Question about Primera Technology Bravo II DVD Duplicator (62743) DVD±R Burner
My printer will not print text.
When I clean and purge it will print on the disk. but thats all it will do. The color ink is at 50% and black at 96%. I just bought some new disk for the the printer thinking that might be the problem. they have a smother finish on them than the old disk. I tried a old disk witch has a more rough finish but it still did not work.The printer is about one year old and ive only changed the black ink once. All I print is text.
    Problem Solver:
  • 30 Answers
Did you try and change the ink cartridge mode from color + black to color, or vice versa? Another thing you can try is to "prime" the ink cartidges by taking them out of the printer and gently pressing on the print nossels to get the ink flowing, then put the cartridges back in the printer.
http://www.techwaredist.com/repairshop.asp
Posted on Jan 12, 2009
Doesn't print black text despite full cartridge
It may be problem in print head or purge unit, bzt first did you try with print head cleaning under printer properties/preferences?Try few times, if not, remove ink crg., remove print head, take lint free clotch and moisture it with destilled water and put the print head on it few minits, then dry it with anoter lint free cloth.Put it back in and repeat the head cleaning and nozzle check.
If not helpfull replace print head and purge unit with absoerber
Mar 06, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
Wont print black ink all outher colors ok cleand
If you did put in a new printhead, it means you need a new purge, or cleaning assembly. If it doesn't clean and prime the printhead properly, it won't print.
Dec 04, 2009 | Canon PIXMA MP510 All-In-One InkJet...
Black not printing, other colors fine, replaced cart and deep cleaned several times, no result
Assuming genuine ink cartThis worked for me on a HP printer 1.Try print black text ,and run many copies black only. I ran 25x12 times still no black. Run head clean after about each 50 sheets. Persevered and finally BLACK ink OK
Good Luck Inkypete
May 01, 2009 | Canon PIXMA iP3500 Printer
C-7250 HP all in one appears to have a stopped up printer head?
Try placing sheet of black text on copy board, and run many copies black only. I ran 25x12 times still no black. Run head clean after about each 50 sheets. Persevered and finally BLACK ink OK Inkypete
Apr 23, 2009 | HP Photosmart C7250 All-In-One Thermal...
Printer doesn't print text in black or any color
I think you'll need to call canon for a printhead.
Apr 11, 2009 | Canon PIXMA MP780 All-In-One InkJet...
My printer only prints pictures, no text.
Sounds like your black pigment (PGBK-5) cartridge has clogged up the printhead or similar.
You could try running a single Deep clean on the that colour alone (use Right click printer > printing preferences > maintenance tab > Deep Cleaning)
If that doesn't work you will probably need to either:
- clean the printhead (see this thread)
or
- replace the printhead/cartridge
Hope that helps.
Mar 09, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Canon iP90 will not print black text - it will print any other color text. When I print a test page - it only prints the small flag top left page. I have done a deep cleaning - three times. I have replaced...
hi karen,
If you are sure that the ink is present, there two other possibilities: Purge unit work properly so the ink cannot flow down from ink tank or Logic board of you printer is faulty.
Dec 13, 2008 | Canon PIXMA iP90 InkJet Printer
PIXMA MP780 - not printing black chararcters
All the people in this forum with a Canon ink printer not printing black, especially if you tried replacing the print head and still have the same problem.
Your purge unit/capping assembly is most likely clogged. This can be caused by using crappy ink cartridges and by not using the printer for exptemely long periods of time.
You will have to disassemble the printer. First open the lid so the print head moves into the centre of travel. Unplug the power cord. Remove the upper case (can be hard to do, usually they're snap-together).
Remove one screw on either side of the print engine and remove the engine from the lower case. Unplug the cables that go from the main board to the purge unit (the large black assembly covered with old ink, located on the right side of the printer where the head usually would stop after you've finished using the printer and shut it off).
Now you have to remove that black purge unit from the right side of the engine. Usually there are two screws holding it in place.
Give the unit a bath, carefully removing old ink from everything so the unit looks like new. (be sure to remove the one motor first or you will ruin the motor). Check the bottom and make sure the two small clear rubber tubes are not clogged with old ink. Clean the absorber off (the pad in the lower case) if it has ink piled into a small hill shape.
If the tubes look like they might be clogged, you'll have to find a way to clear them out. I can do it in my shop, but it's too in depth to explain.
Reassemble the printer, connect to a PC and do a few deep cleans and print out a test page. Problem solved.
Remember, if one colour is not working it's because the head is clogged. You will have to do multiple cleans to get it to work. If it still doesn't work, then either it's REALLY clogged or the purge unit is not working because it's clogged. If you buy a new print head, then the only thing left is the purge unit. Be brave and try the disassembly and cleaning, or take it to your local service shop.
We charge $45 CDN for a job like this.
Rule of thumb: If you can get it fixed at a shop for 1/2 prince of a new unit, go for it.
Jan 02, 2008 | Canon PIXMA MP780 All-In-One InkJet...
PRINT IN BLACK WITH COLOR CARTRIDGE?
Yes, you can print out in black from a color cartridge, however it is not advised as you will run out of colored ink twice as fast as it combines all the colors to get black.However it works great when your in a pinch and need black ink.
Just go to your printer properties when you print and the option will be in there someware.
Dec 26, 2007 | Canon MultiPASS MP390 All-In-One InkJet...
Primera Technology Bravo II DVD Duplicator (62743) DVD±R Burner Logo
529 people viewed this question
Top Primera Technology Computers & Internet Experts
Jim Goldsmith
Jim Goldsmith
ray gallant
Terry Hair
Are you a Primera Technology Computer and Internet Expert? Answer questions, earn points and help others
