Question about Desa International Blower Glow Warm Wall Heater
Glo warm wall heater 3 tiles, center tile burns with a big flame
Model 3b-fb, the center burner, the main one, burns with a large yellow flame instead of making the tiles glow red like the other 2 tiles (right and left). I have tried blowing the unit out with a can of "computer air" but it didn't do any good. The other 2 tiles burn fine, (I think) the tiles turn a bright red color and give off alot of heat while the center one just throws a big flame that looks like it could start a fire.
Thanks in advance for any help
    Genius:
  • 1,199 Answers
Do not use ! needs to be adjusted!
Posted on Dec 09, 2008
3 Suggested Answers
tinytrees
  • 92 Answers
SOURCE: first brick burner worn out, can all bricks be replaced?
They can be replaced, go to enerco/Mr.heater as they own Desa and they will hook you up with the parts you need at a fraction of the cost of a retail parts supplier. you can also cal 1-800-251-0001 and talk to a tech.
Posted on Feb 04, 2009
heatman101
  • 43501 Answers
SOURCE: I have model # FA-3A.
To correct the problem the whple heater will need to be taken apart and eveything blown out with compressed air....
Dust and dirt gets into the heater and messes with the gas/air mixture and then does not burn right...
The heater needs to be taken apart and clean throughly piece by piece...
Then it will work again...
heatman101
Posted on Nov 22, 2010
Adjust pilot light
check your gas pressure meter might be too small call gas company they will assist you
Nov 13, 2013 | Dyna Glo "" Natural Gas Heater Mn200tba
Glo warm heater has an orange flame. It shouldn't, should it?
it should be blue , too much air or burner needs cleaning , how long since it was
serviced ? t
Oct 19, 2011 | Desa International Blower Glow Warm Wall...
Glo warm model FA3 burner one and two flame is too high #3 is fine
The higher flame on those 2 burners may be by rusted out. Of course this depends on how old the heater is and how well it has been annually maintained. Unfortunately, DESA International is no longer in business, but some parts are still available. You just have to search the internet for them.
Jan 25, 2011 | Desa International Blower Glow Warm Wall...
I HAVE A VENLESS HEATER GLO-WARM HEATER THAT THE FLAME IS SHOOTING ABOVE THE BRICKS AND HAS EXCESSIVE GAS FUMES APPEARS TO HAVE A LARGE FLAME WHAT CAN IT BE
can you turn flames down with the control knob ,if not you need control gas valve,that if burning right gas for heater you got. Check the data plate.If not right gas your heater your living very dangerous.
Jan 22, 2011 | Vanguard International Blue Flame - Large...
How do you remove wall tiles
Follow following steps -
1.Decide where to remove the grout
2. Scrape the grout away with a utility knife
3.Try a rotary grinder instead.
4.Remove grout until the spacer lugs are visible.
5.Chisel tiles away from the wall.
6.Break the tile if necessary.
If the tiles are grouted, you will have to clear the grout away first. There are inexpensive tools designed specifically for grout removal. After removing the grout, use a small pry bar or a similar tool to pry the tiles away from the wall. Most likely, though, if the tiles were installed onto drywall, the drywall will be damaged during removal. Fortunately, drywall is relatively easy to replace. Once the drywall surface is ready, new tiles can be attached with tile adhesive or mastic. Regrout and seal the tile around the new tiles. *If the new tiles are natural stone they will be very porous and will need to be sealed and dry BEFORE installation.
Perbaiki lantai teraso Teraso cor di tempat Terazo and mosaic tile
Sep 14, 2010 | YouTube Videos
How and where do I replace a thermocouple on a warm glo wall furnace? Help
There should be a thermocouple in front of the burners that has a copper colored wire that runs from the gas valve to the thermocouple. It is located in the pilot flame as it is a pilot proving switch that tells the gas valve the pilot is lit and its okay to open the gas valve to the main burner.
Mar 21, 2010 | Desa International Blower Glow Warm Wall...
Strange flame on versa raypak
Part of your fire tile (white like) has fallen into your pilot area and is messing with the gas/air mix. Cleaning it out should clear the pilot and have it return to a nice blue flame. If you can get a look inside the unit from a mirror to be sure the area of tile damage is minimal you should be ok. Of course to be on the same side you may want to call in a heater tech to tear it down and be sure the fire box is still sound.
Jul 31, 2009 | Raypak BURNER TRAY ASSEMBLY
First brick burner worn out, can all bricks be replaced?
Jan 16, 2009 | Desa International GWP20T GLOWARM Wall...
Desa International Blower Glow Warm Wall Heater Logo
397 people viewed this question
Top Desa International Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Gil Shultz
Are you a Desa International Heating and Cooling Expert? Answer questions, earn points and help others
