Question about Gateway Computers & Internet
When I turn my Laptop on my screen is white, I currently have it plugged into my TV, everything works fine except for the screen. How do I correct this problem?
  • 107 Answers
It is most likely a FN+fkey combo to turn it on (should look like on empty box and one full colored box)
Posted on Dec 09, 2008
I purchased a component cable (rectangular plug I think called VGA plugs into female left side laptop toward the back and red, blue and green RCA type jacks for LG TV.
Look for a Function Key (fn) on your laptop for activating the VGA external monitor.
If your fn button is blue (for example) all of the keys on your laptop that are activated when you hold down the fn button will have an option in blue. Look for a blue icon on a key that roughly looks like a monitor or two monitors.
With everything hooked up, press and hold the fn key, then tap the corresponding key to turn on the external monitor.
Having said that... the cable you are describing has a VGA (blue 15 pin connector) that plugs onto the VGA jack of your laptop and splits that signal into a set of component RCA plugs. Its critical how you plug these into the correct place on your LG TV component connections. I know such adapter cables exist but I've never seen one work.
Sep 06, 2017 | Acer Computers & Internet
A friends laptop is only showing a white screen
Step 1:
Fix a White Screen on an LCD Monitor
b>When an LCD screen has turned completely white, there are three normal causes: the screen is defective, the video cable is not connected correctly, or the graphics card on the motherboard of the computer is faulty. You will need to troubleshoot these possibilities to determine which problem you have. If you are not experienced in working on computer equipment, you should not attempt to disassemble your LCD screen because you could easily damage it. Seek professional assistance unless you have experience working on computer hardware.
Disconnect the white LCD screen from the computer by unscrewing the blue monitor cable. Connect the working LCD screen to your computer by attaching its blue monitor cable to the same slot. If your computer display does not show on the functioning LCD screen, try rebooting your computer. If it still does not display, the problem is with your computer's graphic card on the motherboard. Seek professional repair assistance. If your computer display shows normally on the working LCD screen, proceed to Step 2. Unplug the LCD monitor with the white screen. Disassemble the rear panel of the monitor with the small screwdriver. Carefully separate the screws into piles so that you can keep track of how to reassemble the monitor. Locate the internal video cable, a gray cable with a plug on the end that connects to the main components of the screen. See the References section for photos of the video cable for assistance. http://www.laptoprepair101.com/laptop/2008/04/13/laptop-lcd-screen-turned-white/ Unplug the cable, checking for any debris or blockage. Reconnect the cable firmly. Reassemble the LCD screen. Plug it in and connect it to your computer. If the screen is still white, you have a defective LCD screen. You will need to replace it or take it to a professional repair service for assistance.
b> b> b> Without this test you'll have to guess because as I mentioned before this could either bad motherboard or bad LCD screen.
You'll have to disconnect the video cable from the LCD screen (connector 2) and the inverter board (connectors 3 and 1). After that you connect another working screen and test video. For this purpose I'm using one of my test LCD screens. My test screen is cracked and because of that you see a wide white band in the center but it still works fine for this test.
The original screen is white but my test screen works normal (except the crack of course) and I can see the image. After this test I can tell that the problem must be related to the screen. After I assembled everything back together and connected the original LCD, it's still white. CONCLUSION. In my case this problem is related to the LCD screen and it has to be replaced. b> b>
Feb 06, 2013 | Toshiba 16" Satellite A665S6095 Intel Core...
While streaming Netflix from my laptop (via S cable) to my RCA TV, the image on the TV is black & white. Whether streaming or not, when I hook up my laptop to the TV, the desktop image on my laptop...
If the cable is damaged then one of the pins can be bent inside or if it unscrews a solder connection may be undone. see the photo showing color on the left and bw on the right. Also plug everything in turn off everything then turn on the computer and then turn on tv. also try just opposite turn on tv and reboot computer.
Go to Bing homepage Video Wikipedia SVIDEO TV BLACK AND WHITE SCREEN Graphics Cards
Nov 12, 2017 | RCA F32649 32" TV
I am currently trying to connect a laptop to my TV monitor for watching Hulu and some wmv files. Everything is fine on the laptop and when i connect via an SVGA cable everything is fine for 10-40 minutes...
Tries go into the computer Control panel go to monitor resolution change it lower resolution like 1020 to 800 should solved ur video problems,scrambling video is tv not supporting the current resolutions.
Jan 30, 2011 | RCA MM36100 36" TV
I have a DYNEX LCD37 for 2 years, it was working great untill I plugged in a new HDMI cable to use my laptop, after a few uses I turned my tv on one day and the Contrast was lost, everything works fine...
The tv Tuner signal board have problems,might need the replacement of the Tuner signal board it self.Tries the tv unplug,replug it back in like an hour later.Let the tv resetting itself back to the factory setting.See,if that solved ur problems.Not,than the Tuner signal board have problems itself,must be replaced the Tuner signal board itself.
Oct 26, 2010 | Dynex DX-LCD37 TV
Plug in the wii system and everything comes in black and white
Try plugging it into another scart socket, this sometimes happens when a tv does not support 60hz. the result is a screen that has no colour. You could try just plugging it onto the seperate av inputs. Most tv's these days have one scart that will work ok and in colour.
Jan 18, 2009 | Nintendo Wii Console
I dropped my laptop and now the screen is messed up.
Ack. Sounds like you might need to replace your screen (sounds pricey but is cheaper than a new laptop). You can find second hand/refurbished screens or another Aspire with a working screen being sold for parts on Ebay or here
On a side note, if you a have a PC monitor lying around, you can access your files by hooking it up to your laptop via the dvi slot. Granted, it seems a bit ghetto but its a quick fix until you get something more permanent.
I recently broke my iPhone screen and completely shattered a dell laptop a few years ago. You know all those people who are adamant about you buying proper carrying/protective cases? Screw 'em.
Dec 01, 2008 | Acer Aspire 5500 5570-2609 Laptop
Sony T240HD monitor TV
make sure that the plug on ps2 is connected and check the settings on tv and the settings on ps2 browser are correct if possible check ps2 on another tv to be sure of it's settings if the ps2 works the check channel setting on tv make sure it's not in pal setting it should be ntsc and also check the antenna setting make sure it might be set to cable and also check cables of any sharp kinks your problem is with the yellow cable red and white is the sound
Dec 01, 2008 | Samsung T240HD 24 in. LCD TV
Mitsubishi wd 52525 Problems, but no blinking lights.
Are you using an hdmi cord or av cables?
Apr 10, 2017 | Televison & Video
DVD plays only in black and white
Hey, I had this problem on Thanksgiving Day, trying to watch a dvd on my mother's HDTV. You should be able to hook up most standard dvd players to hdtvs. First you have 3 cords, mine were red, yellow, and white. The connections go as follows:
HDTV:
Audio| Component. The white cord should be in a white audio slot. The yellow cord should be in a yellow component slot (video) and the red cord should be in a red video component slot labeled Pr/Cr. Make sure you match the component numbers. For instance, if you want to use component one, then hook all of the cords into the slots for component one. Most hdtvs have multiple component hookups ( think multiple "channels" for your game system, dvd player, etc) so it's important that the corresponding cords go to the correct component slots.
DVD:
Match the yellow and white cords to the appropriately colored slots. The red cord should go into the slot labeled component video out Cr/Pr. Not the red audio out. This worked for me. Hope this helps.
May 02, 2008 | Televison & Video
Computers & Internet Logo
26 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
