My monitor comes on long enough to show the e then says no signal! Please help what could be causing this problem?
  • 1,183 Answers
Two things to check , to do, to assertain the point of failure .
1. Disconnect the signal cable coming from the monitor to the computer tower.If the monitor goes out there can be a problem at the monitor.
2. Check buy attaching a different monitor.
If the different monitor also doesnot work , the problem could be your video card or motherboard.
If you posted on the forum, using a laptop , connect your monitor screen to the laptop and check by toggling the display from the laptop screen to the extrenal monitor .
Thanks
Proton
Posted on Dec 09, 2008
What do i do when it comes on and shows analog then goes blank ?
Are you using the analog input or another? If using another input instead, then press the 2 key. It will switch to another input as the source signal. If you still experience trouble, please contact ViewSonic technical support for assistance.
May 03, 2014 | ViewSonic VG1930WM LCD Monitor
A power outage cause dell server 1600sc to shut down & no display on the monitor
Hello here is the homepage.
http://www.dell.com/support/drivers/us/en/ussoho1/Product/poweredge-1600sc
There should at least be a message on the monitor indicating there is no signal coming to the monitor. The first thought that comes to mind if all is connected would be that the power supply has failed.
And maybe the graphic card.
Call also the DELL support in your country they will be glad to help
and they probably know the fault.
Contact Us 1-877-671-3355
Good luck
Nov 16, 2012 | Dell PowerEdge 1600SC Server
Acer Monitor V193W has no signal
There are 2 basic reasons for the "No Signal" message.
  1. Loose video card inside the machine- if you're machine didn't come with on board video or if you are using an independent video card instead of on board video, the card can unseat at times, either due to movement of the machine or pulling on the video cord
  2. Loose connection between the video cord and/or monitor and/or machine. Unless the plugs on both ends are secure (including tightening both screws to prevent loss of connection), the cord can dislodge just enough to interrupt your connection, causing a "No Signal".
If neither of these is the case, try hooking up a different monitor (if equipped, you can use an HDMI cable to your TV) to see if the "No Signal" message persists.If using a different monitor works, the issue is your Acer Monitor.
Dec 07, 2011 | Acer Computers & Internet
Acer d241H display plus mode shows no signal. I want to use the monitor stand alone. When i press the source key to change to display plus mode. the screen shows no signal. (the first time I powered on the...
I had the same issue as yours. After contacting the Acer support team, I got the response as follows. I tired and it worked.
"In order to resolve this issue, you may please perform a power reset. This will remove any static electricity stored in the hardware components that may cause the issue.
- Turn the monitor off and unplug the power cord and VGA cable from the monitor.
- Hold the power button on the unit down for 30 seconds.
- Release the power button and plug only the power cord back into the unit. "
Hope it helped.
Oct 30, 2011 | Acer D241H LCD Monitor
Monitor showing no signal and button not working
The monitor needs a signal ( source), i.e., DVD, TV, to show a picture. If your monitor shows no signal then either the source is not connected or not functioning. Check the connections from the monitor to the source. Also, check that the source is functioning properly and is receiving power.
May 24, 2011 | Sony XVM-H65 6.5 in. Car Monitor
Monitor started to show an all bright white screen, could not view desktop. Now screen will not come on at all.
Sounds like a bad monitor, but just to be sure, hook a spare monitor to the computer, if okay! The Sceptre Monitor is the issue, the cause is the main board on the back of the display panel processes in coming video signals to correctly display the content, to repair would not justify the cost, cheaper to replace. Now if both screens show the same problem, it will be the video graphics card in the computer.
Jan 24, 2011 | Sceptre X9G-NagaIV 19" LCD Monitor
Have had the nx1932w for 4 years. turned on this morning and it only shows a blue screen with message stating no signal. have digital cable and all other tv's in the house work. please advise.. thank you
If the ViewSonic logo first comes on followed with no signal the monitor is okay, check the video cable connection between the monitor and the computer, if okay the video graphic's card may be the problem,or the motherboard, but this is speculation you will need somebody to check the system for exact cause.
Jan 01, 2011 | ViewSonic NX1932W LCD Monitor
Monitor comes up shows "acer" then says no signal and goes black
The interface between the monitor and the cable might need replacement. Please check it.
Jan 12, 2009 | Acer AL2016 W 20" TFT LCD Monitor
When it's turned on, the light on my monitor doesnt show any signal of power supply
I'm assuming that you mean the green indicator light is not on. This could be caused by a host of problems. Assuming that you know the AC receptacle is live by testing with a standard light the next step would be to unplug the unit and remove the back. Check the fuse for continuity. If the fuse is good you have a problem with the power supply or a short which is keeping the power supply from powering up. The most likely culprit is the Horizontal Output Transistor. Unless you are an electronic tech and know how to check this you probably need to take the unit to a shop for further diagnostics and repair.
Jun 22, 2006 | Samsung SyncMaster 753S 17" CRT Monitor
Computers & Internet Logo
414 people viewed this question
David Payne
David Payne
