Question about Refrigerators
Your defrost circuit is probably the culprit. Thaw it out with a hair dryer, remove the panel and you'll probably find the defrost thermostat swollen and distorted, or a burned up heater.
Posted on Dec 09, 2008
Jul 26, 2013 | Refrigerators
Aug 17, 2011 | Refrigerators
Thank you for contacting fixya.com.
Check the condenser under the refrigerator is clogged with lint. Make sure that the condenser fan underneath the fridge is running properly. You can get to it through the back. Check the coils on the rear of the refrigerator and make sure they are clean and dust free. Also check the back wall or floor of the freezer section for frost. Check the evaporator fan to see if it is running. Check the condenser coils under the unit for blockage from dust. Check the condenser fan under the unit to see if it is running. If you have frost in the freezer there is a problem with the defrost system and the freezer will start to warm eventually as well as the fresh food section. If that is the problem you can check the defrost terminator, defrost heater/s, and the defrost timer or adaptive defrost control If used on your unit or the main control board if so equipped. Also check the freezer to ensure it isn't over loaded with food stuff, reason being air must flow freely threw out the entire refrigerator in order for the thermostat to work correctly.
Defrost the freezer by disconnecting the power to the refrigerator and letting it sit for at least 24 hours with both the doors open to allow the frost to melt completely but it will build up again in 1-2 weeks and start the warming up again.
Please get back to us if you have further query else please accept the suggestion.
Jun 02, 2011 | LG Refrigerators
Hi, Thank you for contacting fixya.com. Check the coils on the rear of the refrigerator and make sure they are clean and dust free. Also check the back wall or floor of the freezer section for frost. Check the evaporator fan to see if it is running. Check the condenser coils under the unit for blockage from dust. Check the condenser fan under the unit to see if it is running. If you have frost in the freezer there is a problem with the defrost system and the freezer will start to warm eventually as well as the fresh food section. If that is the problem you can check the defrost terminator, defrost heater/s, and the defrost timer or adaptive defrost control If used on your unit or the main control board if so equipped. Also check the freezer to ensure it isn't over loaded with food stuff, reason being air must flow freely threw out the entire refrigerator in order for the thermostat to work correctly. Defrost the freezer by disconnecting the power to the refrigerator and letting it sit for at least 24 hours with both the doors open to allow the frost to melt completely but it will build up again in 1-2 weeks and start the warming up again.
Jun 01, 2011 | Whirlpool ED5FHAXV (253 cu ft) Side by...
will build up again in 1-2 weeks and start the warming up again. Please get back to us if you have further query else please accept
the suggestion.
Jun 01, 2011 | Haier HTQ21JAAWW Top Freezer Refrigerator
Check the coils on the rear of the refrigerator and make sure they are clean and dust free. Also check the back wall or floor of the freezer section for frost. Check the evaporator fan to see if it is running. Check the condenser coils under the unit for blockage from dust. Check the condenser fan under the unit to see if it is running. If you have frost in the freezer there is a problem with the defrost system and the freezer will start to warm eventually as well as the fresh food section. If that is the problem you can check the defrost terminator, defrost heater/s, and the defrost timer or adaptive defrost control If used on your unit or the main control board if so equipped. Also check the freezer to ensure it isn't over loaded with food stuff, reason being air must flow freely threw out the entire refrigerator in order for the thomostat to work correctly.
Jun 01, 2011 | Hotpoint Refrigerators
May 02, 2011 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Mar 14, 2009 | Bosch Refrigerators
Oct 07, 2007 | Amana ABB1927DE Bottom Freezer...
Aug 20, 2007 | Magic Chef CTB1722 Top Freezer...
Apr 22, 2018 | Refrigerators
48 people viewed this question
