Question about Baby Lock Ellure
Babylock Ellure ESL - Blank screen
My Ellure is getting power - all lights are on/back lit - but the screen is blank.  Was working fine earlier today and now nothing.  Won't sew in any mode.  Any ideas?  Reset button?  Did I brake it?  I might have  - was getting ready to embroider and didn't see the font choice from my card so I pushed the card in harder.  Shortly thereafter the screen went blank.
5 Suggested Answers
fwadley
  • 482 Answers
SOURCE: babylock ellure feed dog will not raise
go see your local parts man. he will know what you need and he will have it there or he will need to order it.
Posted on Dec 16, 2007
SOURCE: Babylock ellure safety device
I have the same problem, I have done what the book says but no luck yet. Have you figured out what happened? And do the experts really check the questions? Cause I asked a question awhile ago, and no answers. Help!
Posted on Oct 14, 2008
  • 3 Answers
SOURCE: Babylock Ellure thread issues
I have the same machine and love it. Sometimes if the thread is old that will happen to me.  And also I spray the thread with static guard before i thread the machine in dry cold weather.  Since you said you are an embroiderer I assume you are using the same weight thread top and bottom. The other thing that causes that on my machine is if there is a nick on the spool of thread I am using and the thread catches just a little as it comes off the spool.  I use a fine nail file and smooth off the edge where the little v is to reattach the thread when you are finish using it.  I never use them. You do sew a little and cut off the tail off the top thread before you let it go through the rest of design. I hope you have found the solution but I learned these tricks while having the same problem as you.
Posted on Mar 07, 2009
SOURCE: Can the babylock Ellure be upgraded to USB?
I keep getting the error message..."this embroidery card cannot be used on this machine"....it's the same card I've used for a couple of years. What is the problem? Would appreciate any feedback.
Thank you.
Barbara
Posted on Oct 02, 2009
SOURCE: my babylock ellure won't work on the embroidery
Ours did the same thing. They said it was the circuit board for embroidery that went bad. The one for sewing is still good. They wanted $200 to $300 to replace it.
Posted on Nov 04, 2010
I have a baby lock ellure model ESL and the LCD display went out. How do i fix it
Sorry, you will have to take it to a Brother/ Babylock dealer for repair.
Jul 05, 2015 | Baby Lock Ellure
Need service manual for baby ellure ESL.
you can try contacting babylock and see if they can help you
Dec 02, 2014 | Baby Lock Ellure
WHAT DO I DO TO GET MY BABY LOCK ELLURE ESL TO PICK UP THE BOBBIN THREAD?
You have your bobbin inserted into the machine spinning in the wrong direction. take the bobbin out and flip it over and wind around needle plate guide and cut. Look at the little pictogram on the plastic part of the machines throat plate. It shows which direction the thread should spin off the spool when you drop the top loading bobbin into the bobbin case.
Cheers,
Kelly
San Diego, CA
Embroidery Services
Aug 30, 2014 | Baby Lock Ellure
How do i remove cover
Lots of screws, then lots of clips to break off when removing the shells, then lots of fine cables to damage. Then a very big repair bill.
Save yourself a headache and a lot of money. Get it looked at by a trained Brother or Babylock tech. Brother makes Babylock machines so getting it serviced by a Brother shop because Babylock shops pay roughly 30% more for parts than Brother shops.
Feb 27, 2014 | Baby Lock Ellure
Baby Lock E Ellure ESL Embroidery Sewing Machine I bought this unit on line from ebay didn't realize it didn't have the manuel. Can't find the manuel online. It don't have the embroidery...
Software is available from Babylock.com and the hoops are available from Amazon.com You might want to contact a dealer on line who sells this model. Here is one I found in Austin who sells your machine for 399.00 http://www.sewaustin.com/eblasts/MoreSew-LessDough/MoreSewLessDough.pdfThe dealer might be able to help or contact one in your state via phone.
A fully loaded used model sells for abt. 700.00 so you got a good deal!
A phone call or email is better than having to travel...Shame on Babylock.com for not helping you!
Good Luck and don't give up.
Jul 23, 2011 | Baby Lock Sewing Machines
Does Allure ESL have a port to plug in a card reader?
I cannot find any reference to a Babylock Allure ESL.
There is a Babylock Ellure, which uses the card only and the Babylock Ellure Plus with UBS port A for a flash drive.
Mar 06, 2010 | Baby Lock Esante
Will the Elure ESL model accept a twin needle
The site shows a twin needle setting.
http://www.babylock.com/embroidery/ellure/
Have you looked at your manual or bought the more expensive book from your dealer? I have found my book for my Evolve a VERY good investment (70 bucks, but worth every penny these past 2 years!)
Baby Lock have very good cust. service either on the web or right at your dealer. Most dealers will give free lessons upon request.
I hope this helped
Jan 20, 2009 | Baby Lock Ellure
Babylock Ellure Embroidery Unit Malfunction
You need to make sure that the embroidery arm is able to move freely be sure that it has no obstructions like a wall behind your sewing table or fabric that may be stacked nearby. If all is clear you probably have thread wrapped somewhere inside the embroidery unit it only take a little bit to jam up the works. You can try to take off the cover by flipping the unit over and removing the screws to the embroidery arm. I would take it to the shop where you bought it they should be able to help you for free if it is new. If you have the original packaging you can send the machine to Steve's at www.stevessewandvac.com just send them an email they can help.
Jul 27, 2008 | Baby Lock Ellure
Start up..Babylock BMP6
Not if you just want to get the patterns off the internet, etc., you cannot, or at least with my older version, make your own designs. You need to download the program to your computer. Its pretty simple if you get on the internet and download the designs put your palette on your computer, go to the designs, with a blank card, and load the patterns. Hope this makes sense.
Apr 14, 2008 | Baby Lock Ellure
Embroidery downloads baby lock ellure plus
If not a USB model, you have to get the disgustingly expensive Babylock palette box ($500) and software with the blank card to transfer the designs from cd or files. Beware of making the embroidery too small, it can make the stitch density too great and then the machine cannot sew the design. There is software called Density Works to deal with this problem.
Apr 04, 2008 | Baby Lock Ellure
Sewing Machines Logo
73 people viewed this question
Top Baby Lock Sewing Machines Experts
Chris Wetmore
SewTechWayne
SewTechWayne
Douglas Plant
Douglas Plant
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
