Question about Philips 64P8341 64" Rear Projection Television
Tv turns off and power button keeps blinking. If turned on again the number of the chanel will pass buy fast over and over than shut off
  • Philips Master
  • 5,138 Answers
Its a good chance you have a bad SSB board cost 255.00 -325.00
Posted on Dec 09, 2008
LG TV #32In5308 will NOT turn on using the on/off button on the remote or the on button on the rear of the panel. It is getting power, because an HDMI receiver is obtaining power from a USB connector,
Try just pressing a chanel number button, some tv's only turn off with the power button and to power them on you press either the chanel up or down button or one any of the number buttons on the remote
Dec 30, 2014 | LG 32LD350 32 in. LCD TV
TV turns itself off, then on automaticlly
The fan should run for a few minutes after shut off to cool the lamp down.
If I read and understand correctly somewhere in the cycle you are getting 5 red blinks? that is an error code........
Either you or I can Google the model number of the set with 5 blinks.....or visit the Sony site to see what it means.....
Apr 24, 2012 | Sony KF-42WE620
My Mitsubishi Medallion tv stays on for about 10 minutes and then shuts down and won't turn back on until a period of time has passed. It is a rear projection tv about 9 years old. Can anyone help ex
When it shuts off and the green power light goes off, press both the menu and input buttons on the front of the set (not the remote) and hold both for about five seconds and release.
Power light will blink a two digit error code like 2 blinks and then 3 blinks and repeat it several times.
What is the error code?
Nov 14, 2011 | Mitsubishi WS-55819 55" Rear Projection...
I have a wd 62725 mitsubishi digital tv. the timer light keeps blinking fast and cant turn on the tv nor watch it what could be the problem
Try pressing power button for 10 seconds or until it turns off. Wait for 1 minute and turn it on again.
BTW, I own a 73 inch model.
Jun 22, 2011 | Mitsubishi WD-62725 62" Rear Projection...
Sanyo TV I need a code for my optimum cable remote control to turn on and off the TV with their remote control.
Here's the instructions and codes plus an alternative method if one of the codes below do not work.
Three-Digit Code Programming Method:
  1. Turn on the TV.
  2. Press and hold the TV and DONE buttons simultaneously for 3 seconds. The iO button will light.
  3. With the iO button lit, point the remote at the TV and enter the TV's three-digit code (see code table below). The TV will shut off when the correct code is entered.
  4. Verify by pressing the SEL button. This should turn the TV on and off.
  5. Press the TV button to store the three-digit code. The iO button will blink twice to confirm that the code is stored.
Codes: 007, 053, 057, 082, 020, 239
Auto Search Programming Method Use this method if the three-digit code method does not successfully program your remote control:
  1. Turn on the TV.
  2. Press the CBL and DONE buttons simultaneously for 3 seconds. The iO button will light.
  3. Hold down CH+ and release it as soon as the TV powers off.
  4. Press CH- five times (the television may or may not turn on again as you do this). If the television does not power, turn it on manually before proceeding.
  5. Press CH+ one at a time until the television shuts off.
  6. Press TV to save the code.
To save time, the Auto-Scan function is trying codes as fast as possible while CH+ is being held down. It scans so fast that you may pass the desired code while holding down the CH+ button. Steps 4-5 allow you fine tune the auto-scan so you reach the correct code.
Nov 26, 2009 | Sanyo Televison & Video
I lost my one for all codes sheet need help please i have a sylvania tv
press and release the tv button , then press and hold down the set button . the light will blink twice ,now enter code991 ,light will blink twice again. now aim remote at tv and keep pressing tv and power buttons untill your tv shuts off. now try to turn tv on
Oct 11, 2009 | Universal Remote Control Remote Control
Problems w/ Sharp LC-46SB54U remote programming
i will help with the easiest way, hit the TV button, then hold the setup button untill the light blinks twice, then hit 991, it will flash again, hit the 1 again, then hit power, then hit the chanel up button, and if it dont shut off, hit the chanul up button again, keep going this every 2 seconds(with the chanel up button) untill the power shuts off, when it shuts off, hit the setup button again, that will lock it in, hit the power button again-TV should come back on, if that dont work, use the volum up button , after doing the first few steps, hope this helps
Jan 10, 2009 | Sharp LC46SB54U 46 in. LCD TV
Samsung hcm4216w won't turn on light blinks then shuts down and tries to restart again
Your problem is TV is not getting enough power so you better buy a stabilizer and make the power to go thro the stabilizer to TV then it will get sufficient power supply everything will be smooth afterwards even the voltage problem.
Oct 17, 2008 | Samsung HCM4215W 42" Rear Projection...
Panasonic projection tv (shuts down)
Does the power indicator blink? Let me know and I will try to help you out. Just keep responding to this same psot so previous info will still be available.
Jun 30, 2008 | Panasonic PT-47WX49 47" Rear Projection...
I have a 53 inch wide screen Panasonic that is roughly 5 years old. It was working fine until I now hit the power button and the light stays on and then the picture comes on for 5 seconds then the TV...
whatsthe model number of your panasonic. Most panasonics mean convergence failure when the led blinks 3 times. Please respond to this post with your model number and I will post the correct ICs for your model and where you can get replacements with free instalation instructions
Jun 27, 2008 | Televison & Video
Philips 64P8341 64" Rear Projection Television Logo
60 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
