setting tray1 manual feed is A4 plain size paper.
send print to tray1 manual feed even there is paper at tray 1
i still need go to the printer and press green check button to resume print
Sep 23, 2008 | HP LaserJet P3005n Printer
HP LaserJet 2100/TN
Replace toner cartridge drum/blade RS, slim faint outside chance it is a fuser (hot bit rear) problem, doubt feed issue
To confiirm to yourself it isn't a feed issue, try feeding A4 via manual bypass (envelope slot) and doing a print using manual bypass tray, just override size missmatch warning if it appears (tick i think when beeping). should do same fault as feeding via cassete
You can also print a test page from printer via operations panel to confirm it is printer problem not software.and you can do a paper path test from whatever feed slot
To eliminate it being fuser problem try printing and turning the power off when paper is 1/2 way threw print job, remove cartridge and exaimine unfused (still image rubs off) print, if image is fine then it is a fuser issue but be carefull to note how much of a page needs to be printed before image repeats so you know if it is right or wrong.
But thats just tecnical possibitys, Change cartridge should fix!
Odds are 95% cart 4% fuser 1% others i reckon!
Oct 19, 2007 | HP Color LaserJet 2600n Printer
Canon MP160 all in one
don't know if it's the same problem i had but its maybe worth a try. My paper went in a little, the wheels were turning but it didn't take the rest of the paper or print.
Yesterday someone replied to my problem, i tried it this morning and its fixed 1st time.
Solution:- Use a piece of thin card, a magazine cover is what i used, make sure its A4 size then try to print something, as the paper starts moving push it through! and hey presto it worked for me, everything printing fine now
Jun 12, 2007 | Canon PIXMA MP160 All-In-One InkJet...
Canon PIXMA iP1600 Printer Logo
29 people viewed this question
old marine
old marine
