Question about Ricoh Office Equipment & Supplies
We have multiple colors for toner... and the machine is running low on all but the K.. which is black toner. is there a way to stop using the color toner? They run like 179.99 a piece. and we only use the black? Please help Thanks, Britt
  • 928 Answers
When you start to print go to properties. One of those options are either print using only black in or print in grayscale.
Posted on Dec 09, 2008
Why does my kyocera 2026 display an error and says add toner even if I have already added toner?
because your dv unit is not agitating your toner these machines are notorious for this you can take out suspect color dv unit cover the toner hole shake the hell out of the unit smack the bottom a few times put it back in and if that works it will say adding toner it may overtone that color but running multiple copies will eventually clear the excess its best if you wrap the unit in a rag as well as cover the toner hole because toner will leak out when you shake it or replace that color dv unit but they are expensive if you don't know how to remove the dv unit try google or youtube try not to let anything come out when you shake it because there is developer as well as toner in there if you lose too much of that your unit will be worthless it wont ever be able to add enough toner to get add toner message to stop
Apr 08, 2017 | Kyocera 2026 Copier
Tip
Toner
HP has this wonderful idea of throwing out previous toner cartridge design upon every printer release. It is not worth it to keep different models of printers especially color printers. One full set of toner is about a thousand dollars for color laser printers. Every time I had to upgrade one, I bought multiple of that unit and got rid of the old one as soon as I go the use out of it. It you run out of toner and aren't going to buy anymore, print only black. Get you your moneys worth. Then get rid of it.
on May 09, 2014 | HP Office Equipment & Supplies
With WorkForce 500, I am using only black for coping. But other color inks become low and the coping is stopped. Are there any way to do only the black coping?
replace all color cartridges with black toner
if ink fill your color cartridge with black ink using a refill kit
and just buy a new color cart and keep it asside in a zip lock untill you need color
Aug 03, 2009 | Office Equipment & Supplies
Konika Minolta 2430 DL won't let me print
Look through the menus on the printer for a setting for "Low Toner" -- the choices of what to do are usually either "continue" or "stop" or something similar (my 2430DL has this option setting) -- set this option to "Continue".
My 15 year old HPs also have a similar setting. However, this will keep it printing when the black runs out, so you will need to check your print production run visually as you go along to make sure the quality is what you need
Jun 22, 2009 | Konica Minolta Magicolor 2530 DL Laser...
How can I ignore the low toner error message and print black on a Dell 5100cn?
i believe that if you remove the color toner cartridges, it will stop asking and only print black. you may also be able to specify in the print menu settings to disable the color printing
Jun 10, 2009 | Dell 5100cn Laser Printer
Hello, I have a Minolta Magicolor 2490 MF, printer/copier. The display shows "low toner". My question is this: Is it possible for the machine to identify the seperate toner levels, so I can replace only...
hi,
if it has a 4 toners which color are separated (the cyan, magenta, yellow and black) then you can replace a low toner one at a time. for example if the black color prompt you that it needs a replacement then you can put off the black toner without changing the other color not until such time it prompt you that it needs replacement. For replacing it I believe it has an instructional manual or if it's still under warranty you can ask assistance from your dealer to help you how.
Dec 20, 2008 | Office Equipment & Supplies
Still using color toner when printing in black
Check the black toner cartridge. Most printers that use multiple cartridges will use the black cartridge as long as it has toner in it but will then start using the color toner to do the black/grayscale when the black cartridge is empty.
-Graye-
Nov 21, 2008 | HP LaserJet 2550L Printer
Blue Toner finishes quicker
I can't imagine where toner could possible go from one of these sort of cartridges except on to your paper, I had a customer once with the same request and I found on their letter head that they printed with it had a single band of yellow across it hence excess yellow use,,,,,, Do your print runs of anything contain dark bands/underlines? I guess check to see if white background in any prints has a blueish tinge to it, or possiblly somehow black is running out and it is printing the blacks by mixing the colours (Check black block and text to see if it is really black not heaps dark blue to ensure black toner is operating)
next I'd be questioning if cartridges where brother ones?
Nov 20, 2007 | Brother MFC-9420CN All-In-One Laser...
System Fault
9-357.
Black toner problem.Probably You have low toner sensor defect.
But try first to vacuum and clean black toner dispenser.You must vacuum whole path wich is used to transport black toner to developer unit.Then if printing B/W print only, you must print 10 full color sheets every 100 copies.
Jan 29, 2007 | Xerox DocuColor 12 Printer
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
