Question about HP Compaq Presario C304NR Notebook
New installed hard drive not recognized on C304NR Laptop
Swapped out hard drives on a C304NR Laptop and the new drive is not recognized while trying to install windows xp. I do not have a recovery cd. The old hard drive will cannot be accessed in any way. I thank you in advance for any assistance you can give me to solve this problem.
  • 395 Answers
Http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&dlc=en&cc=us&product=3245634&lang=en
if you have a windows xp cd , then have the computer boot from the xp cd and it should setup and partition the drive for you. it it doesnt find the harddrive at all then download the sata driver and unpack it to a usb pen drive.when xp starts up from the cd then hit f2 to load drivers . it should pickup the sata drive after it had the driver but i would try a normal setup by booting from the cd
or order a set of recovery cds from hp for $15.85
Posted on Dec 09, 2008
    Master:
  • 763 Answers
Sir, try to check the cable or the connection between the hard drive and your laptop. it must be loose and see also the cmos set up if its really detected by your laptop.
thank you for using fixya
CHARCOIS
  • HP Master
  • 1,183 Answers
HI,
There could be 3 possiblities here.
1. The HDD you have installed is incompatible. This system would not support a harddrive more than 120 GB.
2. Second, there could be a motherboard problem
3. The new harddrive may require additional drivers to be installed , check if you have got any installation cd with your new harddrive .
I would update , more infor on the same in a moment
Thanks
Proton
  • Mandeep  Singh
    Mandeep Singh Dec 09, 2008
    Troubleshooting steps
    Before Windows opens and while the “Press to enter setup” prompt is displayed in the lowerleft
    corner of the screen, press f10.
    Go to the diagnostic menu option and run the test on your hardrive .If the hardrive fails , it would give you an error of why its failing , if it passes , then you need to install drivers for it to get to work with windows xp. The problem is quite common on big harddrives , from segate , wester digital and hitachi. You may need to call the hardrive manufatcurer.
    IF you could give us the model number of the hDD and the capictiy of the haddrive you are trying to install
    Thanks
    Proton
  • Mandeep  Singh
  • HP Master
  • 4,806 Answers
Is the new drive SATA? if it is then there is no way you can install XP without having the sata drivers on a floppy disk to help you recognise the hard drive, the only operating system which will install is Vista, this because there are hardly any sata drivers on the XP install CD, it works fine until you get to the part where it says no hard drive detected.
Had this problem loads of times with Intel based laptops
kind regards
  • Lee Hodgson
    Lee Hodgson Dec 09, 2008
    Guys!!!! if the machine only supports SATA then XP will not install unless the machine is running a AMD processor, if it is not then XP will not install, please will you read the posts properly before making your comments
    regards to all
    Sergeant:
    Champion:
  • 283 Answers
Hi, please dont rate me yet if this could not fix your problem. Please click this
http://www.drivelabs.us/?gclid=CL7f74esspcCFQeETAodIFicjQ
Thank you....
  • HP Master
  • 6,487 Answers
If the new hard driver that you put is a new one and not tested to be working , this can be a problem with that new hard drive and you may want to use a different hard drive since that one is not being detected...
    Genius:
  • 1,550 Answers
Just check whether hard drive is properly placed in your laptop .
If it is not installed properly you cant recognize the hard drive.
I
  • SAM ANDERSON Dec 09, 2008
    Install the hard drive properly .
  • 505 Answers
You will need to get a recovery cd from your manufacturer. with this you can boot the computer from the cd and procede to format and install windows on the new drive. they usually will charge $20 or so for recovery cds.
when you get the cd, put it in the drive and boot the computer. it should load from the cd. if it doesn't, you need to enter the bios to change the boot order. usually you hit a button at startup (del, spacebar, etc) to enter bios, the info is usually displayed on screen.
Hard Disk Failure #1-03 Repair? This code shows up after a hard disk self test.
If the notebook is under warranty IMMEADIATELY contact HP. Get a free hard drive from them.
If not then unfortunately you need to buy a new hard drive.
Note: Buy a HP Hard drive because other third party hard drive may not work.
Jun 18, 2010 | HP Compaq Presario C304NR Notebook
Not recognizing hard disc drive for windows xp reinstall .
You aren't using the correct install disk . The generic XP install disk can't recognize a SATA disk.You will have to load the appropriate driver during install. Here it is ftp://ftp.hp.com/pub/softpaq/sp32001-32500/sp32492.exe
Or you could create a custom install disk  as explained here
http://news.softpedia.com/news/Install-Windows-XP-On-SATA-Without-a-Floppy-F6-47807.shtml
May 13, 2010 | HP Compaq Presario C304NR Notebook
Cannot get Toshiba P@% S507 to see new hard drive.
you can't use a restore disk made for a specific hard drive with a much larger hard drive. This information is checked by the restore cd. You would need to contact toshiba and get a regular windows install cd.
Apr 01, 2009 | Toshiba Satellite P25-S507 Notebook
Cant install recovery disks after a hard drive reformat!
the recovery disk is designed to repair or restore a system to its previous factory condition and is not a full installation. the formating of your hdd would have erased all the data required for this process to be completed. you can try a recovery utility that may be able to help you at this link. the disk might not have been saved in an .iso format to tell the computer to run it before starting an OS. if this disk is recognized and runs on your system then you will need to attempt a recovery, which is unlikely since the drive has allready been formated many necessary system files may not be able to be restored. at this point a complete new install will be necessary.
Good Luck!
Mar 12, 2009 | HP Compaq Presario C304NR Notebook
Installing new Acer Aspire 3200LCi Hard drive
try the jumpers set its th masterand slave thing
Feb 24, 2009 | Acer Aspire 3002LCi Notebook
Compaq evo n800c not recognizing hard drive
Test new HDD in another laptop or else. Make sure it's not DOA.
Jan 01, 2009 | HP Compaq Evo n800c Notebook
Replaced my hard drive and laptop is not recognizing the new one.
Have you installed an operating system on the new drive?
Dec 07, 2008 | Gateway (M520HD80G) Hard Drive
Install a roxio cd into my laptop
You need a replacement CD drive most likely.
The 5300 can be swapped for almost any generic laptop optical drive. I would pick one up from directron.com or geeks.com they have new drives cheap.
Then just unscrew the plastic mounting rails attached to the side and back of the drive, swap them over to the new drive and go!
Dec 20, 2007 | Gateway Solo 5300 Notebook
HP Compaq Presario C304NR Notebook Logo
57 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
