Hello i have proble with air conditioner and heater is a split system unit
Brand Chigo
model kfr-51gw/gx1a 18000btu.
i have shot circuit at home after tha my unit give me error code F6 ..i read some manuals on the internet but dont give the way to fix.
F6
ambient temp.
sensor of outdoor
fault
1、Check whether the resistance of sensor is normal,
otherwise replace it.
2、Check whether the sensor wire is short circuit or open
circuit, and whether the plug is well contacted, whether
there is welding off or rosin joint on the electric control
board, repair it if there is any above.
3、When the 1 and 2 are both normal, then the components
or integrated circuit is damaged, the electric control
board should be replaced.
maybe you know if only need reset on the outdoor unit./
thanks if you now the awnser please let me know
Thanks for Awnser.
Problem was solved :-)
The unit stop working inself at -15c.
3 days ago was -22c thas way stop working :-(
is my first winter with..
i turn on yesterday and working good again.
those units are not the best solution for extrem wether as here :-(
i guest the only way to running those units all year round was if we kent placed insed garage :-)
thanks
Posted on Dec 11, 2008
  • 334 Answers
What its telling you is that there is an outdoor "thermostat" that senses the outdoor temperature.
The system has found a failure on this area.
It is telling you to check the sensor to see if its actually the sensor thats bad, or something else.
Then its telling you to check the wiring and connection of the sensor to the control board for any loose wiring or broken connections, and to repair it if so.
It then says if niether of those two checks reveal any problems that the problem is the board itself and it should be replaced.
To answer the question, resetting it probably will not work.
There is a small chance that due to power surge, flickering lights, or just a fluke one time glitch that there is nothing rally wrong and resetting would work.
95% chance that is not so.
Posted on Dec 10, 2008
Chunlan kfr-700k
Check this link to see if you can find the manual you are looking for here:
http://shop.panasonic.com/shop/model/36PEF1U6?t=specs
Aug 26, 2014 | Panasonic S-36PF1U6 31,200 BTU Mini-Split...
Celiera 51GW 18000BTU mini split a/c heat, water collects on top rear coil and drips into fan housing and comes out bottom
While cooling, water is supposed to drip off the evaporator coil and flow out the unit. That's a feature of air conditioning. You get a little bit of control of where the water drips to by installing tubing to conduct the water wherever you like, unless the outlet port is plugged up. Poke a toothpick up it and see if that unclogs it.
May 13, 2014 | Haier HEATER CPN10XH9 Air Conditioner
My kfr-51gw/gx1a unit is 3 yearrs and is blowing a black like suit out off it
The soot is temporary.Will go away.Check the flue damper is moving freely.
Nov 22, 2011 | Heating & Cooling
We are trying to find out what an E4 on a Celiera
Does anyone know what does that means
Mar 30, 2010 | Heating & Cooling
Require instructions and wiring diagrams for Celestial KFR-70GW/K
If you pull the unit out of the case it should have a wireing diagram in a envelope near the compressor
Jul 17, 2009 | Frigidaire FAA065M7A Air Conditioner
My mini split only sometimes responds to the remote
indoor pcb in the indoor unit faulty and the responder.
Jun 09, 2009 | Soleus KFR-18GW Split System Air...
Heating & Cooling Logo
405 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
