Question about Kenmore 50522 / 50524 Side by Side Refrigerator
Kenmore coldspot model 106.52572202 not cooling
The frig or freezer is not cooling. I can hear the fan but no cold air.
  • lamppa Jan 24, 2009
    the freezer is working, the refrigerator is not.
  • brus59 Apr 16, 2009
    kenmore refrigerator 106.52572202 is not cooling ,what is the problem and how it fix by my self.thanks
4 Suggested Answers
  • 117 Answers
SOURCE: I have a Kenmore coldspot side by side- not cooling properly
Setting it to 5 is what the manufacturer recommends. If you set it to 1 and the frig is still not cold, then you probably have a faulty cold control (thermostat)
http://tclaundryrepair.com/home
Posted on Feb 19, 2009
EllaWatson25
  • 725 Answers
SOURCE: kenmore coldspot - freezer stays cold, but frig isn't
If this model is a frost free, you probably have a bad defrost system. That would make the unit freeze up and cold air can not get through to cool the unit properly.
We have parts and supplies, so please contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
We look forward to working with you.
Posted on Nov 06, 2009
  • 572 Answers
SOURCE: we have Kenmore Coldspot Model #106
check your compresor if its running. relay can fail in compressor
Posted on Feb 11, 2010
"I have a kenmore coldspot model 106.54382300. The freezer is working fine, but the refrigerator doesn't seem to be cooling. We just bought this used and it has worked fine until tonight, when we finally...
Can you hear a small fan blowing air inside the refrigerator? It sounds like the evaporator fan has gone out and it is not transferring the air from the freezer to the refrigerator in order to cool!
Oct 09, 2014 | Refrigerators
How to check fan motor funtionality of PFCS1NJXB SS?
It probably has two fan motors. One that keeps the compressor cool and one in the freezer compartment that blows cold air out into the freezer and into the frig. You should be able to hear the motor running and feel the air coming out the vents when you open the door of the freezer. The fan runs all the time. If you do not feel or hear, the fan is not working. The one on the compressor, take the cover off the back and you can see if the fan is turning. It runs all the time also.
May 06, 2014 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
My frig is extremely hot to the touch on the metal face that separates the freezer and frig. Any thoughts on what might be causing this problem. If it helps, we just moved the frig from another home. ...
Likely the cooling fan has died. This happened on my unit. The fan is visible from underneath on the rear left side. Use a flashlight to see if it is spinning. I used a broom handle to tap it and it started to run, which cooled the metal you found hot. I ordered the part on line and replaced it. Heating problem went away.
Jul 08, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore coldspot - freezer stays cold, but frig isn't
Nov 05, 2009 | Refrigerators
Refrigerator not cool, freezer ok
Either the freezer continues to freeze up (most likely due to low refrigerant, due to a leak), or there is an obstruction between the freezer and the refrigerator (refrigerators get their cooling from the freezer).
Given that it works after you defrost it, I'm going with low gas. Call a professional to see if the leak can be fixed. If the unit is more than 10 years old, just get a new one.
Aug 22, 2009 | Kenmore Refrigerators
The freezer is cold, but frig will only go down to 41-43 deg rang
Make sure both condenser and evaporator fans are running. Is it possible that you might have something blocking the air flow from the freezer to the fridge?! Can you hear the fan running up on top?
Jul 02, 2009 | Samsung RS2630SH Side by Side Refrigerator
Feb 19, 2009 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Kenmore 50522 / 50524 Side by Side Refrigerator Logo
955 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
