Question about HP OfficeJet 6210 All-In-One InkJet Printer
What is an auto document feeder
What is a auto document feeder on a printer
    President:
  • HP Master
  • 990 Answers
I don't know which machine you have, if only printer itself they don't have ADF if this printer come with scanner or fax they do have usually,
Posted on Dec 09, 2008
How do I copy from document feeder?
Dear Flaim
pl. do load documents on the adf tray.face upward and the press copy or start. it will do
thanks.
Apr 02, 2015 | HP Officejet 5740 Wireless e-All-in-One...
What does document in ADF mean
Hello, Thanks for using Fixya today.
ADF is auto document feeder, used to feed a document into a scanner or printer. The error is associated when there is a document or paper jam at the document feeder, or paper trail.
This would happen mostly on scanners and all in one printers after witch a document is left in the feeder or there was a paper jam occurrence. We hope this answers your questions today?
Please contact us again if you still have a issue, or need help with anything else.
Thanks for using Fixya.com
Best regards,
Rulds2008
Jun 14, 2011 | Canon PIXMA MP830 All-In-One InkJet...
Using automatic feeder to scan a multiple page doc into 1 PDF
Yes you can scan up to 30 files in one pdf , and you have to put documents in auto feeder (face up) and from the pc, scan menu, scan to files, select destination and extension.
That's all
Mar 04, 2010 | Canon PIXMA MX310 All-In-One Printer
Canon 1023if auto feeder not working. Says check
The document feeder has multiple sensors in it. sometimes they hang up and stay stuck out of place. Other sensors might get paper dust on the face of the sensor. If you can open the document cover, locate the sensors and see if any are ajar or the sensor flag fell out of place. Also look to see if a paper is stuck in any of the paper path areas. Not seeing the machine it is hard to say if it fed paper and says check document, if it did, clean the feed wheels with a wet paper towel.
Oct 15, 2009 | Canon imageRUNNER 1023iF Black and White...
Auto Document Feeder copier problems
The scanning glass probably needs cleaning.
Jul 31, 2009 | Epson ACULASER CX11NF All-In-One Printer
Document Feeder
Place document face down on top of the lid toward the bottom of the two slots that are on the left. Push forward till you meet resistance and an audible tone is heard. Set the function that you desire on the control panel and then press start.
Jan 20, 2009 | Lexmark X5470 All-In-One InkJet Printer
Auto document feeder
Did you make sure the tape is removed inside the Document feeder,or maybe you need to check to see if anything is stuck in the rollers. Open the door (if you have not already done so) to the document feeder and you will see pictures on the inside showing how you can remove and/or change the roller (make sure everything is put back as the picture. Good luck, I hope that is all that is wrong with it.
Dec 26, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
HP 7410 streaks when using auto document feeder to make copies
the document feeder of that unit have its own scanner glass. try opening the document feeder and clean the scanner glass with a lint free cloth that is moist with water and also clean the rollers of the document feeder
Aug 13, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Jamming of documents in autmatic feed for scan mode
One way to unjam that would be to take a stiffer plastic or manila folder and insert it slowly into the document feeder and the slowly push it through the feeder until you dislodge the jammed document out of the bottom of the feeder.
That is a common practice in removing jams in the feeder.
Mar 13, 2008 | Office Equipment & Supplies
HP LaserJet 2840 Scanner problem
Have you looked to see if there is any paper at all in the trays. That are getting hung up.?? I can help
Feb 10, 2008 | HP LaserJet 2840 Printer
HP OfficeJet 6210 All-In-One InkJet Printer Logo
102 people viewed this question
Ben Johnson
