Question about Dell 1700n Laser Printer
Dell 1700n Laser Printer Jam trouble
My dell 1700n printer keeps jamming. I have switched paper and cleaned it but still it jams on every page.I tried leveling it off but it is still jamming. I also reversed the pick roller bands but it is still jamming. It is jamming inside the printer so that I have to remove the image drum to remove the jammed paper. It is always in the same spot I am not sure how many pages I have printed but they are quite a lot. It started doing it a little bit and now it does it every time but it progressed quickly.
Remove the image drum and at the front of the printer you will see a rectangle flap that lifts up. Under the flap are three rollers. Clean them and it should take care of the problem. I use a product call Caikleen, it is a rubber cleaner and rejuvinator.
Posted on May 22, 2007
  • 624 Answers
If it?s always in the same spot then you can narrow your search for the problem. -Look where the leading edge of the paper is getting jammed up for an obstruction, especially if the paper is folded in an accordion fashion. Look closely, I?ve fixed many a paper jam by pulling out a corner of a page stuck in a recess. -If the paper path is clear then the next thing I would suspect is the paper you are using. -Try new paper that isn?t bowed, folded or curled. Before inserting into the paper try flex it back and forth along the width and length, then insert making sure to slide the two side guides and the back guide until they fit snugly against the stack of paper. -Other things to check are the rollers where the leading edge of the paper is getting stuck. Make sure they are clean. -Also make sure your toner cartridge is inserted into the printer correctly. If you have a spare try using that, sometimes cartridges can drag on the paper.
Posted on Feb 25, 2007
When printing i get the paper jam message have checked for paper jam but dont see anything
Open the cover on the back of the printer sometimes paper is stuck in there and thats why you can't see it.
Sep 29, 2010 | Dell 1700n Laser Printer
My dell 1700 says that there is a paper jam but there is no paper jam visible
You must remove all drums & toner and open all doors and look with a flash light. steven 818-888-0006
Apr 26, 2010 | Dell 1700n Laser Printer
Printer jam on Dell 1700n
the sensor is on the back of the fuser, it's the small black plastic piece that the paper hits as it passes through. (or is supposed to) online suppliers have this part for under $40 us. it's an exit sensor.
Nov 07, 2008 | Dell 1700n Laser Printer
Paper jam light is on with no sign of a jam printer wont print.
1-paper is most likely stuck in the fuser, (where it exits and gets hot) you will have to remove it
2-it would be better to clean the rollers w/ alcohol then inside out.
Oct 09, 2008 | Dell 1700n Laser Printer
Paper jam on back rollers
If it jams every time while printing only 1 page and stops just past the exit of the fuser unit, it is most likely that there is a problem with the paper exit sensor on the fuser unit. We have many of the 1700N printers and have seen several times that the paper exit sensor actuator arm gets broken off when removing a paper jam.
Sep 15, 2008 | Dell 1710n Laser Printer
Paper Jam error
Try feeding paper from the front, if it works, your paper pickup rollers maybe having problems (dusty/worn-out).
- Bianca
Jun 19, 2008 | Dell 1720dn Laser Printer
Paper jam
There is a sensor in the back that lets the printer know the paper has exited the fuser. It is probably broken off if paper is getting stuck back there.
Also check for paper remnants that are jammed. This may require removal of the fuser.
Mar 13, 2008 | Dell 1700n Laser Printer
Dell 1700n paper jam
Most larger printers like yours have an optical sensor that needs to have the paper pass by in order for it to send the "sent" signal. If the paper doesn't trigger that you get the paper jam error. look at this page http://www.fixyourownprinter.com/forums/laser/47953#1 it will tell you what and where to check for your problem. It has photos and videos. I hope this helps some.
Sep 29, 2007 | Dell 1700n Laser Printer
My dell 1700n Laser Printer Paper Jam Light stays on
The sensor is stuck open or closed. It needs to move back and forth between the sensor. Check the paper path for the sensors.
Aug 29, 2007 | Dell 1700n Laser Printer
Dell 1700n Laser Printer paper jams
Some questions first: -Where in the paper path is it jamming? -Is it always in the same spot or does it vary? -Roughly how many pages have you printed with this printer? -Did anything lead up to this or has it progressively gotten worse?
Feb 20, 2007 | Dell 1700n Laser Printer
Dell 1700n Laser Printer Logo
265 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
