Question about Toshiba Portege 4010 Notebook
F250 EGR insufficient flow
I have a problem with my ford F250 and my computer code is "EGR insufficient flow", can someone help with solving this problem.
Thanks
  • 54 Answers
I'm thinking this is a car issue, not a computer issue, maybe some of the car experts wont see it, however, from what I can think of;
Have you made any changes to the exhaust or intake system before this error occured, it sounds possibly like some of the polution control isn't connected or working properly anymore.
If there have been no changes, I would suggest that the sensor could be broken, I'm not sure how to test them, so you may need to goto a mechanic.
Posted on Dec 09, 2008
I need to know what the problem the p0401 what is the problem 1999 grand Victoria Ford 4.9
wow I wish ford could make a egr system that wouldn't fail as I've seen this one go a lot lately ! anyways the code is for insufficient flow in the egr system , this is a means to recirculate some of your exhaust back into your intake , as a means to reburn some of your excess fuel (emissions) , anyways it consists of a means to meter some of the exhaust , and control it (off/on) also to measure the amount that goes in , its part of the closed loop of the fuel inlet system , the fault code is specifically saying flow sensor cant detect any flow in the pipe , there can be a few causes for this including a bad flow sensor , all are from my opinion a poorly designed system (it doesn't self clean it's self ) as almost a guaranty every 60k miles your gonna have some problem with it
Feb 03, 2016 | Ford Cars & Trucks
Why is codes p2106 p0401 on?
P2106 THROTTLE ACTUATOR CONTROL SYSTEM,-PO401-EGR INSUFFICIENT FLOW
May 29, 2014 | 2005 Ford Explorer
96 cutlass supreme will not pass emission in ut. what should I do? KOER failed, trouble code po401
cleanout egr valve and troutle body . Or replace egr with new one, clean, check vacumm lines , check for clogged check , depending on modle of car you can pippoint problem as some have a common part problem depeding with make of car. But all have to do with exaust system. Insufficient flow exaust flow. Im not an expert, all I know it is related to this, I have it myself so im googling it.
Ford EGR valve
The OBDII fault code P0401 means that the engine computer has detected that the Exhaust Gas Recirculation (EGR) system flow is insufficient. Read more how the EGR system works below. What could cause the code P0401 - clogged or restricted EGR passages
- faulty EGR valve
- EGR valve stuck closed
- problems with the DPFE sensor (Ford)
- problems with hoses to the DPFE sensor (Ford)
- problem with the EGR vacuum switching valve (Toyota)
- clogged catalytic converter
- carboned up EGR temperature sensor
- vacuum supply issues at the vacuum-operated EGR valve
- electrical problems with the EGR valve control circuit
- engine computer problems
helpful website helps you with pinpoint and sou;ution related to auto make and model shows you most common cause of code reading.
www.samarins.com
Apr 16, 2013 | Cars & Trucks
EGR FLOW INSUFFICIENT
On your EGR tube you have two hoses coming off of it. If you put them on in reverse you will get a code of insufficient flow. I put headers on and replaced EGR tube and valve and the flow sensor and that's the code that I received switched the hoses and solved the code
Feb 26, 2013 | 2000 Ford Expedition
Engine code p0401 in 2004 ford explorer 4.0 motor insuficient gas flow detected
p0401 is egr flow insufficiant. check or remove and clean egr and port. and also check the vacuum lines to egr. Insufficient EGR flow frequently is caused by clogged EGR passageways.
Aug 19, 2010 | 2004 Ford Explorer
2005 Ford F250 Deisel DTC 401 Exhust recirulaton flow insuffent
The DPFE sensor has failed on you egr system .Replace just this part and don't let someone sell you a egr valve .The sensor is about$70 and faily easy to do .:)
Sep 09, 2009 | 2005 Ford F 250 Super Duty
2002 Crown Victoria check engine light stays on
also have them change the oxygen sensors, if it's deemed necessary. have someone reset the computer. if the light stays off, then you don't have to.
Jun 14, 2009 | 2002 Ford Crown Victoria
Ford F250 EGR problem
The EGR valve (Exhaust Gas Recirculator) provides a path from ******** to nose of your engine, returning some of the exhaust fumes to the intake to supposedly improve tailpipe emissions.
Uh huh, I agree. Seems like a stupid idea and each car I have cheated (that couldn't tell I was cheating) has gained a little on gas mileage but never as much as 10%.
Your Ford apparently has a sensor to rat you out if you cheat it so the quantity of fumes isn't satisfying that sensor.
This could mean that the EGR is clogged (it's a small hole passing dirty exhaust fumes), failed, or the vacuum line that controls it is cracked or otherwise broken.
Dec 09, 2008 | 1999 Ford F250 Regular Cab
Ford F250 egr insufficient flow
i found that the egr valves sometimes get clogged up with carbon and can be remedied by removing the valve and scraping the port clean .
Dec 09, 2008 | 2002 Dodge Neon
Toshiba Portege 4010 Notebook Logo
69 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
