Hi are you in need to unlock your nokia 6300 from network lock then visit classicunlocking.com here they ask you the network name to which your mobile is locked .finally they send you codes to unlock it.
SOURCE: unlock my nokia 6300
hi i need to know what country your in and what network the phone is locked to is it the code for the sim unlock or is it the master security code that you need let me know as i can help you
SOURCE: nokia n73 master reset code
u will have to go to the nearest nokia care n tell them to do software on ur cell
SOURCE: Nokia 6300 Orange Restriction code required
if you have a phone repair tech or store close to you can try having them unlock it for you, this phone is part of the bb5 line of phones and there is not imei code generator free online to have it unlock .
SOURCE: Nokia 6300 Australia Vodafone requesting restriction code
Handset Unlock - Instructions
Please find below the instructions to unlock your handset.
Handset Unlock Procedure for IMEI:
353508029865248
Your unlock code is:
426850229882845
Manufacturer/Model:
Nokia_6300
Nokia 6300
PHONE UNLOCK PROCEDURE
PLEASE READ THE INSTRUCTIONS CAREFULLY BEFORE YOU ATTEMPT ANY
UNLOCK PROCESS
This procedure unlocks the handset from being network restricted from only
using SIM cards from Vodafone Australia. In
case of difficulties, please refer to the FAQ listed below
1.
Take note of the unlocking code shown above
2.
Insert a Non-Vodafone Australia working
SIM card.
3.
Ensure the phone is charged and then switch the phone
on.
4.
Optional
Step: If the SIM card has a PIN, enter your PIN number. (See FAQ below)
5.
The phone will then display a message. The most common
is “Phone
Restricted”. Select
“undo” by pressing the middle
soft-key button. (Different message? See FAQ below)
6.
Carefully read step 6 before
attempting to enter the unlock code. This step has the potential to PERMANENTLY
BLOCK YOUR PHONE!
Enter into the phone #pw+ followed
by the 15-digit unlocking code then +1#
(Unlocking code is shown above). Do not
enter the 15-digit IMEI number by
mistake
To enter +
press the * (star) key two times
To enter p
press the * (star) key three times
To enter w
press the * (star) key four times
For Example: If your 15-digit unlocking code is 123456789012345, enter the following in
sequence: #pw+12456789012345+1#
(When entering the unlocking sequence it
disappears? See the FAQ below)
7.
Then press “OK”
8.
The handset will display “Phone
restriction off”
unlocked after successful entry of the unlocking code. This will be confirmed if
you can make and receive calls with the Non-Vodafone Australia
SIM card. (You will need reception and phone
credit with the different network provider)
