Question about Yukon NVRS 26022T Weapon Sight
Yukon NVRS not working-.
Hi, thank´s in advance for your help. NIGHT VISION SCOPE TITANIUM Model: 3x50 Serial Number: XXX Night vision riflescope gen 2+ , the NVRS 3X50. I installed it on a CZ 22 magnum rifle and zeroed the rifle without problems. The scope was never used on daylight and I always kept the scope objective lens closed when adjusting the scope on the rifle. After the sighting in session at the range, I returned home and tried it again at night but to my surprise, the scope phototube does not turn on. Only the red lighted reticle of the scope and the IR illuminator do turn on, and there´s no image at all. Checked the batteries and they where fresh, the objective lens cover open and the battery cap completely screwed down. There is absolutely no image on the scope, the green image does not turn on, even after 8 hours of the scope resting in my house to be sure it is not an humidity problem. Follow up: I purchased it new, it uses a 2+ tube. It worked perfectly the first 50 rounds of 22 magnum rimfire, then sudently it started to fail. The red hairs turn on, the IR iluminator turns on, but the tube is dark. Sometimes it works but the image appears as the tube was much less powerful. When I first tryed it start time was only 3 to 4 seconds. Now, when the tube works, it takes as long as 30 seconds. Changed batteries but the problem is the same. I really like the scope´s fit and finish, but something seems to be wrong with it. Returned it to Yukon for check, and the scope came back with a hand note inside the box which says the scope works fine.But I doesn´t! At Yukon nobody answers my calls or messages, nor they answer my e-mails.
  • 577 Answers
SOURCE: yukon 2.5 x50 nvrs tactical
Hello, don't worry about it. It is HV to the image intensifier tube. The battery voltage goes through control circuit then to ccfl inverter (here is were dc voltage is switch on and off and switch dc voltage is step up by toroid coil that has two input and only two out puts). By impulsing the coil with two different switch dc voltage on the input this make the current lag the two different phase voltage by 90 degrees. Here is where the strange noise is coming from. The toroid coil is encased in iron case and if half of this iron case is loose, it makes case vibrate so the noise.
Now, the voltage come out of the toroid coil is switching dc (one could call it AC because that what AC voltage is, it switch between positive to negative) this voltage is about 300 to 900 switching DC voltage. This voltage will be applied to a 1/2 wave voltage multiplier (this voltage multiplier with have anywhere four four stages to 10 stages depend on what the input voltage to multiplier is.
Low the voltage out of the ccfl inverter the more stages the multiplier will have.
Now, the voltage multiplier will double the voltage per stage to need image intensifier tube voltage of 12000 to 45000 volts---DC switching or AC what ever one wants to call it. This voltage will bit you but it doesn't have a lot current associated with it, the current would be in the 10 to 15 ua (micro-amps) 1/10X6 amps.
Now, you know. GB...stewbison
Posted on Sep 24, 2011
0 characters
1 Points
My husband has a Paramount moonlight night vision NV 100 that the lumint red light comes on but the night vision stopped working after only a few months it was bought a few years ago he put up and forgot...
Hello. The red light is the IR (infrarad luminator) this inhance the night vision capabilities of the scope, monocular. Do not look directlly into the IR tube, The Paramount Moonlight has gone to the land of the Red Star. The scope contract is up. it junk, to expensive to repair. stewbison
May 26, 2011 | Bushnell MOONLIGHT Night Vision -...
Is this night vision scope effective at 300 - 350 yards? I want to use it on coyotes that come into my farm yard. I am shooting a 25-06 and have killed coyotes at 575 yards, so I want distance with a...
Not really, maybe at extreme shooting---lucky shot. The most effective range would be 200 yrd
and if you are really good with 250 yrds. But you got to be excellent shot and good at it.
With a 25-06 Winchester volocity of 2800--2950 ft/sec you could hit that **** willie coyota at 500+ yards with a excellent 3X9 adjustable scope. But at night without a first night vision scope, no. stewbison
Feb 08, 2011 | ATN Aries MK6500 Weapon Sight
I am Looking for the manual for the D-141M Night Vision Rifle Scope.
Hello, go to Night Optics web site and contact them through their web page. stewbison
Dec 24, 2010 | Kalinka Dipol D-141 Russian Night Vision...
My night vision scope will not turn on. My LEDs work but you can not see anything in the lens. Yes the cap is off. I tried new batteries. It has very few hours of operating time. Help!
Hello, Welcome to the world of Russian night vision system. That is right, Night Owl Optics Cyclops NOCC3 is manufactured in Russian. The biggest problem with these monocular and binoculars and even scope is that they use cheap 1st generation Russian image tubes and everything else. It would be cost prohibitive to have it fixed, that is, if Night Owl Optics will fix it for you. Hint: Auction it on Ebay as night vision parts. Sorry, GB...stewbison
Nov 30, 2010 | Night Owl Optics Cyclops Compact NOCC3...
I have a AMT nightvision rifle scope that was made in the 1990's that has no serial numbers. I am wanting to know more about the scope. what generation etc.
Hello, AMT is defunked, no more, all gone, left in the night, can't see them. no good bye. Don't worry, ATN Inc bought their stuff, just different name now. Sorry, i don't think you can find any material about the AMT NightStorm NV. Try contacting ATN Inc. in CA. ATN does make NightStorm monoculars. GB....stewbison
Nov 18, 2010 | AMT NightStorm Night Vision Optics The...
I DON NOT HAVE A MANUAL OF night vision atn 330 warrrior , I NEED BEACAUSE I LOST...
What is the serial number of your 330 warrior, so i can give u the manual in pdf format, or simply provide the information to
ATN corp
1341 San Mateo Ave., S. San Francisco, CA 94080
Dec 17, 2009 | ATN Night Vision Rifle Scope; Aries 330...
Name of scope . Yukon . Problem : I tried to replace a battery in the dark. Removed the wrong part by relative force . Scope damaged. Two tubes on the front of the scope one is the battery tube and th
I would strip the wires as carefully as I could and get them back together, get the 2 AA batteries back in there, and see what happens. Then go about making a permanent splice in the wires and getting the lens to stay on there, or ship it back to Russia for repairs. Or find somebody to do it. I'm sure it can be done. Hope this helps.
May 24, 2009 | Zhumell Yukon NVRS Titanium 2.5x42 Night...
Yukon spartan my pic is not clear light works but cannot get focu
Define 'clear'.
Is it blurry? Focus the scope or clean the lenses.
Is it distorted? Don't know how to fix. Especially if the lens is cracked/scratched etc.
Is it dark/snowy? Put fresh batteries in.
Do you see black spots in the tube? Don't worry, certain amount of these are quite acceptable.
Anyway: It's a night vision for pete's sake. The picture won't ever be like the one on normal binoculars.
Jan 17, 2009 | Yukon 24021 Monocular
Manual and what generation
Hey there candotha, the site found here:
has some reviews which will be of use to you. I hope it helps. The manuals seem quite hard to locate, but I will notify you if I have any luck.
Feb 10, 2008 | Night Owl Optics Aero NOAR25 Monocular
Yukon NVRS 26022T Weapon Sight Logo
60 people viewed this question
Top Yukon Night Vision & Thermal Optics Experts
Are you a Yukon Night Vision and Thermal Optic Expert? Answer questions, earn points and help others
