Question about Whirlpool Estate TAWS750PQ 27-Inch Washer
Dryer not drying clothes
Dryer takes 2-3 times(2-3 hours) before clothes are dry. Heating is fine. Could there be another issue besides built up lint in the hose???
    Habit-Forming:
  • 94 Answers
An easy way to check dryer function is to check the airflow on the outside of your home at the exhaust the vent. While the dryer is running, and hot, put your hand near the outlet. The air coming out should be hot and forceful. If not, there is most likely an obstruction, and the whole airway should be cleaned. Keeping the airway clean and clear can dry clothes faster and save you money.
Another possibility is the blower,(fan) which can become encrusted with lint, preventing it from moving air. This is much less likely, but still a possibility.
Posted on Dec 31, 2008
Not drying properly, no heat
Check the following areas thoroughly to address this issue.
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Aug 06, 2009 | Dryers
Whirlpool dryer....heats
You could have heating element going bad, or a plugged dryer vent. Start with dryer vent, make sure all lint is out of it, all the way through it, even if it goes to the roof, or out the wall. Also vacuum out back of dryer and inside vent tube. This should help with problem. If not then replace heating element its getting weak.
Jul 19, 2009 | Whirlpool LER4634J Electric Dryer
GE DNXR47GW1WW Dryer is extremely slow to dry clothes (takes over 2 hours per load). The dryer does heat. Any suggestions?
1. Venting
2. Thermostat
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective. (if this is a gas dryer, please disregard this statement)***
Jun 16, 2009 | GE Dryers
GE Harmony electric dryer model DPGT750EC1PL- very little heat - small rattle - takes hours to dry load of laundry... any ideas?
Check the following to address this issue.
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
2. Thermostat
3. Heating element
Jun 06, 2009 | GE Profile Harmony DPGT750EC Electric...
Dryer won't heat up to dry the clothes the heating element works
Check the following to address this issue--
1. Venting
2. Thermostat
3. Heating element
Jun 03, 2009 | Kenmore Dryers
Not heating properly, many cycles to dry loads
1. Venting
2. Thermostat
3. Heating element
Jun 02, 2009 | Maytag SDG3606A Gas Dryer
Clothes won't dry
1. Venting
2. Thermostat
3. Heating element
Jun 01, 2009 | Whirlpool ET8CHEXSQ Dryer
Clothes not getting dry
umplug your vent and run dryer see if that will make a different when dryer your clothe if not may be gas coils
Mar 30, 2008 | Dryers
Maytag dryer doesn't dry properly
heating element is fine. it either works or it doesnt, cant work halfway, your problem sounds like you hav a clogged vent a kinked exhaust leaving the home. try looking at the exit point form the home can you see any lint around the housing, VENT VENT VENT
Mar 11, 2008 | Dryers
Washing Machines Logo
152 people viewed this question
Dan Webster
Dan Webster
Sal De
