Question about LG DLG5988 Stainless Steel Gas Dryer
LG gas dryer model # DLG5988B won't heat
Had to remove gas dryer to work on my washer when i reinstalled the gas dryer the gas burner will not kick on it does not heat i purged the gas line before reinstallation vents are not clogged is it possible theres a switch or thermal couple that could get out of whack where can i find a print how to get to the gas valve could it be a sensor worked perfect before i removed the gas dryer (stackable) is there a way to check the gas valve to see if its operating correctly and where might i find parts for my LG washer and dryer that i can purchae and install myself Thanks very much Gene
  • 36 Answers
Turn the gas on or you might have air in the line.
if that dont work check out the ignitor
Posted on Dec 09, 2008
LG Trom gas dryer dlg5988B got under water 10 inch. The motor is running, just the gas heater does not burn. Computer is working right. Any idea?
Take top off, start drying cycle and see if you can see an orange glow on bottom right front of unit-the Glow plug igniter. If it glows, then you have a different issue. If no orange glow, replace igniter.
Nov 26, 2017 | LG Dryers
Gas dryer lg trom dlg5988B does not get hot.
If it has been under water you need to have it professionally serviced. The gas igniter is electronic and there are safety circuits to prevent explosions and getting gassed..
When i turn on thedryer it will run but will not heat up. it is a DLG5988B Gas Dryer
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jun 24, 2011 | Dryers
I have a LG dryer (DLG5988B) with no heat, maybe the igniter is bad. What is the part needed, and can I replace the igniter myself.
First check the high limit switch to make sure it didn't trip. You will need a multi meter to check.
Jun 17, 2011 | LG Dryers
My lg dryer model dlg5988b is not drying. it seems to be working properly but is not heating.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 05, 2010 | LG Dryers
Dryer is always "Cooling", doesn't heat. Why? How ...
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 20, 2010 | LG DLE2514 Electric Dryer
DLG5932W, not drying completely. I hear gas burner come on but only stays on for short time. Same condition in manual mode
If you have a gas dryer.
Gas Dryer not Working Gas Dryer Not Heating
If your dryer is electric..
Dryer Troubleshooting Electric Dryer won t Heat
heatman101
May 11, 2010 | LG DLG5932W Gas Dryer
Dryer heats up and then stops heating
My gas one just did this. I tested the fuse myself located on the side of the lint trap. It was fine using my electrical tester. I then took the 2 coils off which are easy they are located on the burner. 2 screws removed the plate under are the 2 coils. Took them to ACE hardware were they tested them. The 2 prong was stuck in the open position. The three prong was fine. , I still replaced both and it works great now. What happened was the burner would kick on then when it hit operating temperature it would shut off. Then when it needed to kick on again the 2 prong being stuck in the open position wouldn't ignite burner again.
Jun 22, 2009 | Maytag Neptune MDG5500AW Gas Dryer
LG DRYER DLE2532W DISASSEMBLY INSTRUCTIONS
DLE2532W is an electric heat model. (a gas model would be a DLG......) To get a rear control LG dryer apart: Open door and remove two phillips head screws at the 5 and 7 o'clock positions. Use a putty knife to release the clips holding the top panel to the dryer front by pushing the clips in at the seam of the dryer top and front, a couple inches in from each side. Swing top back. Remove two phillips head screws at the top, allowing front panel to pull forward. Unplug drum light and door switch and drum sensor plugs, allowing front panel to be completely removed and set aside. Now, look at the burner area at the lower right. Behind the gas valve you will find a small (about dime sized) high limit thermostat on the left side of the burner cone. It has two wires attached and has a small pin in the center of it. (Only on gas models) Push the pin in.
Now, if that get's you ignition again, CORRECT VENTING ! Get rid of flexible vent material. (use only rigid aluminum vent pipe and elbows) Clean out vent pipes and outside vent hood. Outside vent hood should be the kind with a four inch flap for the opening, not a two inch flap. Tripping of the high limit thermo is almost always caused by inadequate air flow.
Dec 28, 2008 | LG DLG5932W Gas Dryer
Dryer not Heating up
hi thanks for the question i would also check the thermal fuse when you purchase the hi limit thermostat also purchase the fuse a lot of dirt in venting will cause the thermal fuse to fail the appliance doc
Sep 27, 2008 | LG DLG5932W Gas Dryer
LG DLG5988 Stainless Steel Gas Dryer Logo
360 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
